  1. Jan 16, 2019 at 5:14 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    This one doesn't come near the skid. The lowest point, the pump itself, is even with the bottom of my radiator and I believe I have the larger one. It's a Denso replacement and hangs down pretty far.
    Fernando[QUOTED] likes this.
  2. Jan 16, 2019 at 5:24 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Yeah depending on your altitude and temp out side. The propane and butane dont burn good in cold temps and high altitudes. Thats why they made white gas stoves.
    lucky13don likes this.
  3. Jan 16, 2019 at 5:31 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    I’m told butane doesn’t burn well in the cold, but I guarantee propane burns just fine in the cold. Well the coldest I have tried is -30 F. and it burned just fine. Colder than that I can’t say for sure.
    Adude[QUOTED] likes this.
  4. Jan 16, 2019 at 5:34 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Need a hand, let me know.
    lucky13don[QUOTED] likes this.
  5. Jan 16, 2019 at 5:37 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Right on..we gotta see how the weather looks.
    Area51Runner[QUOTED] likes this.
  6. Jan 16, 2019 at 5:42 PM
    Phessor
    Phessor Well-Known Member
    Propane boils from a liquid to a vapor at -40° F, anything close to that and it cannot create enough vapor pressure. A cook stove may be able to be lit, but large btu using equipment requires a liquid vaporizer.
    Reh5108 and Adude like this.
  7. Jan 16, 2019 at 5:43 PM
    Adude
    Pnw
    04 Double cab
    Im referencing why they made white gas stoves. If your going to climb a mountain a pint bottle of white gas is smarter and burns at a better ratio. As far as propane I think it looses its effectiveness around 28degs. The bottle and fittings can freeze up as well, causing you to go hungry.
    The propane does work great for truck camping for sure. Since I travel solo or plus 1 I just use backpacking stoves, and pre pair meals at home no mess and less to pack.
  8. Jan 16, 2019 at 8:43 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    How did you seal the pump the the pipe? Just reused the rubber grommet and drilled a hole in the pipe? I’ve done mine the way you originally did, with a T... the way Blackdawg shows in his write up. I can’t fit my skid back on now because the pump hangs too low.
  9. Jan 16, 2019 at 9:12 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Woot. New headlights are awesome, I can actually see with them
    fDo9v4TAyReEOMBmXEw_Fy1A26hFpzB1y-9yLmrf_ba590aa548c22a0bf1a9eb05fe4f528bfe81fad5.jpg
    re_yG_mpFyEp9ifRXpcM6qlVjKgIL3XnoVEnqbUV_383b65bb7bb0dfb3f0c812fa21630c798448e9d7.jpg
    ireymon, Kpatt9, jubei and 6 others like this.
  10. Jan 16, 2019 at 9:23 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, reused the grommet that was already on the pump. 3/4" hole is perfect, actually a little tighter than the original seal I think.
    kuntry09[QUOTED] and chrslefty like this.
  11. Jan 16, 2019 at 10:44 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    So I rebooted my cv tonight with the SDHQ boots. They only came with the large clamps, anyone else use them ? Did they just forget to send the small ones? If not what did you use?
    I’m really not a fan of the large clamps either, they are like half the width of the OEM ones. And it would have been nice for the kit to come with the grease. I used the same grease in both inner and outter boots, but I know the oem kit has different greases for both.
  12. Jan 17, 2019 at 5:10 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    It shows a picture of a large and a small clamp on their product page.
  13. Jan 17, 2019 at 5:37 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Strange. When i called they said these boots dont require the small clamp. One of mine started to seap a little so i used any clamp i could find
  14. Jan 17, 2019 at 5:38 AM
    Gyrkin
    Wyoming
    I don't disagree that white gas is a great fuel, it is. Just saying propane will work in pretty cold temps. I use my backyard grill all winter, and it always works. Temps are regularly below zero, and the coldest I rememger using it was -30 F and it worked just fine. Stuff even cooks in about the same amount of time.
  15. Jan 17, 2019 at 6:06 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  16. Jan 17, 2019 at 6:24 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Sometimes I'm up late enough (I think it's on at 2am on Sat Sun on Fox lol) to catch an episode and that show makes me laugh pretty good
    se7enine[QUOTED] likes this.
  17. Jan 17, 2019 at 6:34 AM
    Dan8906
    Daniel
    Concord, California
    Huh they sent me three sets of boots without them!
    Edit: They state for the Tacoma ones that they only include outer clamps.
    I don’t know why they would say that. OEM has a clamp on the small part.
    Edit: toyota sells them separate for $7 and $10 for the small and large clamp, respectively. But fuck thats way to expensive for my blood lol
  18. Jan 17, 2019 at 7:44 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    ...Our campfire that night was one of our best of the trip. With two bundles of wood, we kept it burning hot - the heat helping to cut the chill of what was clearly going to be a clear, cold night. As we had the night before, talk was of our favorite parts of the trip and places to which we wanted to return - either to re-explore or see in more depth - the list long enough for several more trips!
    See and read the conclusion to the great adventure: F.U.Rain Day 14, 15 - Impassable Roads and Unforgettable Memories
    --- and here's the whole story ---
    [day 1&2] [day 3] [day 4] [day 5] [day 6] [day 7] [day 8] [day 9] [day 10] [day 11] [day 12] [day 13] [day 14 & 15]​
    jammer, 4x4Taco09, Kpatt9 and 3 others like this.
  19. Jan 17, 2019 at 9:16 AM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    Went to the locksmith to get keys made for some new HON storage cabinets I found for $20 a piece at goodwill. $10 each i was able to get both cabinet handles and was pretty pumped when he made keys for my camper aswell!
    92EED450-F82A-420F-B540-63C661F49EA9_zps_281608a987dc92455712a476392de293aeaf8242.jpg
  20. Jan 17, 2019 at 9:16 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Did you purchase the Tundra set?
    I don't see 1st gen Tacoma listed...
