  1. Mar 5, 2019 at 6:29 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Probably a 22 250
  2. Mar 5, 2019 at 6:31 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Tonight, if it's not raining, I plan to tint my windows. Give them another good scrub with a razor blade and glass cleaner to make sure they are nice and clean, and then squeegee the new tint on.
    I bought a kit from Amazon, precut for our trucks-
    https://www.amazon.com/Window-Toyota-Tacoma-1995-2004-Extended/dp/B00T1QWZY8/ref=sr_1_1_sspa?keywords=97+tacoma+window+tint&qid=1551796081&s=gateway&sr=8-1-spons&th=1
    Actually, bought the set that has the rear windows in my extracab as 50% VLT, and one for the front driver and passenger front at 35%. Given that the hard part is done and they are all pretty much flat slabs of glass, it should go quite quickly.
    EDIT: stand corrected. It was three kits to get what I wanted- back window and X-cab windows at 5%, not 50. Just trying to keep the nosy out of my business.
    DO NOT buy their install tool kit. The same kit can be had at Oreilly for $13.
    quetzal likes this.
  3. Mar 5, 2019 at 6:51 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Most ham radio have a removable face plate for better placement so you can put the main radio body under the seat or similar. Works very nice. That's prime switch real estate
  4. Mar 5, 2019 at 6:55 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    As a HAM for 20 years, that isn't accurate.
    Many do. Not most. But yes, it is a desirable feature.
  5. Mar 5, 2019 at 7:06 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Very common for most dual band radios these days I'd say.
  6. Mar 5, 2019 at 7:08 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Perhaps the market has changed since I last looked. Got any recommendations, say around $200? 2m/440 at a minimum.....
  7. Mar 5, 2019 at 7:18 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Been talking with Brandon from Coastal Offroad, giving some feedback on the bumper and instructions. He's very receptive which is cool. After talking about the concerns over the thickness of the recovery points, he has offered to send me some additional plate, pre-cut to match, that I can use to beef up the recovery points at no charge other than I pay shipping. He said that he hasn't had or heard of any issues with the recovery points yet but did understand where I was coming from with my concerns. Great customer service.
    Adude, RonJon31, JasonLee and 4 others like this.
  8. Mar 5, 2019 at 7:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Assuming you're not wanting a dual channel one with that price range? And you interested in any digital modes?
  9. Mar 5, 2019 at 7:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's cool!
    xtremewlr[QUOTED] likes this.
  10. Mar 5, 2019 at 8:10 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Hiking Death Valley (Feb 2019)
    Before it even began, the trip was off to a rough start. See, we'd planned - if you can call deciding to go on a trip just a few days prior to departure, "planning" - to leave two weeks earlier, but inclement weather caused us to push the trip back. Even so, the weather report was iffy just a few days before the new date - something we decided we'd ignore so we could get out and explore.
    Check out the first two days in part 1 of this adventure:
    Teke, xtremewlr, LukeCC and 1 other person like this.
  11. Mar 5, 2019 at 8:49 AM
    96ways
    96ways Member
    mcgarrette
    original
    original
    Jiveydude likes this.
  12. Mar 5, 2019 at 11:27 AM
    wat0023
    wat0023 Well-Known Member
    Kendra
    Tri-Cities, WA
    03 DC 4x4
    My truck appears to be stuck in 4hi. Any one have any tips? I already tried pretty much everything I’ve seen on here. It clunked hard when I put it in. I didn’t feel it shift out of it when I put it in 2h and the light is still on. Been using it pretty regularly because the roads haven’t been cleared and haven’t had any problems with it.
  13. Mar 5, 2019 at 11:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Go down a small hill and slalom left and right a bit with the truck in neutral. Might help get things to play nicely. Sometimes a tap or two on the 4wd actuator helps too if it has been very cold out
    burntkat and wat0023[QUOTED] like this.
  14. Mar 5, 2019 at 11:41 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Check the solenoid for the 4wd. It's under the passenger side kick panel.
  15. Mar 5, 2019 at 11:45 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    So I am pretty sure I have leaking rear axle seals after looking at things last weekend while doing the LSPV delete. I have the telltale streaks on the inside of my tires from fluid coming from somewhere, and my brake shoes were soaked when I looked at them a month or two ago. I'd replaced the wheel cylinders and cleaned everything up, but still have the problem. Not much else it could be, in fact I can't think of a thing.
    I have done this on a Dana 44, is it similar on the Toyota axle? IE- back out the 4 retainer bolts, slide out the axle, go find someone with a press to replace the axle bearing while we have it out, , then reassemble?? I think I may go ahead and modify the axle vent as well, in favor of a hose going up into the engine bay to an ARB manifold or similar, not just the little factory nub.
  16. Mar 5, 2019 at 11:46 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I thought this was a mechanical engagement system?
  17. Mar 5, 2019 at 11:47 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Blown fuse maybe?
  18. Mar 5, 2019 at 11:49 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes and no. Early years are vacuum operated. But it still takes a main solenoid to kick the power to the vacuum solenoids to open and close.
    Later years are all electronic with actuators for the tcase and diff
    burntkat[QUOTED] likes this.
  19. Mar 5, 2019 at 11:53 AM
    Speedytech7
    Only if you have the j shift transfer case
  20. Mar 5, 2019 at 11:53 AM
    JKO1998
    Utah
    People extend and run a line to the fuel door thing.
    I can find the part numbers in a minute if you want
