  1. Mar 26, 2019 at 11:50 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Black out the radiator while you’re up in there.
    burntkat likes this.
  2. Mar 26, 2019 at 11:58 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    There is that - but kinda to be expected with solid mounts.
    Main issue being they'll drop your engine an inch. I just went through a big headache with them, and ended up cutting them apart and modifying them to get the engine at the proper height.
    SilverGhost and burntkat like this.
  3. Mar 26, 2019 at 12:03 PM
    PreTRUD
    PreTRUD Member
    Would it be worth it to add an inch plate where it mounts to the frame?
  4. Mar 26, 2019 at 12:05 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah I plan on hitting the condenser eventually but making sure there are no leaks are higher priority for me than aesthetics.
  5. Mar 26, 2019 at 12:09 PM
    Squeaky Penguin
    Brett
    That won't work as they mount at an angle and you would also be moving it in.
    I would just get new OEM mounts and save the frustration.
  6. Mar 26, 2019 at 12:15 PM
    PreTRUD
    PreTRUD Member
    Thanks, I greatly appreciate the input. I would hate to have them installed and hate life.
  7. Mar 26, 2019 at 12:58 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I like the cage/rack around the back. Is that something you built?
  8. Mar 26, 2019 at 1:18 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I was able to use a bearing separator and some all thread to remove mine. I'll see if I can find the picture.
    burntkat[QUOTED] likes this.
  9. Mar 26, 2019 at 1:28 PM
    Reh5108
    Idaho
  10. Mar 26, 2019 at 1:36 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Update on my coolant leak: checked all the heater core hoses again as well as the coolant lines that run near the back of the intake and to the IAC. Didn't see any leaks there, unless its hiding under something I can't see. The leak is present when the truck is running and when it's not. Freeze plugs on the side of the block aren't leaking, but they could be on the back, just not sure if those are located above or behind the trans bell housing. Took some pictures as well:
    Driver's side of bell housing:
    Further up on the engine, near the head gasket:
    It's very wet with coolant where I circled. Is it possible that the head gasket is leaking externally? No coolant is mixing with the oil and there's no smoke from the exhaust, so I don't think it's leaking internally.
    Looking in from driver's side wheel well:
    Stumped on this one. Leak just started about 2 days ago, before then everything was fine. Just replaced basically the entire cooling system; rad, hoses, thermostat, and coolant a few months ago. I'm thinking it's either the freeze plug(s) on the back of the engine, head gasket leaking externally, or one of the coolant lines closer to the intake that I can't see. Any help would be appreciated.
  11. Mar 26, 2019 at 1:37 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I had a great winter, looking forward to the next, if everything goes to plan it should be a ball
  12. Mar 26, 2019 at 1:43 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Thanks. Looks like it's time to bribe my diesel mechanic buddy with a handle of liquor. ;)
    Reh5108[QUOTED] and vonellis like this.
  13. Mar 26, 2019 at 2:40 PM
    vonellis
    Some and some more
    Yes sir definitely a one off.
  14. Mar 26, 2019 at 5:15 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Just got home and the brown truck left me some presents. Took a little longer than I hoped, but the stainless Budbuilt skids have finally arrived...
    Now I need to find some time to get the stock skid mounting brackets beefed up and get these 4xInnovations sliders installed.
  15. Mar 26, 2019 at 5:23 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    FLBAdrian likes this.
  16. Mar 26, 2019 at 6:27 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Repaired an issue with my driver side rear lamp one of my 95 models. Someone I know was following me a few days ago. When I had the brake pedal pressed (brake lights on) and hit the LH turn signal, brake light got weak and backup light started flashing, also weak. No turn signal.
    If you've ever had your rear lights apart, you pretty much know the moral of this story. All 3 lights share a single ground. Not only do the sockets rust, if one ground connection to a socket gets weak, it pulls form the others. In this case, the socket and grnd for the B/U lamp was really corroded. Cleaned everything, including the W/H connector prongs from the grnd, and all is well.
  17. Mar 26, 2019 at 7:16 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Who says there's no place to put switches in a 1st gen? :D
  18. Mar 26, 2019 at 7:21 PM
    JKO1998
    Utah
    Boy oh boy, look at all those over land points
    Yetimetchkangmi and JasonLee like this.
  19. Mar 26, 2019 at 7:27 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Expedition as fuck, as fuck, and such.
  20. Mar 26, 2019 at 7:28 PM
    JKO1998
    Utah
    But really, where’s the write up on the panel?
