  1. Feb 18, 2019 at 9:44 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not a problem if you have a manual. Radiator is frame height.
    eon_blue likes this.
  2. Feb 18, 2019 at 9:46 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Or if you have one of those sweet all aluminum super cool champion radiators, amirite? :p
  3. Feb 18, 2019 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That too!
    Explosion included for no extra charge even!
  4. Feb 18, 2019 at 9:49 PM
    tony2018
    tony2018 Well-Known Member
    got pics of carnage?
  5. Feb 18, 2019 at 10:20 PM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    :popcorn: howdy fellas
    tony2018 likes this.
  6. Feb 19, 2019 at 5:20 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @presto just a heads up that I wasn't aware of when I changed my timing belt kit. I've been told by many here on the TW forum to change the fan bearing. It can go at any time without warning. search TW and you'll se it can cause some serious damage. I'm just waiting on warmer weather before I start doing some more work on my 2003.
  7. Feb 19, 2019 at 5:22 AM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    It's probably way too far gone, but does anyone remember the guy that tan bedlined his 5 lug ext cab? Got some questions for him
    burntkat likes this.
  8. Feb 19, 2019 at 5:32 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @renots thanks for the heads up, I've been looking at these, and this is a really good deal.
  9. Feb 19, 2019 at 6:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not really. Couldn't find the leak in the radiator. So just looks like a dirty radiator with a clean spot.
    Yetimetchkangmi and xtremewlr like this.
  10. Feb 19, 2019 at 6:51 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I have been considering it to clear 33s, because I am not about to invest money into lifting the IFS. I am going SAS, but not in the next two years. I need tires soon, so want to run 33s, without a lift. 1" body lift seems like it ought to work.
  11. Feb 19, 2019 at 6:53 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    You need a couple of pipe test plugs and a garden hose adapter.. Pressure check the system yourself. I bet Amazon has everything you need (you just need to get the ID off the hose outlets). I don't have my radiator handy or I could get them for you.
  12. Feb 19, 2019 at 6:53 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I have a 1”, 60$ block lift on stock suspension and run 255’s
  13. Feb 19, 2019 at 6:54 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I measured the backspacing on my 15X8 wheels- came up with 3.75" BS. Does this sound about right?
  14. Feb 19, 2019 at 6:56 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Sounds to me like you'd have been fine with just putting some Copperseal in the radiator and letting it fix it. For leaks like that, it's a permanent repair.
    Seagull233 likes this.
  15. Feb 19, 2019 at 6:57 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    255 whats?
    a 255/70/15 is a 29" tire. This isn't helpful as my stock tires are 31X10.5X15.
  16. Feb 19, 2019 at 6:58 AM
    JKO1998
    Utah
    255/85/16
  17. Feb 19, 2019 at 6:59 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    that's a 32, so we are getting there. :)
  18. Feb 19, 2019 at 7:02 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    So, haven't done this, but need to, BAD- as I have a serious brake fluid leak...
    need to do the LSPV delete mod. I know I have to add a manual PV inline to the rears, that is not a problem. What I need to know, is the size of adapters and Ls needed to remove and replumb around the old LSPV.
    Why remove it, you ask? Because I intend to go with Air over leaf in the rear, if not link-arm. This will defeat the entire purpose of the LSPV as added air pressure to bring the tail up under load will fool the LSPV into thinking the bed is empty.
    Anyone got a line on the parts/adapters needed? I have the manual PV selected at Summit already....
  19. Feb 19, 2019 at 7:02 AM
    JKO1998
    Utah
    The tire calculator thing says it’s barely a 33” :notsure:
    (Look at this big ass slash pile, shit would burn for days)
    I think I a cheap spacer lift would be a lot easier than a body lift
    m3bassman likes this.
  20. Feb 19, 2019 at 7:04 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
