  1. Mar 16, 2019 at 8:52 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Tent is on the rack so there is some drag. And the truck has been putting on a little weight lately.
  2. Mar 16, 2019 at 8:57 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
  3. Mar 16, 2019 at 10:05 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I'm refilling at 325 give or take on winter gas and -10% for tires/gearing.
  4. Mar 16, 2019 at 12:17 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Did someone try to rub your VIN sticker off?
  5. Mar 16, 2019 at 1:00 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    The edges tend to flake off. Mine is like that too, just not as bad.
    Actually, that looks like the edges were painted over very poorly.
  6. Mar 16, 2019 at 1:17 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    When I monstalined my truck I didnt really take the time to tape that off
    burntkat and xtremewlr[QUOTED] like this.
  7. Mar 16, 2019 at 3:01 PM
    westcoasttaco99
    westcoasttaco99 Member
    2004 Tacoma prerunner dbl cab
    Pioneer in dash, 2 8inch sub kickers, fabtech 3.5 inch lift and wheels 15x10, limo tint all. Blacked out grill and bumpers
    Slapped a magna on yesterday the quiet 22inch. Very nice mellow tone
    FLBAdrian, burntkat and Poncate like this.
  8. Mar 16, 2019 at 4:38 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Mounted new wheels and tires, after manually mounting and balancing them. Changed out the turn signal housings as the old were faded and made intermittent contact. Ripped out half of the driver side fender liner plastic as I'm sick of hearing it rub the tire on hard turns. PO had a ball joint failure which munched the driver's fender and liner. Reorganized the toolbox, I am slowly working through the glut of chemicals that istaking up so much room
  9. Mar 16, 2019 at 6:00 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Took measurements for my shocks today. Drivers side is 24 5/16”, passenger is 24 3/8”. Which means means the 10” 5125s I currently have are just over 1.5” too long. Is it that big of a deal to have them 1.5” too long? Just would limit up travel and need to use a bigger bump stop?
    Since one appears to be leaking, I would like to replace them but I haven’t found anything besides the 5125 that would come in a 10” stroke...without breaking the bank.
  10. Mar 16, 2019 at 6:06 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    That works, you'll just lose an inch of up travel.
    kuntry09[QUOTED] likes this.
  11. Mar 16, 2019 at 7:22 PM
    eon_blue
    Azusa, CA
    P2238...anyone have experience with this code? Was on a trail today and whenever my truck bounced around violently my engine would cut out and dash lights would come on. Eventually the CEL illuminated and showed a P2238....something about my AFR sensor circuit being bad?
    Confused how an AFR sensor code would cause my truck to loose power intermittently...anyone experience this?
    Driving home on the freeway was fine minus the CEL, but as soon as the truck starts bouncing around the symptoms start
    FLBAdrian likes this.
  12. Mar 16, 2019 at 7:28 PM
    eon_blue
    Azusa, CA
    It was weird I could hear arcing or some kind of electrical zapping going on in the engine bay when it would happen...Definitley something loose I just don't know what. Guess I'll start by looking at the AFR sensor tomorrow and check it's connection
  13. Mar 16, 2019 at 8:25 PM
    JKO1998
    Utah
    Anyone run 285’s on stock wheels (or whatever wheels these are)?
    I’ve realized if my 255’s rub the frame with my Steelies the 285’s won’t be fine.
  14. Mar 16, 2019 at 8:35 PM
    TL4x4Taco
    TL4x4Taco Member
    02 2.7 4x4
    Lift, lights, stereo
    Developed a misfire over the last three days, today I made it stumble long enough to trip the CEL. P0301, so I moved the coil pack to another cylinder and the code followed the coil pack. So my barely over 200K 3rz is getting 4 new Denso coil packs. I'm thrilled because last time this happened, my P0301 was a sucked valve that led to finding the head was cracked.
  15. Mar 16, 2019 at 8:46 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Replaced my auto shifter bushings this afternoon. One was completely rotten away and one tore apart when I removed it. I was surprised since my truck only has 125,000 on it. Once I added a transfer case to the truck the added vibration was just enough to cause the shifter to rattle 24/7 on the highway. It has zero play at all now. The red bushing is hiding behind the transfer case lever.
    Brice and SwampYota like this.
  16. Mar 16, 2019 at 9:11 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    details on how you replaced those bushings?
  17. Mar 16, 2019 at 9:19 PM
    04Pre_Runner
    Andrew
    I got them from @Brice I think it's crazy how bad these get on our trucks. It would be interesting to see what the bushings look like on a garaged stupid low miles truck.
  18. Mar 16, 2019 at 9:21 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    No, I mean is there a write up on where these bushing are located and how to replace them?
    Its not clear in the photo.
  19. Mar 16, 2019 at 9:32 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    So... Some shit happened today.
  20. Mar 16, 2019 at 9:33 PM
    04Pre_Runner
    Andrew
    There are multiple different install videos on YouTube. Just search 1st gen tacoma auto shifter bushing. I wouldn't follow the guide by APDTY. They took apart things that had no business being touched to do the job. I've seen APDTY on Amazon and @Brice selling the bushings themselves.
