  1. May 13, 2019 at 5:46 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    No clue, why?
  2. May 13, 2019 at 5:47 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I've changed mine and my Dad's through the fender opening. Just gotta make sure to break the lines loose before loosening the bracket. Not easy, but doable in 30 mins.
    I saw a guy recently say he took the lines loose from the first connection away from the filter and pulled the filter with lines still attached. Then all he had to do was remove the bracket bolt and snake the whole system out. I am going to investigate that next time (if there is a next time...).
  3. May 13, 2019 at 5:56 AM
    1997tacomav6
    Denver
    Was asking if the 4 bangers superchargers original owner had a 7th injection
  4. May 13, 2019 at 6:58 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    This. I'd just move a little east to somewhere in Nevada or similar. Only good wheeling spots are Off-road parks like AOP, Windrock and a few others. The rest is just fire service roads and really meh. But it is cheaper to live out here
  5. May 13, 2019 at 8:28 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Since nobody has looked up the details... I found it in 2 seconds.
    The methanol that’s added to lower the freezing point temperature is a volatile organic compound, and the [California] Air Resources Board [aka CARB] has banned premixed low-temperature fluid everywhere in California except where the temperature drops below freezing for extended periods, such as the Sierra Nevada. But concentrate can be sold anywhere in the state, and motorists can mix it themselves to make the low-temp stuff.
    So, in summary. Just go buy some concentrate. Mix it yourself.
    Read more here at the [California] Air Resources Board. @BartMaster1234
  6. May 13, 2019 at 8:39 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I plan on installing the reservoir there, and no I don’t think there was a fifth injector.
  7. May 13, 2019 at 8:40 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    There was a 5th injector kit by URD. Not sure if TRD made one or not..can't remember. Think there was but like the TRD 7th injector kit, basically impossible to find and didn't work well anyways.
    BartMaster1234 likes this.
  8. May 13, 2019 at 9:14 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It's by county if we have emissions or not.
    Read up on gadgets UTune to get an understanding of how the computer tunes itself. The bigger injectors won't help your afr in closed loop. The computer will see it as a rich condition and tune it out to see stoic. Open loop it should help though but I don't see my afr drop drastically until north of 4500rpms. Maybe the older ecus are different.
    How are you fitting two 100# dogs in an ex cab?
  9. May 13, 2019 at 9:20 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    in the 6' bed...
  10. May 13, 2019 at 11:20 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    :rofl:
  11. May 13, 2019 at 11:53 AM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Ya it's a hard choice to make I have family in kingsland ga that's why I'm contemplating moving out there. I'd go to Nevada or Arizona but the price of living isnt much different then it is in cali.
  12. May 13, 2019 at 11:58 AM
    Malek
    Malek Well-Known Member
    Malek
    Denver
    02 DC TRD
    1UZFE VVTi 5spd Swap
    Yesterday...but whatever..
    Integrated dash cam, backup cam, and rear view mirror
    cali04intx, Jiveydude, jubei and 6 others like this.
  13. May 13, 2019 at 12:09 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Well there's some good camping out here but that's about it. If you want trails best bet is to head up to TN
  14. May 13, 2019 at 12:10 PM
    eon_blue
    Azusa, CA
    I thought NV and especially AZ were supposed to be a lot cheaper than CA...but I'm sure the south is even less expensive.
  15. May 13, 2019 at 12:23 PM
    GoJo
    GoJo Well-Known Member
    Utah
    Busted out lower ball joints (originals has 145k :eek:, seemed to still be in good shape, will be keeping as trail spares), Oil Change, Tire rotation and got the RTT mounted back on the rack. Ready for camping/fishing season to begin!!! Hopefully be getting out here in the next couple of weekends
  16. May 13, 2019 at 12:25 PM
    GoJo
    Utah
    I am playing catch up in this thread, but I didn't see anyone respond to this. I to have a dash rattle that comes from the passenger side, but it doesn't just do it on start up, to "fix" the situation I just put in some 5/8" Backer rod between the windshield and dash across the whole length of the windshield. Should be able to pick that stuff up at Home Depot/Lowes/Walmart for pretty cheap
  17. May 13, 2019 at 12:39 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Got a link? Wondering if I could wire it on full time . I can barely see out the rear view.
    Yetimetchkangmi likes this.
  18. May 13, 2019 at 12:56 PM
    Malek
    Malek
    Denver
    02 DC TRD
    Nope. The camera is just has a wide/tall view. So you can adjust the view up and down from the touch screen itself.
    Here's a pic of the camera. Granted, it's a bit big and wasn't my first choice of location but I found it gives the best view and I can still open the tailgate if I spock the handle.
    I can't see shit out of my back window (dirt encrusted softtopper lol) Link Amazon had a lightning deal for it at 104 dollars. There are plenty others like it all over Amazon. But yeah, there's a hardwire kit you can get separately. I have 3 open cig lighters so I just routed it to one of them.
    SwampYota, jubei and vonellis[QUOTED] like this.
  19. May 13, 2019 at 1:04 PM
    1st4x4
    sam
    Torrance
    They are alot cheaper then AZ. But for a actual house it's pretty damn close to the same price as cali. If not it's a shitty neighborhood.
    It's hard to decide with the pros and cons. Cali are gets good offeoading.
    Going to the south you can find some good mud holes but I'd get something else for that. Plus the ability to hunt your own food in the south is a big bonus. My family that lives up there hasnt bought meat in years because they just go hunt for it instead as they own 67 acres in the middle of the boonies.
  20. May 13, 2019 at 1:06 PM
    eon_blue
    Azusa, CA
    Good wheeling is definitely a requirement for me when we finally get out of CA, so I'm staying west if possible. Or north, just not east or midwest...I can barely stand the mud we get out here, let alone that crazy clay like mud the south/east has.
