  1. May 9, 2019 at 1:22 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    No they don't.
    It doesn't say "No offroad use" anywhere on their page. It says "2wd Only Please verify height" because the 4x radiator is a different size.
    They sell radiators for 4 runners, Land Cruisers, Tundras and Toyota Pick ups... one of the pick up models say it may ONLY fit 4wd and says to verify the neck position and overall width.
    You may have gotten a bad one. But there's probably 25 other people on TW that haven't had a problem. I've been running mine for over a year and the thing stays cooler than the OEM did when it was 2 years old (when I bought the truck)
  2. May 9, 2019 at 1:29 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Sorry, been in the WVa red clay mud, and only blasted off the big chunky crap. I painted mine with Rustoleum Bedliner. Those wet/oily looking spots are from last falls Fluid Film application.
    SwampYota and GQ7227[QUOTED] like this.
  3. May 9, 2019 at 1:35 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Damn!! That looks great. I didn't realize you could just fix the roof, the body shop I went to suggested I repainted the entire truck even though only the roof and hood had failing clearcoat. Something about blending issues since there is no hard body lines to mask it.
    How much did you pay if you don't mind me asking?
    01x4[QUOTED] and GQ7227 like this.
  4. May 9, 2019 at 1:37 PM
    tony2018
    tony2018 Well-Known Member
    Thats pretty good, how much they respray of clear coat cost you?
  5. May 9, 2019 at 1:38 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    No... the hole in the Tstat goes at 6 o'clock.
    That's what @Timmah! said, so thats what I did... I'm at 195° no matter what conditions.
  6. May 9, 2019 at 2:05 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Sorry man.
    Read the warranty
    Warranty will be voided under the following nonexclusive conditions:
    1. The vehicle is used for commercial or fleet, governmental, off-road or racing applications.
    So...just make sure you don't let them know you offroad! haha
    Running Board Man and Gen1FTMFW like this.
  7. May 9, 2019 at 2:15 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    0.5mm is unacceptable. I don't have a dial indicator to check but I'd guess it's closer to 1mm of play.
    eon_blue[QUOTED] likes this.
  8. May 9, 2019 at 3:18 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    https://www.youtube.com/watch?v=UvnqkAUxdgI
  9. May 9, 2019 at 3:35 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    It's very common to see that type of language in any Warranty, including products specifically for Off Road use.
  10. May 9, 2019 at 4:11 PM
    03dbprerunner
    03dbprerunner Well-Known Member
    Erik
    2003 dc taco
    King coilovers and 10" 2.5 smoothies in rear
    Just installed these spc control arms. wow they are amazing !!!
  11. May 9, 2019 at 6:14 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    About 45 bucks in sand paper, primer, paint and clear coat, from O'reillys. Re-painted my driver fender due to rotting clear coat. Doesn't match perfectly at certain angles and light conditions... but certainly came out good enough that I would definately do the roof before paying a shop.
    Didn't even remove the fender... just taped everything else off.
    GQ7227, CS_AR, jammer and 1 other person like this.
  12. May 9, 2019 at 8:45 PM
    eon_blue
    Azusa, CA
    So I attempted to adjust my SPCs tonight and ran into an issue I wasnt expecting...the camber getting thrown way off.
    I found it easy enough to adjust the caster, just jack the front end up, loosen the top bolt and turn the ball joint. Easy.
    The instructions make it sound like you can do either the camber or the caster independently, except as soon as you loosen the top nut, the ball joint also slides side to side freely and messes up the camber big time. I tried readjusting it after I got my caster where I wanted it, but when I put the truck back on the ground and my front tires looked like this \ / haha.
    Luckily I was able to put the whole setup back to the way it was before I messed with it...have an alignment tomorrow just in case.
    So are you just supposed to eyeball the camber when adjusting the caster with these? Then take it in and have a shop fine tune it? I don't see how you can adjust caster without messing with the camber as well.
    CS_AR likes this.
  13. May 9, 2019 at 9:07 PM
    Reh5108
    Idaho
    You can't, but you can adjust camber without adjusting castor. A bubble level would likely get you close enough. You'd need to account for the bulge in the bottom of the tire though.
  14. May 9, 2019 at 9:11 PM
    eon_blue
    Azusa, CA
    Makes sense, was difficult to keep my camber/caster settings in place when I went to torque down the top nut...soon as I started getting torque on it the whole thing would twist and slide. Had to try and hold the tire and ball joint in place while I was doing it lol.
    I gave up for the night since I have a trail run this weekend I didn't want to mess anything up. Gonna see if the offroad shop doing my alignment tomorrow can get it to where I wanted it.
  15. May 9, 2019 at 10:32 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Made it do some truck stuff. Changed out my tires ,I put on the super low mileage tires that I had bought before getting the F5's. 20190509_150143.jpg
    And I failed at picture taking .
    Also had code P0120 pop up. Looks like I'll be cleaning out my throttle body seeing as this is the second time its come up.
    CS_AR, Ace115, BYJOSHCOOK and 3 others like this.
  16. May 10, 2019 at 6:13 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Got the used tank for under $100.
    Afraid to check mine. But I should.
    GQ7227[QUOTED] likes this.
  17. May 10, 2019 at 7:59 AM
    tmswell
    tmswell Well-Known Member
    Bay Area, California
    2002 Tacoma TRD-OR DC 4x4
    chrslefty likes this.
  18. May 10, 2019 at 8:15 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    My passenger side CV boot ripped. So Ill be taking care of that today.
    Running Board Man likes this.
  19. May 10, 2019 at 8:41 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    But he's right, the f5s do look good.... I think I know where they came from
  20. May 10, 2019 at 8:59 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
