  1. Apr 2, 2019 at 2:42 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I have yet to see traction boards perform well in the snow. They usually just ended up just getting kicked out if your wet snowy tire even grips them.
    Am I the only one that uses a hi-lift to level my truck?
  2. Apr 2, 2019 at 2:43 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They sell a rebuild kit for the pump, seals should be included in that. It's all bolt together type stuff nothing super complicated.
  3. Apr 2, 2019 at 2:44 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Cool thanks once I get off work I'll look up the part number.
  4. Apr 2, 2019 at 2:46 PM
    Speedytech7
  5. Apr 2, 2019 at 2:46 PM
    Reh5108
    Idaho
    I found it pretty easy to take apart. If you can find a new seal I don't see any reason why you couldn't fix it. In the fsm there are specs for the pump fins you may want to check. Mine were all good with 250k miles on them.
  6. Apr 2, 2019 at 2:53 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Found a used on online for $64. not to shabby.
  7. Apr 2, 2019 at 2:55 PM
    eon_blue
    Azusa, CA
    yeah I figured they'd be iffy in snow at best, I did try using a friend's traction boards in the snow once and it didn't work well at all. I suspect I'll mostly only need them in recovery circumstances when I'm in sand, or the off chance I get stuck in mud even though I avoid mud like the plague.
    You use the hi-lift to level the truck overnight while you're sleeping in the RTT? I'd be afraid it would drop and scare the ever living shit out of me haha.
    I've never had my hi-lift drop on me but I have seen a friend's drop his truck once when we were using it to change out a spare, luckily it happened almost right away so no one was around it. He admitted he rarely ever oiled it though, I keep mine oiled every time I use it.
  8. Apr 2, 2019 at 3:23 PM
    Reh5108
    Idaho
    I've never had an issue with one. As long as the pin is all the way in its not going to randomly drop. If it does the Kings will gently let me down lol.
    jubei and eon_blue[QUOTED] like this.
  9. Apr 2, 2019 at 3:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Here is the part numbers:
    Pads 04465-35290
    Shim kit 04945-0c030,
    He's wrong, you're right. :p
    Rldanie and eon_blue like this.
  10. Apr 2, 2019 at 3:44 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I have self doubts, when people question me my confidence plummets.
    I really am a member of Gen X, shit.
  11. Apr 2, 2019 at 5:47 PM
    Dan8906
    Daniel
    Concord, California
    Were you able to reuse the retainer clips or do I need to get those too? If so where did you get those ?
  12. Apr 2, 2019 at 5:50 PM
    eon_blue
    Azusa, CA
    Wheelers called me and recommended I get those too so I did, but the ones they send aren't the same kind of snap rings that were on my Kings (didn't have the little holes on the ends to use the snap ring pliers with) so I just ended up reusing my original ones. They were still fine just dirty.
  13. Apr 2, 2019 at 5:58 PM
    eon_blue
    Azusa, CA
    Btw I fought with my drivers side coilover in a bench vise for an hour trying to press the bearing out and the new one in, before I realized I could just knock it out by putting a med size socket on the face of the bearing and tapping it out with a hammer. Got the new ones in that way too and it's a lot easier than trying to hold the coilover in the vise while pressing the bearing out with a socket.
    Dan8906 and Speedytech7 like this.
  14. Apr 2, 2019 at 6:01 PM
    Speedytech7
    Then you're good you don't need more shims
  15. Apr 2, 2019 at 6:13 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Oem pads? If not, then you likely dont need shims.
    m3bassman[QUOTED] likes this.
  16. Apr 2, 2019 at 6:14 PM
    JKO1998
    Utah
    Looks at Napa box in the back* :)
    Blue92[QUOTED] likes this.
  17. Apr 2, 2019 at 6:15 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Eclipse is the caliper type. My akebono pads looks just like that.
  18. Apr 2, 2019 at 6:17 PM
    JKO1998
    Utah
    I just figured Oem pads would say Toyota or something, red and white box.
    But I’m too poor for that shit so I dunno
  19. Apr 2, 2019 at 6:25 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Reminds me when we to the dunes and used all 3 sets.
    eon_blue[QUOTED] likes this.
  20. Apr 2, 2019 at 6:29 PM
    Speedytech7
    Some pads actually use one thin serrated shim and one thicker solid shim. Toyota OEM pads don't come with shims so you have to put them on, aftermarket pads usually come with shims so you don't have to worry about it
