  1. Mar 20, 2019 at 9:21 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I haven't. Id want it as full as possible though.
    burntkat likes this.
  2. Mar 20, 2019 at 9:55 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    When I did mine recently the boot was pretty full.
    turbodb[QUOTED] likes this.
  3. Mar 20, 2019 at 10:06 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    When I got my boots they came with two different types of grease, it was plenty to fill them up. If you need more Auto Zone carries packs of grease for CV rebuilds.
    The boots should be the same, cant go by part numbers even Toyota has a part number for the left CV and another one for the right and they are the same CV.
  4. Mar 20, 2019 at 10:51 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yeah, thanks guys. As I look at the packs more (and smooth the grease down into the end of the pack rather than let it level out), it looks like the volume of grease is probably pretty close (the same) to the tubes that I see in the 4Runner parts. Looks like enough to fill the boots completely.
  5. Mar 20, 2019 at 11:16 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Any reasons you can't use a high quality moly grease or similar, such as you'd use in a grease gun?
    I seem to recall doing that with an old car many years ago, but it's been decades since I owned anything and had to deal with CV joints.
  6. Mar 20, 2019 at 11:24 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Last night- set the SWR on my CB. Got it to 0.8:1 on 1 and 40. I had to tweak the length of the antenna a bit- this is why I love Firestik antennas and use them whenever applicable. Plus, they are "fat"- large bandwidth as well as physically stout construction. 108" whip might get out farther (MIGHT!) but every one I ever ran got kinked in a short length of time. Plus, I can put my 5' Firestik in the bed out of sight/mind if I need to park somewhere sketchy, or need to go into a parking garage.
    I used right at 18' of cable- not because I think that's the magic number, just so happened to be what I needed. I'd intended to cut to length and then make a few pigtails for tuning, but this works.
    Changed out my washer nozzles. Not because I read some 35-page thread extolling the virtues of other nizzles while grousing about the stockers (seriously- first-world problems, much??), but because when investigating the reason the driver's side gave no output to speak of, it broke. $10 in the Dorman aisle and I found a set to replace them, giving me great spray- nice and wide, atomized- and adjustability. And, done.
    Depending on how I feel when I get off, need to put those switched relays under the hood to feed my LEDs on the front, and the CB.
  7. Mar 20, 2019 at 11:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Think I caught your Reddit post at the carwash haha
  8. Mar 20, 2019 at 11:49 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
  9. Mar 20, 2019 at 11:52 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Nice setup. I am going to tuck my aux batteries under the toolbox in a frame so they are out of sight/mind, and put an inverter in the box. Might put my air pumps there too.
  10. Mar 20, 2019 at 11:53 AM
    rctoy
    konstantenos
    Pocatello Idaho
    it's a good place for them helps get weight of the front end and in the back for the kind of rock crawling i do it really helps balance the truck out and believe it or not it lowered my COG.
    burntkat[QUOTED] likes this.
  11. Mar 20, 2019 at 11:58 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I can see that being the case. I may just build an enclosure under the bed and install there. Basically borrow a page from Roget Brown's Toyota Cheap Tricks. That will be a bit of a bitch to change out, though.
    Adude likes this.
  12. Mar 20, 2019 at 12:06 PM
    rctoy
    konstantenos
    Pocatello Idaho
    yeah it'll be a PITA but if you use high quality batteries that don't bleed and typically last 8 years then use air compressors that have remote mount air filters like the viair compressors you'll only have to go in there to change batteries every 8 years.
  13. Mar 20, 2019 at 12:11 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    That's the plan. I was planning on using the AGM batteries at Oreilly's (had good luck with them, and I get a discount), and running the intakes for the compressors to a manifold to get them as high as possible. The only downside to putting the compressors in the toolbox is the resonation that will occur- but then I have enough crap in there that isn't likely to be an issue.
    Might just put the compressor under the hood. Not the best location, either. -shrug-
  14. Mar 20, 2019 at 12:14 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Nah must have been someone else, I don't use Reddit.
  15. Mar 20, 2019 at 12:15 PM
    rctoy
    konstantenos
    Pocatello Idaho
    I'd put them in the back like I did. Honestly mine with the lid of the box shut aren't loud at all and i cant hear them in the cab at all when im wheeling. granted I do have the Stealth edition compressor which already run quieter than the others.
  16. Mar 20, 2019 at 12:23 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I will consider it. Have you run an intake out of the box, or is it not sealed?
  17. Mar 20, 2019 at 12:46 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    You will have enough grease with the Tacoma reboot kits. If I'm remembering correctly, you get two packs of grease per joint. I've rebooted two sets of Tacoma axles and there was plenty of grease. To get the tripod off the axle, it's a little different for Tacomas. You first expand and slide down a c-clip under the tripod and then tap the tripod downward to expose a smaller c-clip above the tripod. Once that upper clip is off, you can slide the tripod off the axle.
    turbodb[QUOTED] and SwampYota like this.
  18. Mar 20, 2019 at 12:48 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Do you still have the file/ paper you used for the front diff removal and replacement? Your own instruction sheet?
    Hope that makes sense
  19. Mar 20, 2019 at 12:51 PM
    eon_blue
    Azusa, CA
    You mean his video?
    https://www.youtube.com/embed/w_gPiDvh9v4
    I believe they're doing a 3rd gen T4R but I'm sure it's similar if not the same process
  20. Mar 20, 2019 at 12:54 PM
    JKO1998
    Utah
    Yea I watched the video, I’m talking about his cheat sheet thing he made with all the torque specs and what not
    eon_blue[QUOTED] likes this.
