  1. Jan 30, 2019 at 9:54 PM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    Just finished changing the front/rear diff and transfer case oil. Did a transmission filter change/flush. Think I’ll need to look at the transmission mount and/or carrier bearring next
  2. Jan 30, 2019 at 9:54 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I made my own out of conveyer belt. It held up great for 4 years of winter
  3. Jan 31, 2019 at 5:02 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Tractor tire inner tube?
  4. Jan 31, 2019 at 5:04 AM
    Brake Weight
    Installed a new head unit. My old one didn’t have Bluetooth or even a USB port so I looked around at a few stores. Found a decent Pioneer unit with all the new features (BT, iOS, Android, blah blah) sans CD player, who plays CDs anymore, for sub $70.
    What’s crazy is I remember paying $300-400 easily for a unit back in the day and this one sounds just as good with mp3 and BT.
  5. Jan 31, 2019 at 5:48 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Not a Hobart fan, personally- got screwed on their warranty on an AirForce 250ci plasma cutter- but that ought to do well. Remember, for anything heavy, multipass is a thing. I built the SAS S10 with a Lincoln 3200HD, a 120VAC MIG machine. I used "dual shield"- ran innershield wire with CO2 gas- and it worked a treat.
    xtremewlr[QUOTED] likes this.
  6. Jan 31, 2019 at 7:43 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Thickest I'll be welding is 1/4" and this is rated up to that so I should be good. And yeah, I'm not afraid of doing multiple passes if I need to, just means more grinding sometimes! I'm admittedly more of a grinder than a welder but hopefully will improve with a decent machine and some practice!
    jubei, Adude and burntkat[QUOTED] like this.
  7. Jan 31, 2019 at 8:08 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If its not too late id highly recommend maybe taking it back and getting the same thing that will run at 220v. Will work much better.
  8. Jan 31, 2019 at 8:15 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I'd love to but I don't have a 220 outlet readily available at this house and it's a rental so I won't be adding one either. Believe me, I thought about it!
  9. Jan 31, 2019 at 8:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ahh drat. Well can always upgrade later.
  10. Jan 31, 2019 at 8:23 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, that's the plan. This welder will work just fine for the time being. Maybe take a little more work with some additional passes but it'll cover 99% of what I want to do or build. For now at least.
    Blackdawg[QUOTED] likes this.
  11. Jan 31, 2019 at 8:26 AM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Your good that Hobart is a awesome little machine.
  12. Jan 31, 2019 at 8:43 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Do you have a washer/dryer outlet? Ran mine that way for years
    Adude likes this.
  13. Jan 31, 2019 at 8:52 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Are you low on brake fluid?
    95 taco likes this.
  14. Jan 31, 2019 at 8:57 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I do but it's not easily accessible to the garage. Not going to run a long-ass extension cord thru the house. Unless I have an issue with the 115, it'll be just fine for now.
    burntkat[QUOTED] likes this.
  15. Jan 31, 2019 at 8:59 AM
    eon_blue
    Azusa, CA
    Mine does this when the e-brake gets to be extremely loose (more than ~16 clicks to get it to hold) and goes away when I crawl under the truck and tighten it.
    Also that light will come on if your brake fluid is low...maybe clutch fluid too? Can't hurt to check both since it's the same fluid in either one. If you have a manual trans that is.
    jtb1798[QUOTED] and JKO1998 like this.
  16. Jan 31, 2019 at 10:26 AM
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Valve cover gasket, tube seals, pcv grommet and valve
  17. Jan 31, 2019 at 10:32 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    omg that looks so much easier than the 3.4
  18. Jan 31, 2019 at 11:05 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
  19. Jan 31, 2019 at 11:28 AM
    4x4Taco09
    Dane
    Louisiana
    SUPER EASY
  20. Jan 31, 2019 at 12:49 PM
    eon_blue
    Azusa, CA
    I can almost smell the gear oil looking at this pic
