  1. Apr 9, 2019 at 2:51 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    My tall skinny’s were 500+Utah tax
    eon_blue[QUOTED] likes this.
  2. Apr 9, 2019 at 5:42 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Okay I know theres tons info out there which is better but it's back and forth. I also know this isnt really the place to ask, but people with aftermarket lockers past or present which do you prefer and why. A electric locker or a air locker? I plan on installing a compressor for onboard air so that additional cost doesnt bother me.
  3. Apr 9, 2019 at 6:28 PM
    therealbhump
    therealbhump Member
    I put Monroe complete struts on my truck today. Did the rear shocks last week. With the worn out suspension replaced I’m sitting about 1/2 inch higher. Anyone considering doing the replacement for stock ride height equipment, be confident it’s a pretty straightforward job.
    burntkat likes this.
  4. Apr 9, 2019 at 6:59 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    I prefer the elocker. You can either get the Toyota one or go for one of the aftermarket elockers. Harrop is supposed to be very good.
  5. Apr 9, 2019 at 7:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Which electric locker we talking?
    The 8.4 diff is stronger than the Toyota diff due to design. Adding an arb to it makes it even stronger.
    Air lockers can leak air though. And lines can break.
    Top of the line is the electric Harrop locker for the 8.4. few nice features that make it better than the arb. If I could do it again I'd do dual harrops. However they cost an arm and a leg.
    Can't go wrong with either though really .
    The Toyota elocker isn't always instant on, the actuator can die from mother nature induced problems. But they are not bad. If you don't have one with the truck from factory I wouldn't pay over 300 for a elocker axle. Might as well get one of the other options with the strong 8.4 diff.
    Which is worth mentioning, you can not swap a factory elocker into a non locker axle. Not without major modifications to the axle.
    There's a nice summary for you
  6. Apr 9, 2019 at 7:13 PM
    1st4x4
    sam
    Torrance
    I swapped in a tundra axle and had to lose out on the elocker found a arb rd129 for 500 bucks and already plan on adding onboard air
    I have the 8.4 I swapped a tundra axle into my truck hardly ever used the elocker that came stock in my truck but like having it just incase its needed found a arb for 500 just not sure if I should do it. A friend is trying to get me to buy a truetrac as that's what he runs and loves it.
  7. Apr 9, 2019 at 7:24 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Love my pro's so far! 900 mounted and balanced! Not bad
    SwampYota[QUOTED] likes this.
  8. Apr 9, 2019 at 7:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I got mine for 450. Well worth it.
    I'd do the arb. Selectable is great
  9. Apr 9, 2019 at 7:31 PM
    cbassd
    cbassd Member
    sebastian
    Nor cal Davis
    02 tacoma
    tc uca, 2.5 icon coilovers with resis, trd supercharger,flow master,u-bolt flip kit,,, all-pro standard pack leaf springs,10 inch travel 2.0 fox shocks with remote resis,21inch led bar,ham and cb radio,4xinnovation sliders, custom from bumper, prp bucket seats and deist 5-point harness
    Got some tube doors for the taco
  10. Apr 9, 2019 at 8:13 PM
    1st4x4
    sam
    Torrance
    Did you do the install yourself? I'm mechanically inclined but not sure I'd be able to do this even tho it looks simple.
  11. Apr 9, 2019 at 8:27 PM
    eon_blue
    Azusa, CA
    The Detroit TrueTrac is a mechanical limited slip not a locker, a locker is much better offroad if that's what you want it for.
    Detroit does make a lunchbox locker too but selectable lockers are far better than auto lockers imo
    1st4x4[QUOTED] likes this.
  12. Apr 9, 2019 at 8:36 PM
    1st4x4
    sam
    Torrance
    My friend is supposed to pick up the arb for me tonight but he falls threw with alot of things so hopefully he doesnt with this. If he does and the guy doesnt sale it I pick it up Saturday. Said fuck it for new and half price I can resale it if i dont like or use it. But I'm already trying to find a shop to install it. Going to call my transmission shop in the am and see what they say for the install
  13. Apr 9, 2019 at 8:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah I did.
    You can probably do your own rear diff. The front I would NOT recommend doing yourself.
    It's a bit of a pain to do the rear on the 8.4 as the master kits come with worthless "shims" to help place the ring gear. So really the only way to do it, is to put it back to stock and the check the wear. It'll be off. Then you have to guess how much further you'd want to move it and order what Toyota calls "washer plates" which are the actual shims. Not very cheap either. I order what I thought would be perfect then also got a set the next size up and down. You order 6 total plates as you need them both to offset the ring gear so if you need it to move left you get a smaller one on one side and larger on the other.
    Doing this means the truck is down for longer than you'd like as you have no idea what the plates are you need until you take it a part and measure. So its a pain.
    Also Toyota diffs are super picky about how they are set so if you fuck up a little bit..in 5-20k...boom
  14. Apr 9, 2019 at 9:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You'll feel that weight right away and likely take an MPG hit.
    Not sure what your previous wheel/tire combo were and how it compares, but I went from 33x10.5-15s on steelies to 285/75-16s on SCS wheels. Both are very similar in diameter but the Pro's with the Ray10s outweigh the BFG KM2s on D Windowed steelies by 11 lbs apiece. Makes a huge difference on pavement. I lost 2-3 MPGs depending on how much city stop and go there is.
  15. Apr 9, 2019 at 9:04 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Only got one side done tonight, still hear a creaking popping ish noise hopefully after I do the next side it clears it up.70E067BB-2656-484B-8A55-69DFF0598657.jpg
  16. Apr 9, 2019 at 9:12 PM
    eon_blue
    Azusa, CA
    Can you tell which side it's coming from? Mine was pretty easy to tell since one was making a lot more noise than the other. Hopefully you'll get rid of it when you do the other side but it might end up being your UCAs making the noise especially if you only hear it on turns. My spherical bearings were mostly noisy going straight especially during stop and go.
  17. Apr 9, 2019 at 9:12 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm pretty sure my arb is beginning to leak air again for the 2nd time in the 4 years it's been installed. If I had the cash to ditch it and go with Harrop I would.
  18. Apr 9, 2019 at 9:14 PM
    eon_blue
    Azusa, CA
    In the Harrop thread on here I've been reading that people have been having issues with the Harrop lockers disengaging when the truck rolls backward, does that happen with the ARBs? I've never had that happen with my TRD elocker, seems like something that would become really annoying.
  19. Apr 9, 2019 at 9:15 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Ok not specifically Tacoma, but somewhat related ...
    After getting a call from my stranded son, headed out of work an hour early. BLUF, dead battery and alternator. Oh FML. Well, my truck, my problem, til I sign it over to him. There went 300. Took about 2 hours, luckily it stranded him at work.... Oreilly.
    Got home, washed up (because of course this happened in the rain) and settled down. Went to make the battery cables for my truck, found my solder pot dead. Brand new, too. Took it apart and found some piss poor solder joints and a blown fuse. Of course a kind of fuse I don't stock. Wired around that for testing, reflowed the joints, all good to go. Which brings us to now.. after midnight and I just realized I haven't eaten since lunch, nor taken my meds. That in itself is kind of an indicator of how crazy things got after work.
  20. Apr 9, 2019 at 9:17 PM
    Dan8906
    Daniel
    Concord, California
    It’s been over a year since I’ve greased my UCAs. I’ll hit those tomorrow.
