  1. Jan 25, 2019 at 8:55 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    It looks like the lip that is on the outer edge (that allows for the cap to be set in before pressing) is where it is mostly oval.
    But where would I look for a new yoke? If I need to replace.
    Also, fortunately this is one of the rear driveline yokes. And this is not the driveline that I'm currently needing to run. This is the driveline I bought because it's the right length (6 cyl, auto, 4x4) for my swap. I have my Prerunner yoke, if I need to use it.
    Adude[QUOTED] likes this.
  2. Jan 25, 2019 at 9:06 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Ahh then its a spare or paper weight. I used the wrong term thats the flange. I want to say Marlin use to sell them, but Im sure you could find online seller. Just make sure the hole pattern and intended needle bearing cup dia are good for what you have going.
  3. Jan 25, 2019 at 9:22 PM
    Phessor
    Phessor Well-Known Member
    What did they charge you?
  4. Jan 25, 2019 at 10:43 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    It was about $770 for a rebuild, honing cylinders, new springs, new shafts and clean up. They cut me a little deal but still very happy with the end product
    2002Tacoma4x4 likes this.
  5. Jan 25, 2019 at 10:45 PM
    tony2018
    tony2018 Well-Known Member
    I hear you.
  6. Jan 26, 2019 at 1:54 AM
    Faster_n_you98
    Faster_n_you98 Well-Known Member
    Nick
    Arnold, MO
    02 Taco
    Bobbed, 4” of Lift, 35’s, Locked F&R, loaded with badassery
    With the clutch engaged in neutral, how would his throw out nearing be making noise, it wouldn’t have any load on it??
    A throw out bearing like any other bearing makes noise or the most noise with a load in it.. so in neutral, clutch pedal down, should make noise, then disappear or drastically quiet down when the pedal is up.
    OP, your problem sounds like it is a failed PILOT bearing/bushing. That is the bearing/bushing pressed into the rear of the Engine Crankshaft that supports the tip of the input shaft.
    I highly recommend you pull that trans ASAP to address it and don’t put it off. If this is the case, the failed bearing/bushing can wear through hardening on the input shaft and that will mean you’re paying for an entire trans rebuild and replacement Input shaft for a $15 part..
    Obviously thoroughly inspect your clutch and replace the throw out bearing with a quality replacement while you’re at it.
  7. Jan 26, 2019 at 3:33 AM
    1997tacomav6
    Denver
    Yea either way pilot or input shaft means pulling the transmission to fix it and see which one and I guess installing a new clutch and all that stuff and a rear main seal since I’m in there.
  8. Jan 26, 2019 at 7:17 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Following mines cracking they're to..
  9. Jan 26, 2019 at 10:50 AM
    Zam15
    Zam15 Well-Known Member
    Derek
    San Diego
    Needs power..
    ARMOR
    It's that time again! Time to play whats that noise!
    Started up the Taco this morning and got a new clicking sound.. Any idea what this could be? Not throwing any new check engine lights yet.
    Happens when stationary, goes faster when the engine revs
  10. Jan 26, 2019 at 12:06 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Replaced the OEM bed stickers with aftermarket ones. I dig the different look now. The 20 year old OEM stickers where a bitch to get off tho.
    OEM stickers:
    New stickers:
  11. Jan 26, 2019 at 12:09 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Have you tried using a long screw driver as a stethoscope (or an actual stethoscope if you have one) to try and pinpoint where the ticking is coming from? Sounds like it might be from the valve cover area which could be vlaves, injectors or who knows what.
  12. Jan 26, 2019 at 4:55 PM
    1997tacomav6
    Denver
    Yup it does or use a long piece of vacuum hose to listen to where the noise is coming from
    xtremewlr[QUOTED] and Zam15 like this.
  13. Jan 26, 2019 at 4:55 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Out trolling for pussy this morning
    And hooked up with a granny
  14. Jan 26, 2019 at 5:09 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Glad to hear that. Post a pic when you get a chance.
  15. Jan 26, 2019 at 5:16 PM
    Shortman5
    Supercharged TRD
    @2002Tacoma4x4
    The J59s are not the wheelers. They are Deavers. Wheelers designed a 8 pack that could handle more weight than the J59s and have a comparable ride. The wheelers are also made to provide 1.75-2” of lift per wheelers website. When I got my new truck I went a different direction.
    I want probably 1/2 to 1” of lift on my new setup. I’ll probably have to get a custom set made. I really want a spring under setup so I can get plenty of arch and sit closer to 1/2” above stock. And spring under supposedly brings the center of gravity lower and I think I’d prefer that since I do a fair amount of driving.
  16. Jan 26, 2019 at 5:33 PM
    1997tacomav6
    Denver
    X2 let me know what you do, I’m in the same boat as you wanting the same thing
  17. Jan 26, 2019 at 5:35 PM
    eon_blue
    Azusa, CA
    I think I have sharper teeth than that cat
    burntkat likes this.
  18. Jan 26, 2019 at 5:36 PM
    Phessor
    I like mine too..
  19. Jan 26, 2019 at 5:37 PM
    eon_blue
    Azusa, CA
    Where'd you get those TRD stickers? I like them a lot better than the stock ones
  20. Jan 26, 2019 at 5:48 PM
    Shortman5
    Supercharged TRD
    It’s gonna be a while. I have a ton of other stuff to do first. So I’ll keep an eye on your build as well.
