  1. Jan 19, 2019 at 1:59 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    That almost sounds like the veins on a light bar vibrating.
  2. Jan 19, 2019 at 2:01 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    UGGH, that's coated in ice!!
  3. Jan 19, 2019 at 2:22 PM
    eon_blue
    Azusa, CA
    Thought I heard that you have to drill the holes bigger for the banjo bolts on the Tundra calipers but I haven't done the conversion myself... @BartMaster1234 you've done this haven't you
    BartMaster1234 likes this.
  4. Jan 19, 2019 at 2:23 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Did you buy the brake lines for a Tundra or for a Tacoma? The Tundra (stock) is setup to use a hard flared brake line, and then a soft line. The Tacoma is setup with only a banjo bolt and a soft brake line. However, you can make the Tacoma banjo bolt work by drilling it out.
    Most folks use the banjo bolt setup with the soft line, but I'm extra and wanted the setup to match the Tundra stock. So I used LC Engineering's conversion kit with the correct hard and soft brake lines.
    2002Tacoma4x4 likes this.
  5. Jan 19, 2019 at 3:32 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Got my alternator in with the help from @taco71742 after we installed his snorkel.
    Damn thing is huge compared to stock
    Everything is up and running, so far no issues :thumbsup:
    Digiratus, Prayn4surf, Adude and 6 others like this.
  6. Jan 19, 2019 at 3:39 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    The problem is that the remaned calipers are sometimes remaned too shallow for the banjo. This seems to happen somewhat randomly, but more so with less expensive remans from what I've seen. The Napa remans for instance generally don't have the issue, which is one of the reasons I went with them. Link to those calipers and all the other parts I used in my write-up: New-to-me Tires and a Tundra Brake Upgrade
    The other option of course is to go purchase a slightly shorter bolt to use with the Wheelers lines. Or, use thicker crush washers, depending on how much is still sticking out.
    Or, is your problem that it won't thread in at all? If that's the issue, then you've just got a bad reman. Not much to do really except get another IMO. I wouldn't want to re-tap that, since you could end up with metal in the caliper.
  7. Jan 19, 2019 at 3:45 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    I had this problem where the remans were to shallow to take the entire bolt from the wheelers lines. I ended up stacking two thicker copper washers on the bottom side of the fitting so that they would tighten up without bottoming out.
  8. Jan 19, 2019 at 3:49 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Thats why the banjo bolt doesn’t fit. You have a Tacoma length banjo bolt that you’ll have to drill out.
  9. Jan 19, 2019 at 4:08 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    This is not true at all, please don't spread this around.
    The Wheelers lines and bolts ( ) fit just fine on a lot of remaned 13WLs. It's just some that they don't fit on, and it has to do with how the reman was done.
    Not too tight, just 22 ft-lbs.
  10. Jan 19, 2019 at 4:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Sorry. I mistook it for the stock Tacoma banjo bolt which does need to be drilled out, as I’ve been told.
  11. Jan 19, 2019 at 5:24 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Just a tad. It was pouring down rain and then switched to snow rather quickly so everything just froze.
  12. Jan 19, 2019 at 8:31 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Got a new job so no access to a 3D printer anymore. @sk8rjess get on that :p
    Reh5108[QUOTED] likes this.
  13. Jan 19, 2019 at 9:11 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    Just had to pull someone off a median with my truck. First time getting to use some of my newer recovery gear. The old 280k mile Tacoma pulled the car off the median real quick.
  14. Jan 19, 2019 at 9:49 PM
    CamD95
    CamD95 Member
    Cameron
    2003 Toyota Tacoma sr5
    Just finished up swapping the engine. Took me about 3 weeks granted I work all day. Got her washed up and ready to get back on the road
  15. Jan 19, 2019 at 10:02 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Hell of a first post. What'd you swap it with? LS1? 6BT Cummins? Details, man.
    Speedytech7 and eon_blue like this.
  16. Jan 19, 2019 at 10:07 PM
    CamD95
    CamD95 Member
    Cameron
    Nah just put in another 3.4. The other engine was at 200K with a blown head gasket and knocking. So I got one from JDM and pulled the old one, did some swapping, and put the new one in.
    burntkat, jubei, lukester78 and 4 others like this.
  17. Jan 19, 2019 at 10:08 PM
    eon_blue
    Azusa, CA
    Nice, how easy was the JDM swap? I hear they're appealing because of the low mileage engines but can sometimes be a pain since they aren't US spec emissions wise
  18. Jan 19, 2019 at 10:11 PM
    CamD95
    CamD95 Member
    Cameron
    It honestly wasn't that bad. I was going to get someone to do it for me since I'm an amateur mechanic but kept looking at it and didnt seem too bad. Had to swap the plenum and intake manifold(vacuum lines didnt match up), and oil pan and cooler. Went ahead and changed the intake gaskets and exhaust manifold gaskets and replaced the timing belt/water pump. But overall, not bad.
  19. Jan 19, 2019 at 10:15 PM
    eon_blue
    Azusa, CA
    Great to hear, hope it lasts you another 200k+...welcome to TW :cheers:
    2002Tacoma4x4 and CamD95[QUOTED] like this.
  20. Jan 19, 2019 at 10:17 PM
    CamD95
    CamD95 Member
    Cameron
    Thanks. Kept looking around on here during the swap. Figured I'd join in after I finished. Now I have a few cosmetics I'd like to change up. Always a project lol
    Teke, burntkat and eon_blue like this.
