  1. Mar 19, 2019 at 9:14 PM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Made some progress on my winch bumper today.
  2. Mar 19, 2019 at 9:28 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I crawled under my truck and took photos of things I've been thinking about and new things I noticed. Mainly the slowly leaking steering rack.
  3. Mar 19, 2019 at 11:07 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Sounds like a vac leak if they get better with high rpm
  4. Mar 19, 2019 at 11:33 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I saw a post on custom tacos that the IAC uses coolant to function properly. I’m going to revert it back to see what happens. I’ve checked for vac leaks. Everything looks good.
  5. Mar 19, 2019 at 11:34 PM
    Reh5108
    Idaho
    What's the reason for bypassing it?
  6. Mar 19, 2019 at 11:36 PM
    Shortman5
    Supercharged TRD
    Coolant heats the TB as hot as the motor runs. Which in turn heats the blower housing as well. Trying to minimize heat soak.
    Reh5108[QUOTED] likes this.
  7. Mar 19, 2019 at 11:47 PM
    Reh5108
    Idaho
    Is the ecu just learning for the cooler air? I'd be impressed if it made that much of a difference though.
  8. Mar 19, 2019 at 11:53 PM
    Shortman5
    Supercharged TRD
    It’s not that it’s the cooler air it’s the Idle Air Control Valve that is actuated when at operating temp.
    Alot of people think that Toyota runs coolant through the TB to keep it from freezing. Which sounds really stupid when you realize it makes more sense that it’s for the IAC to actuate when warm so it’s not in a warm up mode.
    Running Board Man likes this.
  9. Mar 20, 2019 at 4:49 AM
    nczo6
    nczo6 Well-Known Member
    robert
    Triad NC
    2002 2.7 4x4 xtracab silver
    What was the code you used to get your trans temp?
  10. Mar 20, 2019 at 5:46 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Yes, like my aluminum radiator... which I am LOVING, BTW.
    Yetimetchkangmi likes this.
  11. Mar 20, 2019 at 5:49 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    That seems awfully low for the winch. Will it be completely hidden from view?
  12. Mar 20, 2019 at 6:20 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    That's where every winch is mounted basically.
  13. Mar 20, 2019 at 7:14 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Got my emissions done, now to get my tags tomorrow
  14. Mar 20, 2019 at 7:36 AM
    BlackPearl
    Alex
    Toyota Tacoma TRD
    From all the designs I’ve seen they are in about the same area, just like @se7enine mentioned. And yes it will be hidden once the face plates are welded over the front.
    burntkat[QUOTED] likes this.
  15. Mar 20, 2019 at 8:07 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Nice. Can't wait to see how it shapes up. I will be building one soon, but not for a Tacoma.
  16. Mar 20, 2019 at 8:53 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Are the CVs for 3rd gen 4Runners and 1st gen Tacomas the same? I thought they were/would be.
    Curious because the reboot kits are different part numbers and the 4Runner one (04438-35060) looks like it comes with more grease (in tubes) than the Tacoma one (04438-04021) which has little plastic packs of grease.
    A little worried that as I tear into the CV today that I won't have enough grease to fill up the boot...which Timmy does in his video...the boot is FULL.
    @gunny1005
    @Timmah!
    chrslefty likes this.
  17. Mar 20, 2019 at 9:04 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I think i am running a 4runner cv. Maybe @SCRunner12 can answer your question
  18. Mar 20, 2019 at 9:11 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    They are the same far as I know.
  19. Mar 20, 2019 at 9:14 AM
    eon_blue
    Azusa, CA
    something about that screenshot just murdered my appetite
    Running Board Man and burntkat like this.
  20. Mar 20, 2019 at 9:16 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Ever done this before? Does the boot need to be that full?
