  1. Mar 11, 2019 at 6:14 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Oooh yeah @Yetimetchkangmi don’t mount your resi’s there, it looks like a nice protected spot but they’ll get nailed by your UCAs. I had to move mine out in front of the control arms.
    Yetimetchkangmi likes this.
  2. Mar 11, 2019 at 7:16 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That looks great! Are you doing any tube around the sides for bedside protection?
  3. Mar 11, 2019 at 7:58 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Yes - 1.75x.120 DOM.
    And I'll be cutting the bedsides for high clearance.
    BYJOSHCOOK[QUOTED] likes this.
  4. Mar 11, 2019 at 8:49 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    How are you gluing these together? Seems like that would be difficult in-situ.
    BlackPearl[QUOTED] likes this.
  5. Mar 11, 2019 at 8:58 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    If it doesn't, crib it with 4X4 lumber stacked till it does. Just be sure to crib it *properly*. One piece under the jack is fine if you are only going up 4". Any farther, you need to start cribbing in a 2X2 block pattern.
    May look redneck as hell, but it also works exceptionally well. There's a reason rescue orgs and shipyards use cribbing.
  6. Mar 11, 2019 at 9:05 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I thought I took a photo of that incident but it sadly appears I didn't. Much regret.
  7. Mar 11, 2019 at 9:17 AM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    I'm using a hot glue gun. It holds it in place just have to be very carful. Ill admit it I've bump it one of the times to hard and bumper fell off and shattered into pieces. After that I was using a lot more glue to hold the pieces in place.
    burntkat[QUOTED] likes this.
  8. Mar 11, 2019 at 9:19 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Thanks for looking out for me!
    @drr
    Now I'll have to move them before Death Valley in April...
    Digiratus and drr like this.
  9. Mar 11, 2019 at 11:37 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah that was an expensive lesson to learn.
  10. Mar 11, 2019 at 11:48 AM
    eon_blue
    Azusa, CA
    have had a couple of those myself last year...on the bright side, what they taught me I will definitely never forget.
    Such as, if you accidentally cross thread the axle nut to your CV axle, don't be lazy like I was...fix it or swap the axle for another one at the auto parts store. Otherwise, you might (in this case 'will') end up with a wheel bearing failure ~400 miles later. Lesson learned.
    drr[QUOTED] and burntkat like this.
  11. Mar 11, 2019 at 11:52 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Don’t overtighten them either. I had one I had to warranty because the kid who did it used an impact. 315 ft lbs killed the bearing in a few k miles
    burntkat and eon_blue[QUOTED] like this.
  12. Mar 11, 2019 at 11:57 AM
    eon_blue
    Azusa, CA
    It seems like I hear more horror stories related to using impact wrenches while working on vehicles than good ones lol.
    I have an impact driver that I use a lot but it doesn't put out very much torque, it's good for getting things on/off and then finishing them with a torque wrench.
    Seagull233 and burntkat like this.
  13. Mar 11, 2019 at 12:07 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Good Day Today, I just checked my lower ball joints, and have zero movement in them. Looked over all my bushings, and they look good also. Only part I found not right, my drivers side outer tie rod boot has small tear in it. So that will be a soon to be completed project. Now for my Dumb Question for the day. Should I change both outer tie rod ends, or change both outer and inner tie rods while I'm in there. Comments are always welcomed.
  14. Mar 11, 2019 at 12:13 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I just use an impact to get things off and then typically use a ratchet to put things on. Don't wanna booger up the threads or over tighten
    eon_blue[QUOTED] likes this.
  15. Mar 11, 2019 at 12:25 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I used Toyota fpig to install my turbo oil pan. The bung leaked and needed to be rewelded so I had to pull the pan back off. That stuff is strong! I don't think bolts are even needed once it's cured. I'd just use the FPIG. The fsm for the 3rz uses it, no gasket.
  16. Mar 11, 2019 at 12:27 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    It's the same as when people use Dremel tools to work on firearms.
  17. Mar 11, 2019 at 12:50 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Brilliant!
    Another plus of only doing the one side is, you don't have to sweat making both templates even. Make the one side, then have the parts for that side cut twice.. Mirror image, and tack.
    I was going to go with cardboard, but I think this might be easier to get it to not flop around. I assume you're using 1/4" luan ply or similar floor underlayment ply, nothing too pricey (using marine birch would just be stupid, unless you have a line on it for free or dirt cheap).
  18. Mar 11, 2019 at 12:56 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    That's one of the lessons I have had to relearn recently- and made sure to teach my son. "Impact tight" is by no means tight enough. Just because you stalled out the impact doesn't mean it's done right. Example from this weekend- helped my son install a front receiver on his XJ (a huge PITA, due to DSPO lack of maintenance, and rust.) This involved removing the front bumper and drilling a few holes, then wrestling everything in place and getting all the fasteners reinstalled. He first tried tightening each bolt as he went (nope, and I have taught him about that, but let him figure it out himself this time), then once all 6 bolts were in, we used my 20V cordless impact to hammer them in. Stalled it and then had him get his new torque wrench to finish the job. he needed 110 ft/lb on the front two bolts, and that was just about everything he could get out of his 150 pound frame. The others were easy at 48, but hard to get to. After the first pass, go back around and check everything. That part, he remembered.
    It all comes down to, you just have to be smarter than the tool.
    Speedytech7 and eon_blue[QUOTED] like this.
  19. Mar 11, 2019 at 12:59 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Personally I would do both. You're going to need an alignment afterwards, owing to manufacturing variances, so you might as well do them all and pay once. By all means measure them carefully and try to duplicate the length CL-to-CL of the TRE stud, but count yourself VERY lucky if you get it DNO by tape measure.
    Your tire bill and wallet will thank you. Cry now or cry later.
  20. Mar 11, 2019 at 1:01 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Taught my son to always start the fasteners by hand with a ratchet. Run them with an impact to speed things up, but finish up with a torque wrench. Bearing in mind that it's entirely possible to have something TOO tight with an impact, then "final torque" it with the torque wrench- and if you didn't see the fastener move before reaching final torque, it's too tight.
