  1. May 22, 2019 at 11:39 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    A keys a key? They both start and unlock my truck just fine.
    And a Walmart keys like 4$
  2. May 22, 2019 at 11:39 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They're cut from the original map of the pins in the lock cylinder, rather than a couple thousands off of whats right as you keep recutting from an example that may already be worn or a copy.
    lukester78, cruiserguy and Wadar like this.
  3. May 22, 2019 at 11:40 AM
    Speedytech7
    Also @BartMaster1234 make sure you tell them what key you want, or you'll get the basic steel key like I have
    BartMaster1234 likes this.
  4. May 22, 2019 at 11:40 AM
    JKO1998
    Utah
    I guess I get it if you can get a great value key cut right but I don’t think I’d spend 22$ if I had other options
  5. May 22, 2019 at 11:42 AM
    Speedytech7
    The only way a Wallyworld (or any key copier) can make a perfect key is for you to have an unused OEM key and they have a perfectly maintained key cutter. $22 is nothing in the grand scheme of things to have a key that works in all the locks smoothly
  6. May 22, 2019 at 11:42 AM
    eon_blue
    Azusa, CA
    I got my local hardware store to cut me a spare key for my truck, works fine. I use it on the trail because I don't keep any other keys on it making noise bouncing around. Think I paid $8 or something like that.
  7. May 22, 2019 at 11:43 AM
    JKO1998
    Utah
    I guess, mine still work.
    I think my flathead screw driver key is still my favorite
  8. May 22, 2019 at 11:44 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I had a locksmith cut me a key from only copy which is worn out. I used an OEM Toyota blank.
    I’d rather have a fresh key that’s cut from the key code rather than copying a worn out key.
  9. May 22, 2019 at 11:44 AM
    Speedytech7
    I had a buddy that cut his key shank off and epoxied it into a screwdriver handle, he was a bit of a dim bulb
  10. May 22, 2019 at 11:44 AM
    eon_blue
    Azusa, CA
    Ah I see what you mean, yeah they have to copy one so if it's worn out then it'd be better to go to Toyota.
  11. May 22, 2019 at 11:48 AM
    JKO1998
    Utah
    That just doesn’t make any sense
  12. May 22, 2019 at 11:49 AM
    Speedytech7
    I did say he was a bit dim
    JKO1998[QUOTED] likes this.
  13. May 22, 2019 at 11:53 AM
    JKO1998
    Utah
  14. May 22, 2019 at 11:53 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    just glue the key into the handle
  15. May 22, 2019 at 11:53 AM
    JKO1998
    Utah
    Oh no I get that, but why
  16. May 22, 2019 at 11:54 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    cause its kewl
  17. May 22, 2019 at 11:57 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    You’re lucky someone ripped apart a 4Runner steering column or I wouldn’t have been able to get it for you.
  18. May 22, 2019 at 11:59 AM
    JKO1998
    Utah
    I don’t think a person can get the part I needed new, kinda dumb.
  19. May 22, 2019 at 11:59 AM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    Yes, a key from Walmart will work. But if all of your keys are worn out a new set of OEM keys will make things good again. I thought my lock cylinders were going out, but everything works perfectly with new keys.
    I used my title because it has the vin number on it and provides proof of ownership. Toyota (or any dealership for that matter) is actually required to report that they cut keys for your vehicle. It gets put into a database in case someone makes keys for nefarious purposes.
  20. May 22, 2019 at 12:06 PM
    Cutter_
    Cutter_ I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    OneWheelPeel likes this.
