  1. May 12, 2019 at 10:05 AM
    1997tacomav6
    Denver
    Just make sure your AFR is correct when you get on the throttle
  2. May 12, 2019 at 10:06 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    How did you know what setting to put your injection system at?
  3. May 12, 2019 at 10:07 AM
    1997tacomav6
    Denver
    AFR you will monitor to see. Every engine is different for nozzle size to injection start time
  4. May 12, 2019 at 10:08 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Guess I’m going be driving the E320 around for a while, I’m supposed to be driving my truck back to San Francisco tonight haha. I only get to work on it on weekends.
    I have the AFR and Boost gauges plus the meth harness, but I need to plumb it into the truck.
  5. May 12, 2019 at 10:09 AM
    1997tacomav6
    Denver
    I started with a number 1 nozzle now Im at a 4 nozzle with my upgrades and starting at 4 pounds of boost up progressively
  6. May 12, 2019 at 10:10 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    How much boost are you making?
  7. May 12, 2019 at 10:11 AM
    1997tacomav6
    Denver
    10 pounds, porting dropped it a little which means I actually have more air flow more power with less boost
  8. May 12, 2019 at 10:14 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Good lord man. I’m happy to make 5.5 PSI.
  9. May 12, 2019 at 10:17 AM
    eon_blue
    Azusa, CA
    I'm sure the answer is 'duh' but I'm gonna ask anyway...Is it possible to ask an alignment shop to only adjust your steering wheel/tracking?
    Reason I ask is I paid $120 for an alignment recently and they finally got me perfect numbers, and of course after wheeling this weekend my steering wheel is now off to the left.
    I have a lifetime deal with Firestone that I rarely use because they generally suck at doing custom numbers, I'm wondering if I can take it to them (so I don't have to pay for it) and only have then fix my tracking/crooked steering wheel. I don't want them touching my caster numbers because they always put them within stock specs.
    I guess the safest thing to do would be to bring it back to the shop that just did it.
  10. May 12, 2019 at 10:19 AM
    1997tacomav6
    Denver
    Its a process getting more,
    1 pound of boost equals to about 10-12 extra horsepower
  11. May 12, 2019 at 10:20 AM
    eon_blue
    Azusa, CA
    I only make 6 (stock for the v6)...even after the 7th injector I didn't see the advertised "20% increase" or whatever it was supposed to add. I'm still on the stock pulley though
  12. May 12, 2019 at 10:22 AM
    1997tacomav6
    Denver
    I found a Firestone shop with a new alignment machine and my alignments have been dead on perfect now with them
  13. May 12, 2019 at 10:25 AM
    eon_blue
    Azusa, CA
    Its always the caster they screw up for me, I need 3 degrees to clear my larger tiresbut they always put it between 1 and 1.5 since that's technically in the green...3 is in the red according to Toyota specs. But I rub under 3.
    I'll just take it back to the shop that did it and hope it doesn't cost me another $120. I trust Firestone out here like I trust a sushi restaurant in the middle of the desert
  14. May 12, 2019 at 10:25 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    It’s harder for me since I’m in California. I have the URD High Boost pulley, and what I did was sandblast the red anodizing, bondo’d away the ID engravings, and painted it black so it looks stock.
    JasonLee and FLBAdrian like this.
  15. May 12, 2019 at 10:28 AM
    1997tacomav6
    Denver
    If u have a smaller pulley just be careful to make sure your AFR are perfect with fuel management or you will destroy the motor
    In a New York second
  16. May 12, 2019 at 10:30 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s concerning... haha. I’m running the 2001-2004 pink injectors too which deliver fuel differently than the stock ones.
    I’ve been running 91 for the past two weeks so it flushed the 87 out of the system.
  17. May 12, 2019 at 10:33 AM
    eon_blue
    Azusa, CA
    You might be fine then with just the larger pink injectors...I don't know if adding methanol will make you run rich though like the 7th injector would since its spraying fuel.
    If anything you'll be running rich which isn't nearly as bad as running too lean...too lean is what you really want to look out for but too rich isn't good either.
    1997tacomav6 likes this.
  18. May 12, 2019 at 10:34 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I “ran lean” every three weeks because the K&N would coat the MAF with soot and told the ECU it was lean.
    So I got rid of it.
    Think I’m going to order the snorkel. :anonymous:
  19. May 12, 2019 at 10:37 AM
    eon_blue
    Azusa, CA
    Well yeah getting rid that k&n crap was a good first step lol.
    When you do your test runs if you don't have an AFR gauge yet, back off the throttle immediately if you hear any pinging.
  20. May 12, 2019 at 10:38 AM
    1997tacomav6
    Denver
    That must have been a 4 banger issue.
    I have over 550k on my KN filter with zero issues
