  1. Apr 21, 2019 at 3:49 PM
    1997tacomav6
    Denver
    Anyways got new nerf bars yesterday and OF COURSE the new bars don’t have Factory
    type welded on brackets, so I guess the gas torch and welder get to be used the next few days cutting
    old brackets off and welding them on the new bars.
    SwampYota and CS_AR like this.
  2. Apr 21, 2019 at 3:55 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Why don't you just weld on some sliders
    Silver02Taco, CS_AR and Area51Runner like this.
  3. Apr 21, 2019 at 3:56 PM
    1997tacomav6
    Denver
    Hindsight, probably should have
    Area51Runner likes this.
  4. Apr 21, 2019 at 3:57 PM
    tony2018
    tony2018 Well-Known Member
    Well, thats lame as fuck...
  5. Apr 21, 2019 at 3:57 PM
    1st4x4
    sam
    Torrance
    See if you can return those say you thought they came with the mounts
  6. Apr 21, 2019 at 4:02 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Its just a bearing. As long as its from a reputable source (NSK, Koyo, FAG, SKF, Timken) it should last just as long as oem, which is probably one of those. That exedy kit is quality so I wouldnt have any issue over installing one.
  7. Apr 21, 2019 at 4:19 PM
    1997tacomav6
    Denver
    I probably should have gotten that kit,
    I did the rear main seal and both the input shaft seals front and back on the transmission along with a new rubber transmission mount while it was out
  8. Apr 21, 2019 at 4:23 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    How's that new clutch feeling? Hope it's better than before
  9. Apr 21, 2019 at 4:36 PM
    1997tacomav6
    Denver
    Speedytech7 likes this.
  10. Apr 21, 2019 at 5:06 PM
    firstgentacotuesday
    firstgentacotuesday Well-Known Member
    CA
    ‘01 3.4 4x4
  11. Apr 21, 2019 at 5:13 PM
    Speedytech7
    SwampYota, fiziks and lukester78 like this.
  12. Apr 21, 2019 at 6:08 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    1997tacomav6[QUOTED] likes this.
  13. Apr 21, 2019 at 6:51 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    replaced tired ass dakars with the new hotness dakars with AAL - gained about 3" on shock shafts.
    tony2018 likes this.
  14. Apr 21, 2019 at 7:14 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Reaplaced the gear oil in the trans and t case. It was long overdue, especially the trans. Also painted the sliders. Lots more work to do.
    Next up is engine oil and filter, and drivers side axle seal.
  15. Apr 21, 2019 at 7:17 PM
    eon_blue
    Azusa, CA
    You're more careful than I am painting my sliders...I just hold a piece of cardboard up while I go down lol. Looks really clean though
    CS_AR, CrustyTaco and Fernando like this.
  16. Apr 21, 2019 at 7:22 PM
    1997tacomav6
    Denver
    Did you weld the sliders to the frame?
    CS_AR likes this.
  17. Apr 21, 2019 at 7:24 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Same. Just did it today...hella over spray...lol
    CS_AR likes this.
  18. Apr 21, 2019 at 7:24 PM
    Phessor
    Phessor Well-Known Member
    Quite the rock sample collection you have there!
  19. Apr 21, 2019 at 7:25 PM
    eon_blue
    Azusa, CA
    I did it during a windstorm out here too, not fun. Managed to not get any on the truck but probably breathed in too much of it.
  20. Apr 21, 2019 at 7:28 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Finally got to install my El Taco Diablo light bar brackets. They've been hanging above my shop bench for nearly 2 years.
    Also got a light bar cover... to keep from giving poe-poe a reason for pulling me over. (yes, uncovered lightbars are technically illegal in CA)
    burntkat, CS_AR, Area51Runner and 3 others like this.
