  1. Jan 23, 2019 at 9:58 AM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Good to see you came out of it with little damage. If that happens again (wheels turned, truck going straight) take your foot off the brake. If that doesn't get your front wheeles tracking, and if you are in 4-wheele-drive, give it a little gas.
    Reh5108 and Nate0303[QUOTED] like this.
  2. Jan 23, 2019 at 11:31 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  3. Jan 23, 2019 at 11:31 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Whoa! That's kind crazy. Glad that thing is still in use. It's not the lightest rack but it was functional. I liked it. Mount that sucker up and lets see some pics!
  4. Jan 23, 2019 at 12:06 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    October 26, 2018.
    "Let's go somewhere." said @mrs.turbodb after I'd been home just a short time from my previous trip. That was of course fine with me, and so we set about finding a place to go. It was going to be cold and rainy on the Washington coast, so we set out looking for somewhere warm...
    ...As we started into Succor Creek Canyon, we were both looking forward to the drive - this area was so beautiful the last time we were here - the hills covered in May's spring green grass, blowing in the wind. The hillsides were golden this trip, but striking nonetheless.
    Read and enjoy the photos in Winter Escape - Hot Springs and the Alvord Playa (Part 1).
  5. Jan 23, 2019 at 1:16 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    You can actually just weld in the stock mounts a lot better, and they will hold the skid just fine. The problem is that from the factory those mounts are just tacked in two places below the LCA.
    Did this to my truck and to Mike's @Digiratus truck, and both have held up just fine through many scrapes.
    Description and pictures of the end result: Fixing the IFS skid mounts
    @xtremewlr
    burntkat, SwampYota and xtremewlr like this.
  6. Jan 23, 2019 at 1:46 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    No engine was off.
  7. Jan 23, 2019 at 3:39 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Your tires should clear with the truck sitting on the bumps. Lift height doesn't clear tires if you flex your suspension.
    It should be pretty easy to drill and tap a zerk into them. I'll likely do it if I find them squeaking.
    I see Subarus more than any other vehicle in the ditch for likely that reason. With snow tires and giving it gas it's like they're on rails but if you brake or let off the gas with an MT they just go straight. Took me a bit to realize that since I was mostly used to driving the Tacoma in 2wd and just letting off the gas to get the back end in line. That didn't work with the wrx I had.
  8. Jan 23, 2019 at 4:04 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Damn, looks great. Clean truck.
    01x4[QUOTED] likes this.
  9. Jan 23, 2019 at 4:12 PM
    Mitch4x4
    Mitch4x4 Member
    Mitchel
    1999 Toyota Tacoma
    Method 305s and 285/75 r16 BF Goodrich KM3s going on this weekend!
  10. Jan 23, 2019 at 4:23 PM
    Brandons2004tacoma
    Brandons2004tacoma Member
    Brandon
    2004 toyota Tacoma Double cab
    Are those after aftermarket headlight housings? Where did you get them they are nice and clean i am needing to replace mine.
    zodc[QUOTED] likes this.
  11. Jan 23, 2019 at 6:24 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    That looks good.
    mechanicjon[QUOTED] likes this.
  12. Jan 23, 2019 at 6:57 PM
    tntacomaguy
    tntacomaguy Well-Known Member
    Did you buy that piece or fab it up yourself? I think I like that spot better than any other place I’ve seen and I’ve yet to mount mine or even set it up lol
  13. Jan 23, 2019 at 7:25 PM
    zodc
    zodc Well-Known Member
    These are actually from protuninglab.com. Initially I tried the HID kit they had. HID is not meant for these housings as it just scattered the beam. I kept the housing because the originals were yellowed and just added halogens.
    They lasted two years. Up close they are about ready to expire/replace. And one indicator housing did leak. I'm assuming the Amazon headlights that are similar to this are all the same.
  14. Jan 23, 2019 at 8:17 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    I have the ultimate headlight upgrade and I’ve noticed mine is around 12.5 with the headlights on...usually it’s 13-14 under normal conditions, hits 12 only every once in a while when the headlights aren’t on.
  15. Jan 23, 2019 at 8:42 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Little bit more progress on the 4x convert tonight. The blue gasket maker has been bugging me. I've never seen blue gasket seal that is for diffs or for contact with gear oil. So I decided to crack her open. Good thing I did. I'm pretty sure, even if the blue RTV was ok for gear oil, this thing would have been a leaker. Almost no RTV on the mating surface. It appears it all got squished out. Took a while to clean everything up. But we used gear oil compatible gasket maker. Put everything back where it goes, and just bearly snugged the bolts. I'll let the gasket maker set up over night and torque the bolts tomorrow.
    1997tacomav6, SwampYota and Fernando like this.
  16. Jan 23, 2019 at 8:49 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Also did a little personalization to the Hellas.
    Have never been a fan of the covers... Like this.
    So I painted them matte black and added some (grey) stickers I found on eBay for a more subdued look.
  17. Jan 23, 2019 at 8:58 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Going to Arb tomorrow!!! The shocks I bought last year had epoxy all over the stem threads (I dont think they were cut deep enough. Cause the 3/4 nut wouldnt budge with a 1/2 ratchet before the top plate They did exchanged them as manufactured defect after alot of hassel. Now my used 881 springs were within 1/16 of free length spec before mounting. These I pulled out of the box 20 minutes ago and my eyeball caught this.
    Maybe this is why some people get a horrible taco lean. Poor manufacturing quality control, I should have just bought kings.
    Pulled tape from the same spot to the same spot. A whole quarter inch difference.
  18. Jan 23, 2019 at 9:05 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The taller spring goes on the driver side... To compensate for the lean.
    A lot of springs for our trucks come that way. Here's a set of OEM replacement springs I had on my truck for a while.
    The taller spring was labled to go on the driver side.
    Zam15 likes this.
  19. Jan 23, 2019 at 10:23 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Are king springs that way?
  20. Jan 23, 2019 at 11:18 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I fab'd it up from a piece of 20g aluminum I picked up at Home Depot. It uses the 2 bolts that hold the light on to secure it. To do it you have to remove stock review mirror and have one that glues to the window.
    tntacomaguy[QUOTED] likes this.
