  1. May 6, 2019 at 6:48 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    I was lucky and found it on OfferUp and let’s just say the price was way too good to pass up. Brand new too :)
    That’s the only reason I’m running a 12k winch, which is overkill for my setup. I would of been happy with an 8k, even 10k.
  2. May 6, 2019 at 6:52 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    I actually like that front end/headlight style better. Do you know if a conversion can be done for the 01-04 model?
    FLBAdrian[QUOTED] and GQ7227 like this.
  3. May 6, 2019 at 7:13 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Yea you can convert them I had found a thread about it one time. From what I remember it was getting all the front like headlights, grille, bumper and lower. Also the hood, and some trimming.
    GQ7227 and TacoJohn4x4[QUOTED] like this.
  4. May 6, 2019 at 7:16 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Trust me, I've seen worse at Costco. That isn't half bad. My buddy works at my local one and tells me all the horror stories of what people do to take furniture home.
  5. May 6, 2019 at 7:18 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Anything vacuum related usually leads to the gas cap and evap system. I've fixed "large vacuum leak" codes on a Scion tC, an E320, and a Dodge Caravan just by changing the gas cap. Something to do with the rubber seals or something.
  6. May 6, 2019 at 7:21 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Local sale for me ksl told the dude 12k was more than i was looking for and willing to pay for . He went for it.
  7. May 6, 2019 at 8:23 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you guys have pre-drilled mounting holes in your winch plate in your bumpers, might want to verify your winch plate can handle the winches you bought. Some 12K winches have different mounting (further apart) points from 8k-10K winches.
  8. May 6, 2019 at 8:30 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This makes sense. I had read about the P0446 code being emission systems related. IIRC, the reference was to a vent control circuit malfunction of the evaporative emissions control system.
    I got this code a few weeks ago and cleared it with the scangauge. So far it has not come back.
  9. May 6, 2019 at 8:33 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Gas cap is a good place to start. It's solved most, if not all the vacuum related codes I've had.
  10. May 6, 2019 at 9:05 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Smittybilt XO 10k winch is the same dimensions as their 12k winch. The difference is in their gearing ratio. I already have it mounted to my AllPro Apex Bumper.
    I looked at their spec sheet and verified before I did the purchase.
    Digiratus[QUOTED] likes this.
  11. May 6, 2019 at 9:10 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Yea, this blows my mind. People would come in a sedan expecting to pickup furniture.
    I even had a guy come in a Camry to pickup my oem front bumper. Where’s the logic in that I don’t know, obviously they don’t either.
  12. May 6, 2019 at 9:12 PM
    chuckers
    chuckers Well-Known Member
    Chuck!
    Sneads Ferry, NC
    2004 Tacoma 4 door TRD Off Road
    Ill put pics in my build thread tomorrow with a wiring description. The seats were from a wrecked truck for 70 bucks, wiring was pretty simple and the holes mostly lined up. The comfort on the new seats is worlds better
    vonellis[QUOTED] and Seagull233 like this.
  13. May 7, 2019 at 6:27 AM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    TacoJohn4x4[QUOTED] and GQ7227 like this.
  14. May 7, 2019 at 7:01 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    snazzy looking white valence panel (can't recall if I have ever seen something like that before), did you paint it to match the white?
    are those rock chips on the hood :confused:
    FLBAdrian[QUOTED] likes this.
  15. May 7, 2019 at 7:05 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    You can fit a surprising amount of stuff in a sedan with the back seat folded down. My Accord will fit a bunch of 8ft 2x4s with the trunk closed and backseat down.
  16. May 7, 2019 at 7:36 AM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
    Yeah I got some color match spray cans to paint it. Sadly they are rock chips :( that’s how I got it when I bought it 2 years ago.
    GQ7227[QUOTED] likes this.
  17. May 7, 2019 at 7:41 AM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
    Where did you order this from?
  18. May 7, 2019 at 8:13 AM
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Lol I bet
    I laid down the mattress in the crowded aisle to get a good test and rest before purchase - people definitely were lookin' at me like I was nuts or something.
  19. May 7, 2019 at 8:20 AM
    vonellis
    Some and some more
    Local sale
  20. May 7, 2019 at 10:37 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    anyone running the wheelers HD greasable shackles? thinking about replacing my stock ones.
