  1. Jan 19, 2019 at 10:21 PM
    taco71742
    taco71742 Well-Known Member
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    3" Toytec Boss Lift with External reservoir and adjusters Prerunner to 4x4 conversion Manual locking hubs 16x10 w/-38 offset 305/70r16 Toyo RT tire
    RUN before it’s to late. Being a Tacoma world member gets expensive :spending:
    burntkat, Seagull233, jubei and 6 others like this.
  2. Jan 19, 2019 at 10:27 PM
    taco71742
    Daniel
    Woodstock GA
    04 Taco DC 4x4 5spd
    I learned this fairly quickly. Glad I left the mall crawler life tho
    04Pre_Runner and 2002Tacoma4x4 like this.
  3. Jan 19, 2019 at 10:33 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Fuc ya man nice, did you trim your exhaust after the shocks were in or is that just a illusion?
    turbodb[QUOTED] likes this.
  4. Jan 19, 2019 at 11:25 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Ha @Titus94 my specs were right for the torque hahah
    I had a feeling the calipers were machined off spec.
    Titus94 likes this.
  5. Jan 20, 2019 at 9:27 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Rebuilt the brakes all around. New drums and rotors. The drums were about an eighth of an inch beyond discard. Pads out back looked brand new, just had a lot of contamination. Used a can of brake clean on each side, have them nice and dry now. All the hardware looks good as well, so I am rolling the dice here, but not to the extent of danger. Now the front brakes, it was damn sure time for them to be done. Pads were worn almost to the backing plates, though the rotors didn't look horrible. I didn't bother micing them out, as I was able to get new ones cheaply. Did them yesterday, and had an immediate improvement in braking.
  6. Jan 20, 2019 at 10:07 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Got my lower ball joints in from Camelback Toyota. With new bolts. @gunny1005 ships fast, took a day to get here.thanks gunny
  7. Jan 20, 2019 at 1:36 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Had a wheel bearing seize up on me
    Adude and Running Board Man like this.
  8. Jan 20, 2019 at 2:14 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Almost! Three of the four attachment points line up. If I'm not mistaken, it is the outside front mount that is flat on 4R, and at 45 degrees on Tacoma.
  9. Jan 20, 2019 at 2:23 PM
    tymeson
    tymeson Let's ride
    Steven
    In the desert
    03 Gold Prerunner
    Bend it 45 ° for a perfect fit
    burntkat likes this.
  10. Jan 20, 2019 at 3:06 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Having driven the truck since the above post... the only difference between driving it with new front brakes yesterday (itself a huge improvement) and just now being that I replaced the rear drums with new, and cleaned the hell out of the rear shoes- holy hell, have i got brakes now! Also, the parking brake doesn't come out nearly as far, and grabs much harder. Don't think I will have to be all "belt and suspenders" on hills, and leave it with parking brake engaged and in gear
    Now if I can just find this brake leak I've had since I bought it. It's just possible that it was a matter of over-excurding the wheel cylinders out back, and leaking fluid that way, due to the rear drums being about 3/16 beyond their discard diameter. I should note that everything inside the drum was soaked in fluid. It wasn't water and didn't smell like gear lube. I sprayed each side down with 2 cans of brake clean, getting all the trash out. So far it seems to have worked quite well. If I still have a leak, I guess next thing to do is replace the wheel cylinders.
  11. Jan 20, 2019 at 7:03 PM
    taco_blanco2005
    taco_blanco2005 Well-Known Member
    NE Florida
    ‘02 Tacoma PreRunner V6 DC
    Busy weekend...
    1. Installed my (new to me) Sony XAV-AX200 headunit. Bought it used off eBay for half the price of new, no scratches and so far so good.
    2. Installed a backup camera from a Amazon. Still need to figure out the location, current location is tucked between the tailgate and rear bumper. I like that it’s somewhat hidden, but camera view isn’t great.
    3. Installed an Access LiteRider roll up tonneau cover. Kinda a PIA to install. Had to cut away some of the bed liner and trim a very small amount of the side rails off as it was too long. Overall though very happy with the look and functionality.
    4. Bought a set of 4Runner 5 star wheels off Facebook marketplace. Need to figure out if I keep the OEM paint color or go a little bit darker (looking at Rustoleum Metallic Dark Steel). Maybe be asking for some second opinions in the coming days.
  12. Jan 20, 2019 at 8:14 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Finished up the wiring for the air compressor and got it all working. Fills an aired down tire from 13psi to 26psi in about 5 minutes. I'm good with that.
    And we had an amazing moon rise out here in Tucson tonight. Crappy cell phone picture, makes me wish I had a real camera.
  13. Jan 20, 2019 at 8:51 PM
    eon_blue
    Azusa, CA
    what does that do? lock up the wheel? I had a shot wheel bearing on the freeway once but luckily noticed something wasn't right and got into a shop before it got worse. Was grinding like crazy and even made it so the front brakes got really sketchy.
    Fernando[QUOTED] likes this.
  14. Jan 20, 2019 at 9:04 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Does the 3rd gen 4runner front seats mount tour trucks? Or are the different?
  15. Jan 20, 2019 at 9:07 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I think they hit 3 out 4 mounting holes
  16. Jan 20, 2019 at 9:27 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Didn't believe the first two guys who answered you?
  17. Jan 20, 2019 at 9:28 PM
    zodc
    zodc Well-Known Member
    Went with a machine gray on the front metal bumper. Rattle can. Really didn't plan on investing in paint. I already wish I put a lot more layers (maybe 2 cans at least) but it's much better than what it was previously.
    I should have took a before and after but I didn't think it would come out this nice.
    Here's an old photo of the front:
  18. Jan 20, 2019 at 9:34 PM
    eon_blue
    Azusa, CA
    yikes...I wish I could've seen what mine looked like, but I was on my way up to my wedding in Santa Cruz that weekend and only had time to drop the truck off and barely time to pick it up late the next day, lol. I got really lucky it didn't leave me stranded along the 5 freeway somewhere between LA and Sacramento, happened right as I got into Santa Cruz.
    The freaky part was having the front brakes suddenly only work at about 10% capacity. The first 3 hours of the drive were completely normal and it went from normal to hell in a handbasket in all of maybe 20 miles. There may have been grinding sounds happening before that I couldn't hear over the road noise being on the highway for so long.
    2002Tacoma4x4 likes this.
  19. Jan 20, 2019 at 10:06 PM
    eon_blue
    Azusa, CA
    Few phone pics from today's trip, started in the High Desert and ended up at ~8k ft.
    JPinFL, BYJOSHCOOK, cbassd and 15 others like this.
  20. Jan 20, 2019 at 10:40 PM
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    Added a small single row light bar to the back of my truck today. 095AFE57-DF93-42FB-9E71-FB4F35A80F31.jpg 86E3C259-C8F4-4596-AE32-71014501932F.jpg
    cbassd, erice, TacoYankee and 5 others like this.
