  1. Feb 22, 2019 at 9:23 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Anything is possible... 57 Chevy Sonoma
    burntkat likes this.
  2. Feb 22, 2019 at 9:34 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I need new ones too. I’m tired of them looking so sun faded. The truck looks so much better when I put stuff on them to “restore” them but it only lasts a week or so.
  3. Feb 22, 2019 at 9:36 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    That's the thing. I don't know what my preferences are here. That's why I was hoping to pick someone's brain that has done them.
    Not committed to 63s by any means, just think they are an interesting idea. I will 100% be upgrading my rear suspension (now that 4x4 swap is complete, it's coming up but probably be after some armor and a high clear swing out).
    Definite items for the rear suspension will include:
    - Ubolt flip
    - Shock relocation. Not sure exactly but leaning behind axle, just inside leaf |-o-| straight up and down.
    - Superbumps.
    - And probably 2.0 with resi. (I'm going to do a 1 inch body lift so I can get the xmember for the upper shock mounts up higher without going in to the bed, and hope I can fit 12 inch shocks)
  4. Feb 22, 2019 at 9:36 AM
    eon_blue
    Azusa, CA
    If you buy a new one from Toyota it comes unpainted at $400....if you want, they'll paint it for you but that's probably another $400 lol. I asked when I inquired about a new one.
    I just bought a $60 aftermarket one on fleabay, unpainted and primed...and bought a couple cans of OEM paint and clear coat. Gonna give it a go myself.
    Don't expect it to look perfect but as long as it looks decent I'll be happy
    2002Tacoma4x4 and burntkat like this.
  5. Feb 22, 2019 at 9:38 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I think he’s talking flare, could be wrong though
  6. Feb 22, 2019 at 9:41 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I have 63's, they're not hard to do at all if you are a decent welder/fabricator. Around $200 out the door, and you could shave 60 or 70 off that if you can make your own brackets, leaf perches, etc.
    They ride great, handle a shit load of weight, flex awesome, and are cheap and easy to tune by adding/subtracting different length leafs, of which every junkyard in the country has plenty.
    You're not fitting 12" shocks vertically unless you go outside the frame rails or go through the bed. Maaaaybe 11" short body shocks if you lean them back a bit.
  7. Feb 22, 2019 at 9:43 AM
    eon_blue
    Azusa, CA
    oooh that makes sense, thought he meant his actual fenders were sun faded
    JKO1998[QUOTED] likes this.
  8. Feb 22, 2019 at 9:50 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Maybe I used the wrong choice of words. I realize they will have to lean back a bit. When I say |-o-| it is meaning opposed to
    \-o-/ or /-o-\
    How it the axle wrap with Chevy 63s? That's one of the other questions I had. Pretty sure that question would apply to any other leaf I do, if I go both shocks behind axle.
  9. Feb 22, 2019 at 9:54 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    12" shocks would have to lean back a lot, it would be just as bad as leaning them in. I have 12" fox shocks, they're leaned in pretty good, but I don't do go-fast stuff very much so it's not a big deal.
    Axle wrap is non-existant. The Chevy leafs are way bigger and thicker than Toyota leafs, and they don't move at all.
    I would recommend getting a 4 or 5 leaf pack from a 3/4 ton truck, as I recall it was right around the turn of the century are the ones you want. Older ones have less, but thicker leafs, and they don't flex as well.
  10. Feb 22, 2019 at 9:58 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ok, see this is good!
    Obviously I'd have to make final measurements after I get things set up under there, before I go buy shocks. But it sounds like I'd be looking more toward 10inch shocks than 12 (if I'm following you correctly)
    I'm not looking to do go fast stuff offroad, but t I would be looking for a good, stable, highway speed setup.
  11. Feb 22, 2019 at 10:03 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah definitely wait to order shocks until you've got all your measurements done. See discussion in @turbodb 's excellent post about shock measuring:
    https://www.tacomaworld.com/threads...ment-for-maximizing-shock-utilization.583280/
    You can get 11" shocks from some manufacturer's, if you really want to optimize you can get short body shocks with welded rod ends, etc., to really stuff them in there.
    turbodb likes this.
  12. Feb 22, 2019 at 10:09 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    20190222_103733.jpg Truck idles much better with the new front o2 sensor.
    Just waiting on @Ace115 to get here to start our wheeling trip.
  13. Feb 22, 2019 at 10:10 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Truck says 36!
  14. Feb 22, 2019 at 10:12 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Chevy 63s are definitley a great budget upgrade. I'm in my setup for under $300, which includes the kit (RuffStuffSpecialties) U bolt flip, shock mounts, leaf springs (Junkyard pick-n-pull for $30), shackles, just not the shocks. Whats nice is with the Chevy 63s you can set the lift/ride height/shackle angle all as you see fit and all the while locating your rear axle centered in the wheel well without shims.
    Project: DBL BLK ◇ by ToyRyd
  15. Feb 22, 2019 at 10:17 AM
    Goran
    Goran Well-Known Member
    Jacob
    WA
    2023 Tundra Pro
    Hah, Funny i did the same mod. Just achieved it in a less cool way.
    2002Tacoma4x4 likes this.
  16. Feb 22, 2019 at 10:29 AM
    Goran
    Jacob
    WA
    2023 Tundra Pro
    No, i sheared all 4, Simultaneously too... Was a loud "POP POP POP POP" and down goes the truck.
    JKO1998 likes this.
  17. Feb 22, 2019 at 10:44 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I am too, looks like cheese grade fasteners, but even those should hold up
    Digiratus and JKO1998 like this.
  18. Feb 22, 2019 at 10:46 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    Never go full ugga dugga. Just ugga.
    Silver02Taco and desertjunkie760 like this.
  19. Feb 22, 2019 at 10:48 AM
    Goran
    Jacob
    WA
    2023 Tundra Pro
    Replaced them with 10.9 bolts.
    was a fun Sunday afternoon.
    Getting the truck off the trailer was the most challenging part :rolleyes:
    Speedytech7[QUOTED] likes this.
  20. Feb 22, 2019 at 11:06 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Reason for this is, IIRC, they are hazmat. They contain an explosive charge in the locking assembly.
    I am going to send mine in to be rebuilt. Of course, I'll have to have another vehicle to drive while it's out.
