  1. Apr 1, 2019 at 8:39 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I hit them with the hose and some dry lube tonight. I have looked at the driver side the other day, it’s fine and I have a passenger spindle on order so I’ll have eyes on the passenger side next week hopefully.
    JKO1998[QUOTED] likes this.
  2. Apr 1, 2019 at 9:03 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I’ve had cracks for years all the way through on both sides in that location, like 3 layers of sheet metal but still hasn’t busted all the way through on the bottom.
    I think I’m gonna do 2in .065 square tube and gusset the shit out of it to the rest of the core support for the new cross member the body mounts sit under
    It deserves saying I replaced the core support many years ago with aftermarket shit, lotta work and not enough invested in the parts
    Reh5108[QUOTED] likes this.
  3. Apr 1, 2019 at 9:07 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Just cut it all off and make a new one. :sawzall:
  4. Apr 1, 2019 at 9:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Seriously? Go with new OEM. Cry Once!
    lukester78 and GQ7227 like this.
  5. Apr 1, 2019 at 9:51 PM
    tony2018
    tony2018 Well-Known Member
  6. Apr 1, 2019 at 10:50 PM
    Laxtoy
    Maltby, WA
    I’ve thought about it, my inner fenders are all messed up too, bought it with rebuilt title. I thought of caging the front from the cab forward or bending up my own inner fenders but I can’t take the downtime, daily driver.
    I have a donar truck, plan to do a complete swap, my current bed is messed up too
  7. Apr 2, 2019 at 5:01 AM
    tony2018
    Do our transmissions also have the vin tag on them?
  8. Apr 2, 2019 at 7:12 AM
    Dan8906
    Daniel
    Concord, California
    So I think it did help a bit. Might need to actually need take the bolt out and clean it. Ill just hit it for a few days with lube until then and see if it goes away.
    eon_blue[QUOTED] likes this.
  9. Apr 2, 2019 at 8:15 AM
    eon_blue
    Azusa, CA
    Yeah lubing them worked for me for quite awhile...eventually when the sound keeps coming back more frequently you'll have to look into replacing the bearings but it's an easy job to DYI and Wheelers sells them
    Dan8906[QUOTED] likes this.
  10. Apr 2, 2019 at 8:17 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    https://www.jegs.com/i/QA1/122/COM10T/10002/-1
  11. Apr 2, 2019 at 9:05 AM
    Dan8906
    Daniel
    Concord, California
    I dont see any icon bearings at wheelers.
  12. Apr 2, 2019 at 9:15 AM
    970 Street Taco
    970 Street Taco Member
    Mark
    2004 White double cab 4x4
    Stock..... for now
    I just got the ToyTech lift. I went ahead and had them assemble them, it came with new bushing and all. The rear was an add a leaf..
    Overall, it was pretty easy and fast to install.
    tony2018 likes this.
  13. Apr 2, 2019 at 9:28 AM
    eon_blue
    Azusa, CA
    Unless Icon is different from King, Fox and the rest, they should just use the standard COM10 spherical bearings that the rest of the performance coilovers use. @JKO1998 linked some above. Wheelers carries them too.
    When you do decide to swap them out for new ones, you might want to get some new misalignment spacers as well (the little spacers that go on either side of the bearing). I ended up just reusing my original ones but sometimes they can get damaged I guess. Mine were just dirty. Those I had to order from 4WP but they sent me the wrong ones, but luckily my old ones were still good to use.
  14. Apr 2, 2019 at 9:35 AM
    JKO1998
    Utah
  15. Apr 2, 2019 at 9:38 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm pretty sure it was 01 - 06
    I'm positive 02 - 05 calipers are 13WL
  16. Apr 2, 2019 at 9:41 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Not all 1st gen Tundras. The early Tundras were 199mm and had problems with warping. The 231mm 13WL is the fix for the undersized early rotors.
    The 199mm was 13WS or 13WG or something like that. Can't remember off the top of my head.
    m3bassman[QUOTED] likes this.
  17. Apr 2, 2019 at 10:28 AM
    Dan8906
    Daniel
    Concord, California
    Oh ok sweet. Just ordered a set. for $8 why not lol
  18. Apr 2, 2019 at 11:17 AM
    eon_blue
    Azusa, CA
    expo points +10
    Going to the sand dunes this weekend by myself and figure these might come in handy, ordered a cheap knock-off set off Amazon so hopefully they hold up. Couldn't really justify the $350 that Maxtrax wants for their's so knockoffs it is.
  19. Apr 2, 2019 at 11:27 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Nice maxipads! I have yet to use mine for anything other than leveling out my RTT
  20. Apr 2, 2019 at 11:29 AM
    eon_blue
    Azusa, CA
    Haha 'maxipads', I like that.
    Yeah I haven't pulled the trigger on any for this long because I've never really been in a situation where I'd need them, I rarely wheel in mud but I did find myself in a few snow/ice situations this season where they may have come in handy. But in the sand dunes I can definitely see where I might need them especially since I'm going solo this time.
    Plus I usually have to find and stack rocks to level out the RTT when we camp so they'll at least come in handy for that like you said.
    BYJOSHCOOK[QUOTED] likes this.
