  1. Feb 10, 2019 at 2:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  2. Feb 10, 2019 at 2:47 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
  3. Feb 10, 2019 at 2:49 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Lol... Just makin sure. Was literally headed out the door to buy fluids for my front diff and t-case. With intentions of buying 75w-90
  4. Feb 10, 2019 at 2:51 PM
    Speedytech7
    They aren't picky, I wouldn't go higher than 80-90 in the transfer case though, I don't think it's little oil pump would be too appreciative.
  5. Feb 10, 2019 at 2:52 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    I was going to get it because its on sale for 2.75 they only had 4 quarts and 30 quarts of 80w-145. If they would have had enough for all 3 I would have bought them
  6. Feb 10, 2019 at 2:54 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    So just go 80w-90... That would make both diffs and the T-case the same (and make it so I need to buy 1 less qt cause I have 1 left over from when I last did my rear diff)
  7. Feb 10, 2019 at 2:55 PM
    Speedytech7
    I've run it plenty when I couldn't find 75-90, you're in a mild climate anyway so it'll be fine
  8. Feb 10, 2019 at 3:10 PM
    1st4x4
    sam
    Torrance
    xtremewlr[QUOTED] likes this.
  9. Feb 10, 2019 at 3:11 PM
    Speedytech7
    I'm not sure I'd waste it on the case, but it won't hurt it.
    1st4x4[QUOTED] likes this.
  10. Feb 10, 2019 at 3:15 PM
    1st4x4
    sam
    Torrance
    Ya I had originally bought the gallon because it was cheaper then buying 3 quarts and I figured it wont go bad so it could sit on the shelf for years untill I swap the oils again. I dont drive my truck as much as most do. I've probably only put 20 maybe 30k miles on her in 5 years.
  11. Feb 10, 2019 at 4:25 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Don't know that I'd call it a waste, it's barely over a quart and makes it so I'm not having to swap around bottles or remember what goes into what since I do the trans and t-case at the same time and boths diffs at the same time. Not necessarily all 4 at the same time tho.
    1st4x4 likes this.
  12. Feb 10, 2019 at 5:25 PM
    Speedytech7
    The t-case isn't picky and at $16 a quart Id just save it for something that is picky like the trans. You could pour recycled veggie fry oil in the tcase and it would probably be okay for a time haha
  13. Feb 10, 2019 at 5:37 PM
    paetersen
    paetersen Well-Known Member
    Spent some quality time with my Taco and my doggo this afternoon...
  14. Feb 10, 2019 at 6:07 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Finally got around to installing the RAM mount.
    Ended up installing to the A Pillar and also the blank switch plate on the dash. As much as I wanted to put a switch where that blank sat, but I may end up leaving the RAM Mount there. More natural to look there vs. the A Pillar. Going to test both locations out and decide.
    xikeda, SwampYota and lucky13don like this.
  15. Feb 10, 2019 at 6:18 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    What climate control knobs are those?
  16. Feb 10, 2019 at 6:36 PM
    Area51Runner
    1st4x4 and lucky13don[QUOTED] like this.
  17. Feb 10, 2019 at 6:41 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Area51Runner[QUOTED] likes this.
  18. Feb 10, 2019 at 6:56 PM
    1st4x4
    sam
    Torrance
    Does anyone here have a pa? Theres been a 100w federal siren speaker on my truck since I bought it and I'm thinking of hooking it up but doing research the pa option on a CB radio will not be loud or I will have to buy a amp to power the speaker which could end up costing close to the price of a used federal pa amp/siren. Lemme know what you have if you have anything
  19. Feb 10, 2019 at 7:11 PM
    Speedytech7
    @BartMaster1234
  20. Feb 10, 2019 at 7:22 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You have a Federal Signal siren system on your truck?
    That will be better than any CB radio PA system. I’d like to know more about the siren system. If that was equipped on the truck properly to be used by emergency services, it would already have an amplifier unit. If you don’t have the siren box, I’m a little confused as to why you have only the Federal Signal siren.
    I should add having a legitimate emergency services siren installed on your vehicle in the State of California (assuming you’re in Lomita) is against the law, including most other states. Even if you don’t use the siren, if an officer sees the box installed in the vehicle you could catch some grief about it. If you hide it well you could probably get by.
    CA Vehicle Code SECTION 27000-27007
    27002. No vehicle, except an authorized emergency vehicle, shall be
    equipped with, nor shall any person use upon a vehicle any siren
    except that an authorized emergency vehicle shall be equipped with a
    siren meeting requirements established by the department.
    Area51Runner and 1st4x4[QUOTED] like this.
