  1. May 1, 2019 at 9:37 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Oh.
    I doubt it. Looking at pictures, the length of the overall bearing is off. Besides, my suspension doesnt articulate enough to warrant an inner C/V.
  2. May 1, 2019 at 9:37 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    Soldered up some 100 Ohm 3W resistors for the map and dome lights.
    SwampYota likes this.
  3. May 1, 2019 at 9:39 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I don't think it will work. And not needed unless your inner's are binding. With my extended travel kings, mine don't bind :notsure:
    Check out the pics here: Will need a slightly longer shaft to work as far as I can tell.
    https://www.offroadsolutions.com/tech-info/high-angle-cv-boot-kit/
  4. May 1, 2019 at 9:47 AM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    3.5 kit has every advantage over the +2 kit including cost and cv simplicity
    Trim taco[QUOTED] likes this.
  5. May 1, 2019 at 9:56 AM
    eon_blue
    Azusa, CA
    So...best way to bend a 3/16" skid back into place? Took my Budbilt IFS off the other day to do an oil change and the effing thing is twisted in the back portion where it mounts under the steering rack.
    Something tells me this isn't a job for a BFH
  6. May 1, 2019 at 9:58 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Pyrifera likes this.
  7. May 1, 2019 at 10:01 AM
    eon_blue
    Azusa, CA
    If it were a dent, yeah...but the back is twisted, I don't see how a hammer is going to untwist steel. But I guess I'll have to try to find out lol.
  8. May 1, 2019 at 10:04 AM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Maybe prop it somewhere and drive on top of it slightly to try to bend back? :rofl:
    I know it’s a tight fit right there but you could use longer screws and tighten it with both sides, then use a jack to keep the skid in place while exchanging the long bolts for the normal shorter ones... that’s what I had to do every time installing my relentless skids :anonymous:
    eon_blue[QUOTED] likes this.
  9. May 1, 2019 at 10:04 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Our trucks are old, face that fact. Why would companies develop new products for these trucks when the demand is already low for the already existing kits, as compared to a kit for a 2nd or 3rd gen?
    m3bassman likes this.
  10. May 1, 2019 at 10:05 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Acetylene+O2+sparks
    Adude and eon_blue[QUOTED] like this.
  11. May 1, 2019 at 10:07 AM
    eon_blue
    Azusa, CA
    Actually that's not a bad idea, I think I may have twisted it myself by using it as a floor jack point in the wrong area once (too far back). I'll have to crawl under and see if the mount for the skid under the steering rack is bent too, I'm guessing it probably is
    snowboard704[QUOTED] likes this.
  12. May 1, 2019 at 10:10 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah I think it would have been cool if done well. Really the only reason there is a +2 kit is some race standard that Total chaos entered and then everyone else followed.
    I love my +3.5 kit though. Its amazing how awesome it handles. The width has stopped me a few times, but not often.
    Im not sure it is worth it or not. I can say when my front diff locked up at 45 mph after catching air...the CVs are fine..haha Good enough for me!
    Yeah I doubt you'd gain anything in terms of travel. Usually the Upper ball joint is the main culprit to limiting travel.
  13. May 1, 2019 at 10:32 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah it wouldn’t be for more travel, would purely be for any additional strength of the joint.
    Might just try it for the hell of it.
  14. May 1, 2019 at 10:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Can't hurt for 35s
    drr[QUOTED] likes this.
  15. May 1, 2019 at 10:47 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    But its the outer race that always fails on these trucks. The inner joint looks much less susceptable to failure IMHO.
  16. May 1, 2019 at 10:48 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Got me some parts from Gunny to prep for my Supercharger install and top end refresh. I also will be ditching the K&N.
    jammer, CS_AR, OneWheelPeel and 4 others like this.
  17. May 1, 2019 at 11:09 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Bravo, much better than what I did by cutting the wires. I love the jumper idea.
    A BFH over and over and over. That's how I adjust mine. Though I am getting to the point where the IFS needs to just get replaced soon.
    There was a guy in one of the 1st gen fb groups running 37's on IFS. I was amazed and was wondering how he wasn't snapping cv's left and right and he said he's using the tundy cv's with LT.
    Not always.
    [​IMG]IMG_1177 by Michael Halat, on Flickr
    [​IMG]IMG_1927 by Michael Halat, on Flickr
    [​IMG]Untitled by Michael Halat, on Flickr
    CS_AR and SwampYota like this.
  18. May 1, 2019 at 11:12 AM
    eon_blue
    Azusa, CA
  19. May 1, 2019 at 11:13 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    ^ but that's the axel that failed, not the joint itself. Unless that trifold joint is putting additional stress on the axel that a C/V wouldnt...
    Eitherway, the Tundra CV joint is a bit shorter than the trifold joint so I'm not sure the stock axel length will work with it :notsure:
    If someone ships me a Tundra C/V I'll be willing to test it out :D Need to rebuild my stock CVs anyways.
  20. May 1, 2019 at 11:18 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
