  1. Mar 12, 2019 at 9:54 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Can the stud be cut off, drilled for longer bolt and then a spacer be used?
  2. Mar 12, 2019 at 9:54 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Well it was a flat bed so
  3. Mar 12, 2019 at 9:55 AM
    Reh5108
    Idaho
    Where are your mounts?
  4. Mar 12, 2019 at 10:01 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I don't think that would work due to the angles. Making spacers to raise it would also move it in.
    My current plan is to cut the uprights off the base piece, and make longer ones. Need to get the angle right so it's an inch higher than the current hole, without moving it in or out. Was also debating ordering new OEM mounts. Could also do what you did with my original ones, but the new perches don't have a hole to receive the head of the bolt.
    Not looking forward to pulling those mounts.
    Reh5108[QUOTED] likes this.
  5. Mar 12, 2019 at 10:07 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Just gave it the day off (it's raining). We have always had an "understanding" with the gifting thing. I take it out on trails and it brings me back.
    jubei and Digiratus like this.
  6. Mar 12, 2019 at 11:39 AM
    Falkor1
    Falkor1 Well-Known Member
    David
    Arizona
    95.5 Tacoma 2.7 4x4
    2,000 Tacoma rear axle with E-Locker.
    The cab bolts aren’t hard to access at all.
    xtremewlr[QUOTED] likes this.
  7. Mar 12, 2019 at 11:49 AM
    98tacomaSR5
    98tacomaSR5 New Member
    1998 Tacoma SR5 2.7L
    Upgraded a very dated Skyjacker 2.5" (SKTOY30KS) to adjustable Bilstein 5100 / OME 2881 spring setup (adjusted to middle setting) and rear shocks. Far superior ride from stock and the Skyjacker lift. Did the ball joints too as I had everything apart. Only a couple hundred or so miles under the new setup but I highly recommend this setup...
    Big shout out to @Wheeler's Off-Road Inc who helped me with all the correct parts I needed to complete the job. Their invoice also has helpful notes on spots I got stuck (e.g. direction of rear shock canister/front spacer mounting, lift achieved at the 3 adjustable settings, etc) Not to mention they gave a member discount!IMG_8897.jpg IMG_0202.jpg IMG_6776.jpg IMG_6014.jpg
    TacoYankee, FLBAdrian, Adude and 8 others like this.
  8. Mar 12, 2019 at 12:03 PM
    Wheeler's Off-Road Inc Well-Known Member
    Grants Pass, OR
    Very Nice! Looks good!
  9. Mar 12, 2019 at 12:36 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    @Wheeler's Off-Road Inc is the shit! :thumbsup:
  10. Mar 12, 2019 at 12:56 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Its a love hate relationship for us east-coasters. Love the customer service and the parts offered, hate the shipping. Totally understand why its as high as it is, but it leaves me looking at other dealers like Low-Range and headstrong that offer free shipping.
    TacoYankee likes this.
  11. Mar 12, 2019 at 1:09 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Huh??? o_O
    Low Range rapes me on shipping. Not a love hate for me with Low Range... I fucking hate them.
    Last thing I bought from them was a vehicle speed sensor. That thing is the size of dipping sauce from McDonalds and weighs about the same. ($30 part) They charged me $15 in shipping... And it turns out it's a Trail Gear part... They had Trail Gear drop ship it from Fresno. An hour and a half from my house.
  12. Mar 12, 2019 at 1:13 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
  13. Mar 12, 2019 at 1:25 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Free shipping over $50.
  14. Mar 12, 2019 at 1:52 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Stock upper mounts, lowers are about as low as I could get without them being below the axle.
  15. Mar 12, 2019 at 4:00 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Both 4 wheel parts and Summit Racing are local so I never pay shipping. I've been able to get everything I need from them and if I can't I can always get it on Amazon and still free shipping.
  16. Mar 12, 2019 at 4:02 PM
    Reh5108
    Idaho
    Jack up the truck so the axle is full droop and remove your current shocks. Measure the distance from mount to mount. Find a shock that is 1/2" to an inch longer. Install the new shocks and let the truck sit at ride height and measure the the exposed shaft. Set your bump distance so it's less than that measurement. Remember that your bump with compress some.
    Adude, kuntry09[QUOTED] and SwampYota like this.
  17. Mar 12, 2019 at 4:22 PM
    eon_blue
    Azusa, CA
    I don't understand why some companies charge so much for shipping items that can easily fit in a USPS flat rate box or envelope...Wheeler's will send stuff in a flat rate ($7 or something like that) box if it fits in one, even if it's something 'heavy' like u-bolts and similar hardware.
    burntkat likes this.
  18. Mar 12, 2019 at 4:26 PM
    JKO1998
    Utah
    Anyone have a 3rd gen 4 runner and want good deal on some Oem balljoints? No bolts and you need 1 castle nut and 2 cotter pins.
    @m3bassman cause you’re the only one I know with a 4R.
  19. Mar 12, 2019 at 4:27 PM
    eon_blue
    Azusa, CA
    @theesotericone has a 3rd gen T4R
    JKO1998[QUOTED] likes this.
  20. Mar 12, 2019 at 4:29 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Changed my oil today, Walmart Super Tech 5W-30 synthetic, and gave the drive train a good lube job. Had one bolt on the skid plate rounded off, and thank God my neighbor showed up with a set of Erwin "Grip" sockets and saved the day. Replaced all the bolts and washers with new hardware from Lowes. Changing the oil used to be such a simple task, but I'll be so dam sore tomorrow, I might not get out of bed. But I won't have to change my oil again for 10k miles, which should get me about an 8 month break. I also installed my new TW group buy Weather Tech Floor mats, thew my old ones in the trash. Thanks TW for saving me some bread on the group buy.:thumbsup:
    burntkat and Ace115 like this.
