  1. Jan 24, 2019 at 10:00 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Our night on the Alvord Playa was uneventful - the wind picked up a bit around midnight, easily remedied by closing the door on the windward side of the tent. And, one of the nice things about winter - at least when you're camping - is that sunrise is a bit later. For us, it was nearly 7:00am before the light started on the horizon...
    Read the full story, and our unexpected encounters at Winter Escape - Hot Springs and the Alvord Playa (Part 2)
    - - - catch up on the full story - - -
    [part 1] [part 2]​
  2. Jan 24, 2019 at 10:06 AM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Hey man got it all squared away with ARB, thought I would update you so you are in the know.
    They are exchanging the springs and admit that they are 2 different springs. One at 400mm one at 395mm. This would change the spring rate and make the ride funny. Next time you change a part give it a look and measure to make sure they are specific or within tolerance. We pay alot of money for companies R&d. Though we are all human and shit happens, but Assumption is the mother of all f#$k ups lol.
    :thumbsup::cheers:
    Now out to start on a timing belt that I screwed up by not replacing the Idler pully.
    :facepalm:
    Edit: @Yetimetchkangmi good time to look over at what you will have to do.
    Digiratus and Yetimetchkangmi like this.
  3. Jan 24, 2019 at 11:20 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Added free height of a spring does not change the spring rate. The actual steel they make the coil out of is what would change that.
    5mm difference between springs is not going to make much difference if installed on the driver side. With battery, driver, and full gas tank, there is easily a 2-300 pound difference in load from driver to passenger side.
    I wouldn't have worried about it, but that's just me.
    Did ARB actually say that the longer spring would make it a different spring rate? That part would be more concerning to me than their quality control.
    mechanicjon likes this.
  4. Jan 24, 2019 at 12:11 PM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    Installed a new set of brake rotors, i have a much better pedal now and stops much smoother..
    Adude and burntkat like this.
  5. Jan 24, 2019 at 1:16 PM
    Adude
    Pnw
    04 Double cab
    The only part they make in 400mm is a 887 590lbs spring. The 2 springs I have are different rates springs by lenght and
    Coil spacing wind as well.
    Someone miss tagged a part is my point, Arb, and Wheelers. Also yes, if I had disregarded the .25 difference I would have a 590lb spring and a 500lbs.
    The objective was to make others aware to check your parts before installing.
    jubei and burntkat like this.
  6. Jan 24, 2019 at 1:39 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Watching snow collect and wondering if my chains will be frozen to the ground when I try to head down to town later this afternoon...
    SwampYota, Adude, FLBAdrian and 3 others like this.
  7. Jan 24, 2019 at 2:04 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Well then, if that's the case, and they were different spring rates, your would have had yourself a taco lean.
    Adude[QUOTED] likes this.
  8. Jan 24, 2019 at 6:59 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Well, when you cut a coil down in length/height, you increase the spring rate, so yeah, it does make a difference.
    Adude likes this.
  9. Jan 24, 2019 at 8:01 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Installed a set of new/used Wheelers 8 pack thanks to @Shortman5. So far rides much better than my previous rebuilt Toyota/chevy pack!
    Adude and m3bassman like this.
  10. Jan 24, 2019 at 8:22 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    What?!?!?
    Planning on replacing the plastic $hitbird radiator...
    Timing belt could be next, when you are planning on hitting that?
  11. Jan 24, 2019 at 9:10 PM
    Adude
    Pnw
    04 Double cab
    I tore it down today, just removed the Fan and upper Radiator hose. Pulled all the parts to find out what I needed to order whoppi g 30mins lol. I ordered all Oem parts, both pulleys, tensioner, and belt for a fraction . The parts will be here Saturday or Monday from southern Wa.
    Then the Hot Shot Part Deux, in February will be the 2.4 Aluminum Radiator, Electric fan/s, stand alone Trans cooler, Power steering, cooler, and 7.5lbs lighter crank pulley.
    Your welcome to observe or participate any time.
  12. Jan 24, 2019 at 9:12 PM
    Adude
    Pnw
    04 Double cab
    Why the hell does my Honda civic bounce around like a pogo stick.... All I did was lower it... lmao:playball::cheers:
  13. Jan 24, 2019 at 9:16 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    How does the front of the bed box attach to the bed sides and bottom? Is it bolts? Bolts and welds? (hard for me to see with it installed, and the bed liner)
    Noticed a crack right in the front passenger corner this evening on mine. Wondering if I'm going to be hitting it with the welder or if there's a part I can buy/install. Sides look fine, crack is entirely in the front panel.
  14. Jan 24, 2019 at 9:23 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Well... So we are talking about the same amount of coils only 5 mm taller so NO... That in and of it's self does NOT matter nor change the rate of the spring.
    If you take away an entire coil, or add one, that's a different story. But that's not what we were talking about, now was it?
  15. Jan 24, 2019 at 9:34 PM
    Adude
    Pnw
    04 Double cab
    Its all spot welded that I found. Thats why I bought @shubbins? Bed when mine scrunched
  16. Jan 24, 2019 at 9:41 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    count me in for participate
  17. Jan 24, 2019 at 9:48 PM
    Adude
    Pnw
    04 Double cab
    Come on, come on, let the burning car roll off the cliff everyone. I will give it the first push.
    SwampYota likes this.
  18. Jan 24, 2019 at 9:48 PM
    tony2018
    tony2018 Well-Known Member
    did laundry
    jjsul and Adude like this.
  19. Jan 24, 2019 at 10:08 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lol... I hear ya :thumbsup:
    I'm just glad you worked it out with them before you installed them so you didn't have to do everything twice. Lucky thing you are close to them.
  20. Jan 24, 2019 at 10:11 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Started rebuilding the drivelines (new U-joints and carrier bearing) for my 4x swap.
    Let me just say... FUCK our U-joints are a pain in the ass. Worst U-joints I've ever done, hands down, bar none. (And no, I'm not messing with the Double Cardin... Just the regular U-joints).
    tony2018 and Area51Runner like this.
