  1. Feb 17, 2019 at 4:49 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @wander mojave is that where the wild burros roam. I was out there several years ago, and wish I could have spent more time exploring and hiking there.
  2. Feb 17, 2019 at 4:52 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @Gen1FTMFW I have this job coming in the spring. I've found some really good video's on how to do it. My question for you is why wrap the wire looms with electricians tape.
  3. Feb 17, 2019 at 4:53 PM
    wander mojave
    wander mojave Member
    Pat
    Las Vegas NV.
    1998 Tacoma TRD 5 speed 4X4
    stock and staying that way
    Yes! Also Bighorn sheep. Though its really rare to see them. Such a large area. Red Rock area is better for wild burro sightings.
  4. Feb 17, 2019 at 4:55 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Some looms can be brittle and break, causing plastic shrapnel to find it's way into the heads/motor. Pre-wrapping it keeps it all together while maneuvering the valve covers in and out.
    burntkat likes this.
  5. Feb 17, 2019 at 4:59 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @wander mojave Red Rock was the place I was thinking of. I only got to spend one day there, and we drove up the one big mountain outside Vegas, which I can't remember the name either. I grew up in West Texas, so I've always liked the desert type environment. I know from keeping up with the news, that Lake Mead is in serious trouble, if it doesn't get some serious snow run off, and soon.
  6. Feb 17, 2019 at 5:21 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Thanks @CrippledOldMan. I’ve checked them out as well. Most would need to have the bushings replaced, putting the cost over what a new aftermarket LCA would be. Appreciate the tip though.
  7. Feb 17, 2019 at 6:05 PM
    wander mojave
    Pat
    Las Vegas NV.
    Its definitely been wetter this winter than the past few. The west slope of the rockies is where that water comes from so hopefully theyre getting good snow. California is the largest user of Colorado river water by far and they are getting buried with snow in the Sierras this winter. Arizona and California have agreed to cuts to help stabilize the lake.
  8. Feb 17, 2019 at 6:09 PM
    eon_blue
    Azusa, CA
    yeah the Sierras are getting dumped on this winter...Tahoe just got 116" of snow in the last week alone. I was there the week before and there was already several feet of snow. Mammoth has said that they plan on keeping their ski slopes open through July 4th at least, they haven't done that in years.
    wander mojave[QUOTED] likes this.
  9. Feb 17, 2019 at 6:24 PM
    Jacksongp69
    Jacksongp69 Member
    2004 Tacoma 4wd
    So this weekend I put new shocks on the rear and new strut assemblies on the front, now I'm a little nervous that I may have done them wrong. I ordered Monroe strut assemblies for the front, they were marked left side and right side on the box. I installed the left side first and after I installed the right side I noticed the part number etched on the shock indicated it was L (left side). The boxes were clearly marked left and right and the left assembly had a yellow L sticker while the right side did not. Did I royally screw up? Im sure I couldn't return the assembly assuming that they sent out the wrong one. Any thoughts?
  10. Feb 17, 2019 at 6:27 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Left is typically driver
  11. Feb 17, 2019 at 6:30 PM
    Jacksongp69
    Jacksongp69 Member
    2004 Tacoma 4wd
    Yea I know for sure that I put the left side on the driver side, but I'm afraid I may have two left side struts
  12. Feb 17, 2019 at 6:34 PM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Off the top of my head.Wouldnt your sway bar end link or your brake hose bracket be in the wrong spot?
  13. Feb 17, 2019 at 6:37 PM
    Jacksongp69
    Jacksongp69 Member
    2004 Tacoma 4wd
    Sorry for my ignorance but I'm not sure what you mean?
  14. Feb 17, 2019 at 6:43 PM
    loosnut
    jerry
    feasterville pa
    06 dbl cab long bed
    Disregaurd.Was thinkinh of a different set up.
  15. Feb 17, 2019 at 6:45 PM
    Jacksongp69
    Jacksongp69 Member
    2004 Tacoma 4wd
    Oh ok no problem, I will say it fits fine but I'm sure there is a reason they have a left and a right side but I'm not sure what the differences are.
  16. Feb 17, 2019 at 7:09 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Deer 0, Hellas 0, @RelentlessFab bumper 1. The journey home continues...
  17. Feb 17, 2019 at 7:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Drove it a few hundred miles this weekend to Yellowstone and back with no issues. So think I'm okay for now. Will keep an eye on the oil level.
    Not always. Though it's not due to the axle so much as it is the backing plate being a bit fused to the axle. Give it a whack with a rubber mallet or two. Even a pry bar can be used to pop it off I think there's a notch for that...or I'm thinking if something else
    Reh5108 likes this.
  18. Feb 17, 2019 at 7:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah of course. Just the lower bit. Mine needed a lot with 33x12.5s
  19. Feb 17, 2019 at 7:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    HA!
    nice.
    Didn't bend into the hood huh?
  20. Feb 17, 2019 at 7:13 PM
    Speedytech7
    I would put fresh oil in if it's the same shit from the overheat. It breaks down rapidly in those conditions and becomes more varnish than lubricant
