  1. Feb 7, 2019 at 8:17 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    He’s on here bro
  2. Feb 7, 2019 at 8:20 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    No way?!?! Sick ass fuck
  3. Feb 7, 2019 at 8:21 PM
    eon_blue
    Azusa, CA
    That's the dude on here with the Cummins diesel Tacoma...he was just posting about being on that show a few days ago. I forget his username though
    He's got a build thread I think...gonna look for it
    burntkat likes this.
  4. Feb 7, 2019 at 8:22 PM
    JKO1998
    Utah
  5. Feb 7, 2019 at 8:22 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Just tagged you in it
  6. Feb 7, 2019 at 8:33 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanka guys. Badass rig.!
    burntkat and 1st4x4 like this.
  7. Feb 7, 2019 at 9:14 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    No full write up on the U-joints (that I've seen).
    But, the way I ended up doing it is set it up like this. (Pull out all the snap rings on the bearing cups before you start)
    That socket on top is a 20mm the socket on bottom just has to be big enough to allow the bearing cup to fall out when you beat on the top socket... Wail on the top socket with a hammer. Once you get the top bearing cup in the middle of those yokes the bottom cup will fall out and you can normally get that side of the U-joint out of the yoke. Do it again on the other side of the U-joint and the whole U-joint is free.
    Putting them back in, just put a 20mm on top and set the bottom on another 20mm and give it good hard taps until you can see the groves (on the inside of the yoke on the bearing cup) to put in the snap rings.
    Now... The Double Cardin joint is a different process. The U-joints in that are replacable, but it's a pain in the ass.
    quetzal likes this.
  8. Feb 7, 2019 at 9:16 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    So... This arrived today. This one makes me nervous.
    I don't enjoy the thought of doing transmission work.
    burntkat, Brice, SwampYota and 2 others like this.
  9. Feb 7, 2019 at 9:41 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Which one is this? My box looked completely different.
    1st4x4 likes this.
  10. Feb 7, 2019 at 9:42 PM
    1st4x4
    sam
    Torrance
    K54908 looks like the part number
  11. Feb 7, 2019 at 9:50 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I got the mildest kit. Says it doesn't need machine work or special tools... We'll see how it goes.
  12. Feb 7, 2019 at 9:52 PM
    Shortman5
    Supercharged TRD
    Well duh. Completely overlooked that. The one I did is supposed to make it shift faster for putting the trans under more abuse. I guess the latter is for when it’s a bit worn and needs a refresh.
    I’m curious though how much it differs in terms of putting them under stress. I’m not a huge fan of the 1-2 shift but at least I can boost through them and know I did something to protect it.
    @Uphillshunter if you don’t mind post the size hole it tells you to drill in the separator plate. I’d like to know how much smaller the bit is.
  13. Feb 7, 2019 at 10:03 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I'll definately post details when I get it done (hopefully this weekend).
    I'll probably make a few posts about it in my thread here.
    https://www.tacomaworld.com/threads/the-el-taco-diablo-4x4-conversion-and-maybe-some-b-s.562405/
    Adude likes this.
  14. Feb 8, 2019 at 1:00 AM
    Flare side Taco Lover
    Flare side Taco Lover I'm gettin hitched...to my truck!
    Mudder Trucker
    Hicktown Ohio
    03 Taco, 98 Ram, 00 Ranger, 85 Ranger, 03 Ranger, 00 Sonoma
    put truck nuts on my 2000 Ranger
    Nice Dodge!
    xtremewlr[QUOTED] likes this.
  15. Feb 8, 2019 at 7:05 AM
    Railroad_Earth
    Railroad_Earth Well-Known Member
    Black 2010 DCSB
    Swapped out my old, torn apart steering rack bushings for some new urathane ones , what world of difference! Also my truck was starting to sputter a little at low and high rpms, so I replaced the spark plugs, wires and boots. Running like a top again! 0B1DD8E8-E89A-4C3B-A9B9-E2FC1E64E8F9.jpg
    SwampYota, Adude, m3bassman and 2 others like this.
  16. Feb 8, 2019 at 7:43 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Well did he win?
  17. Feb 8, 2019 at 7:55 AM
    4banga
    4banga Semi-evolved monkey
    Colorado
    98 3RZ SC 4WD
    LCE headers & cat-back, Bilstein 5100s & AAL, LR UCA's, CVJ axles
    Installed a remanufactured cylinder head last night
  18. Feb 8, 2019 at 9:55 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Can you post some photos? I want to check my frame to make sure it's doing alright.
    Hopefully there isn't a next time.
    This isn't a Tacoma anymore.
    I am not a fan of the 1-2 shift when in low range.
  19. Feb 8, 2019 at 10:00 AM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
    I have that exhaust too :thumbsup:
  20. Feb 8, 2019 at 10:43 AM
    CruisD64
    CruisD64 Well-Known Member
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    Line-X, LED Gauges, Bluetooth Stereo, TracRac, OME 2.5 Lift, Relentless Fab rear bumper, Shrockworks front. Bleh. So much good stuff.
