  1. Apr 16, 2019 at 1:32 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm assuming it involves removing headlight and grill... ugh... I just installed those damn things lol
  2. Apr 16, 2019 at 1:34 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Just grill, filler panel and maybe the side marker
  3. Apr 16, 2019 at 1:35 PM
    eon_blue
    Azusa, CA
    I didn't remove the grill or the headlight. The corner light yes, but that just comes right off.
    I'm sure it would be much easier to put back into place if you remove those other parts but you don't need to.
  4. Apr 16, 2019 at 1:36 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    My sidemarkers and headlights are one piece... sounds like I should have thought this out better lol
  5. Apr 16, 2019 at 1:37 PM
    JKO1998
    Utah
    Hmm, I thought there was a bolt under the filler.
    But it has been A year and a half since I took mine off so
  6. Apr 16, 2019 at 1:38 PM
    eon_blue
    Azusa, CA
    In that case you might have to remove those and the grill, I don't know how the grill and headlights work with one another. But all I had to do was take the bolts for the fender the off and yank the fender out. Putting it back on was a little tricky but I got it done in maybe 30 minutes.
    I nearly decided to remove the grill because I was having a hard time working it into place, but I eventually got it to go in.
    JKO1998[QUOTED] likes this.
  7. Apr 16, 2019 at 1:48 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    Not sure if it matters, but isn’t your 4banger a 2.7l, that one says 2.4l on the bag.
    Congrats on the supercharger btw
    :burnrubber:
  8. Apr 16, 2019 at 2:10 PM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Yeah they do. Oh my vacuum cleaner did amazing, although it’s about 5-10lbs heavier now with all the glass inside
    Blue92 and m3bassman[QUOTED] like this.
  9. Apr 16, 2019 at 2:39 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    2RZ and 3RZ are pretty much identical in exception of the bore.
    I figured it out, brought my manifold to a local Toyota dealer and the gasket I have is for the exhaust end of the EGR pipe pipe. I picked up the proper one for the EGR body.
    $10 too... damn stealership.
    Here’s the part number for anyone who needs it.
    2CBA5498-9DC0-4DCA-95AE-BC741EBA4F7C.jpg 556F3ADF-5633-432A-B606-C1B245BA758A.jpg
    Additionally, just dropped off the manifold at a local machine shop. I’m having the two EGR stud holes re-welded, machined, and re-rapped along with a jetwash. $110 for that, not bad.
    Captain Magma[QUOTED] likes this.
  10. Apr 16, 2019 at 2:44 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    How long do the lower bearings on shocks last? The little metallic balls the lower bolt goes thru I can’t remember the actual name
  11. Apr 16, 2019 at 2:49 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    1 wheeling season for me.
    Spherical bearings - COM10T is the part number for most applications.
  12. Apr 16, 2019 at 3:22 PM
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    Been a busy two days.
    Now to try and sleep before my one month old son gets set off again
    sandsloth, chrslefty, jammer and 6 others like this.
  13. Apr 16, 2019 at 4:28 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    shockseals.com has them. @Squeaky Penguin said the part number already.
    I bought a couple sets of seals from them for bypass shocks as recommended by a rebuilder on here and one of these days I'll try to write up the rebuild.
    BYJOSHCOOK[QUOTED] likes this.
  14. Apr 16, 2019 at 4:35 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    So back in April of last year, I ordered retro (89-95) tailgate graphics. Finally put them on today. :smack: excellent quality, satisfied with the results.
    graphics were ordered from http://jamesdeancreations.com/pretacomalogos.htm although, if I had known about @CBoy808 back when I ordered these, I would've ordered from him.
    Phessor, chrslefty, SwampYota and 5 others like this.
  15. Apr 16, 2019 at 4:36 PM
    Area51Runner
    every two hours brother, every two hours... enjoy! :annoyed:
    congrats!
    MedicMutt[QUOTED] likes this.
  16. Apr 16, 2019 at 4:40 PM
    eon_blue
    Azusa, CA
    Those are spherical bearings, Wheelers sells them and a lot of other places too. I got about 20k out of the ones on my Kings before they started making so much noise I needed to replace them. Easy enough to do and cheap. Hitting them with dry lube helps quiet them down but after awhile they need replacing.
  17. Apr 16, 2019 at 5:17 PM
    JKO1998
    Utah
    If you feel like they need replaced they aren’t hard to do, and if you go too long without repacking you could end up with a much bigger bill
  18. Apr 16, 2019 at 5:29 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    @BartMaster1234 how much did you pay for that SC? Was it local or on here. CBA paying 3500xx for a new one.
  19. Apr 16, 2019 at 5:35 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I paid around $2,000 for it with a brand new AEM Methanol Injection kit. Bought it from a member on here through a private deal.
    Not a good deal, not a bad deal. However the original TRD superchargers for the 3RZ are stupid rare, they were made by Alpine for TRD for only a few years before they were discontinued. For every twenty five v6 superchargers, there is one I4 supercharger. You can still buy TRD stamped I4 SC's from LC Engineering.
    Considering the rarity of an original SC I think what I paid is perfectly fair and competitively priced with the market.
  20. Apr 16, 2019 at 5:36 PM
    Sebz13
    Shane
    Maui Hawaii
    I'm really curious to as if you like it, I've also been trying to keep an eye, but I think I will end up paying the piper.
    Something about a SC makes me giddy with joy.
    It would be the LC kit if I do buy one.
    BartMaster1234 likes this.
