  1. Feb 16, 2019 at 10:19 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Trying to fix as best as possible the fubar passenger side frame horn. This is what I'm working with.
    The plan is to reinforce both frame horns at the bottom where the recovery point mounting holes are with 1/4" plate that I cut to about 14" long. Going to weld those to the bottom of the frame. This will hopefully give me a more solid and hopefully flatter mounting surface for the new bumper. It's a DIY weld up bumper which should allow me to make adjustments for the additional plate.
    Primed the bottom of the 2 plates in hopes that it will help prevent corrosion. Not weld thru primer but it's better than nothing. I hope.
    chrslefty and 2002Tacoma4x4 like this.
  2. Feb 16, 2019 at 10:39 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I want to take mine off too but since I do a lot of backroads and highway driving I’m afraid it would compromise the safety. Last thing I want is to roll it or cause an accident if I had to go around something or slam on brakes. I don’t think the 550lb springs would be enough to act as a sway either. ORIs for the first gen would be awesome because they act as a sway bar as well.
    burntkat likes this.
  3. Feb 16, 2019 at 10:47 AM
    Shortman5
    Supercharged TRD
    Does anyone know what you call the type of switch that the O/D button is?
    I need a switch like that so if I have something wired directly to the battery it will always cut off when I turn the key off.
  4. Feb 16, 2019 at 11:13 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not a fan of Oris.
    550? What you have ome coils? You'll be fine. It's really not that bad. And if you offroad makes a huge difference. Hell rides better in town for the most part too
  5. Feb 16, 2019 at 11:19 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Lose it!
  6. Feb 16, 2019 at 11:42 AM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    :thumbsup:
    Great headway now take a grinding wheel and round that inside corner where you remove material. Even if you are welding over it, that is a horrible habit to start.
    In the futures take a 1/4 or 1/8 inch bit and drill your inside corner out. Like you would using a jig saw. It will be cleaner cut and you wont have created a tare point.
  7. Feb 16, 2019 at 12:05 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Great tips for next time I do something like that, thanks. Already have the driver side burned in, about to start on the passenger side. I'll clean that corner up some more first.
  8. Feb 16, 2019 at 12:11 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I'm not completely sure what you are asking...
    The overdrive switch on the shifter is a momentary switch, but that itself isn't going to achieve what you are asking for.
    What happens is when the truck shuts off, the ECU in the truck effectively resets the state of Overdrive being turned off. When you press the overdrive switch, it tells the ECU to disable it.
    One option to achieve what you want is to wire up a relay that has both 12V directly from the battery as well as a signal from the Ignition circuit that will shut it off when you turn it off. Then you can have either a momentary or another type of switch that lets you control that relay from inside the cab while the truck is on.
  9. Feb 16, 2019 at 12:25 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    I agree with everything you wrote. I just like to only change one thing at a time, and make sure everything is good to go before changing the next thing. Probably unnecessary, yes, but couldn’t hurt.
    burntkat and xtremewlr[QUOTED] like this.
  10. Feb 16, 2019 at 12:46 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Cleaned up and trimmed a little more off the passenger side plate. Then realized I did it all with the plate uside down from what I originally intended...:anonymous:
    So I primed the other side and am giving that a minute to dry before proceeding.
    SwampYota and 2002Tacoma4x4 like this.
  11. Feb 16, 2019 at 12:58 PM
    SpodieOdie
    SpodieOdie Well-Known Member
    2004 Tacoma OR
    None
    Upgraded my son's factory head unit to a Pioneer touch screen, front and rear factory speakers replaced with Polk audio 522 db 5x7s and added a rockford phosgate amp along with a 12 inch Sundown sub with 1.8 cuft Qbomb enclosure. It sounds great with some serious bass for only one12. Taking off the door panels and putting them back on was a slight pain in the ass at times but not too bad.
    IMG_20190215_210109045.jpg IMG_20190215_210059613.jpg IMG_20190215_205925888.jpg IMG_20190215_204720306.jpg MVIMG_20190118_175815539.jpg
  12. Feb 16, 2019 at 1:36 PM
    Shortman5
    Supercharged TRD
    Nope. Eibachs. The 700 that came with the ADS was way to much. Even with no preload it wild sit way too high, just over 3”. So I swapped for the 550 and with zero preload I get 1.75” of lift over stock. Much better ride.
    I just diconnected them today. Eats up bigger bumps much better but more sway obviously. Guess I’ll leave it and decide if I want to leave it.
  13. Feb 16, 2019 at 1:42 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    She gone
    Adude, lucky13don, BYJOSHCOOK and 6 others like this.
  14. Feb 16, 2019 at 1:44 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Well... She may not be actual 4x yet. But she's starting to look like it.
  15. Feb 16, 2019 at 1:48 PM
    Shortman5
    Supercharged TRD
    Exactly were do I tap into the ignition? I need a guide for this. I don’t know anything about relays, fuses, or where to tap into things that’s not too invasive.
  16. Feb 16, 2019 at 1:49 PM
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    Without a sway bar will you need limiting straps? Let me know how it handles after.
  17. Feb 16, 2019 at 1:51 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @Radarninja
    He did a bad ass job on them
    Silver02Taco likes this.
  18. Feb 16, 2019 at 2:04 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Got some goodies delivered today :thumbsup:
  19. Feb 16, 2019 at 2:16 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    [QUOTE
    I think there's going to be a difference in opinion. Your shock is the travel limit so that's what you risk damaging. FWIW I top out my ome coilovers all the time and haven't killed them yet. It's not the most pleasant feeling or sound but it hasn't damaged anything yet.
  20. Feb 16, 2019 at 2:22 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Passenger side burned in now. It's much better but still has a curve in it and the bolts still go in crooked. I'll feel better about bolting the bumper to it and having recovery points there though. Not putting the stock tow hook back on but I will use the tie down brackets since they work well with shackles.
    Yes, my welding still sucks but it's improved significantly from when I started with the cross piece between the horns! I actually went over a few of those welds while I was there.
    burntkat, chrslefty and SwampYota like this.
