  1. May 22, 2019 at 12:23 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Best key I had was on my 86 toyota. Was a 306 bullet casing that had been notched and bolted to the key to basically extend the wing of the key the length of the bullet. If you've even been in an old toyota you know how odd the angle was with the key. The bullet made it super easy to just flip the key to start. Was great.
    BartMaster1234 likes this.
  2. May 22, 2019 at 1:35 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    well I finally got around to replacing my clock spring, and installing a new to me steering wheel, to replace my old grungy looking one. Hopefully this will fix my air bag light on the dash. I'm going to try and get a friend of mine to clear the code. If not, then I'll drive is a 100 miles to see if it clears. Keep my fingers crossed. But I also have a replacement air bag, and controller. I'll keep replacing until the problem is solved. 1st pic is old, 2nd is newer to me. Color is a little off but it won't bother me one bit. Thanks to the TW user who sold me the parts.
  3. May 22, 2019 at 1:39 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I believe the fsm has instructions on resetting the airbag system without the Toyota diagnostic tool.
  4. May 22, 2019 at 1:42 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @Reh5108 I've tried searching through the FSM multiple times, and that is one pain in the ass to navigate or find what your looking for. but since I have to go out, shortly, my friend doesn't live too far from me.
    Reh5108 likes this.
  5. May 22, 2019 at 1:43 PM
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Not sure, I’ve had Infiniti door speakers before they sounded good
    I’m very happy with this 12”
    I’d definitely get a 12” though. I had an 8 before and traded it for a 12”.
    A 12 can do what a 10 can do, and a 10 can do what an 8 can do.
    However an 8 struggles to do what a 10 can do, and a 10 struggles to do what a 12 can do.
    So you can go one way but not the other!
    better to have too much and not need it, then have too little and need more!
    I also prefer sealed box over ported, and I like the 2ohm speaker a bit louder than 4ohm but people have their preferences
    It really adds so much depth to music it’s really a great upgrade. And I’m not some drive around the parking lot with loud bass sorta guy lol it just adds a lot of depth and dimension to music
  6. May 22, 2019 at 2:44 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Ive been trying to narrow down exactly where my leafs are squeaking. Me and a friend traced down the culprit to be the passenger side leaf spring bushing on the shackle side. I ruled everything else out by spreading the leafs with a prydriver and getting some grease on the rubber pads. Hopefully gonna tackle that tomorrow and be left with some silent leaf springs.
    Another horrendous noise started coming from the drivers leaf pack today though. Turns out the add a leaf I installed was either a tad too long, or the hole wasnt drilled where it shouldve been. The spring was scraping up against the clamp that holds the pack together. Easy fix with a cutoff wheel, and now that side is dead silent.
    GQ7227 likes this.
  7. May 22, 2019 at 2:58 PM
    eon_blue
    Azusa, CA
    I've found that those clamps can also create a lot of knocking/thumping sounds if they're too tight, when I installed my AALs I overtightened them and they made a lot of noise. Apparently they shouldn't be too tight to allow the leafs to move naturally. There was an ARB document that I found that pointed it out
  8. May 22, 2019 at 3:15 PM
    JakesTacoTRD
    JakesTacoTRD "Winona the Tacoma"
    Jacob
    Gainesville, FL
    2001 White Tacoma SR5 TRD 4x4 5 speed
    New lower ball joints and brakes... still have a suspension clunk so new upper ball joints are next!... the lower ball joints looked OG... 180k...
  9. May 22, 2019 at 3:19 PM
    eon_blue
    Azusa, CA
    What kind of front coilovers do you run? If you have spherical bearings in the bottom of them, I got a lot of clunking from mine when they needed replacing.
    Also make sure your LCA cam bolts are torqued to spec
    JakesTacoTRD[QUOTED] likes this.
  10. May 22, 2019 at 3:20 PM
    JakesTacoTRD
    Jacob
    Gainesville, FL
    Just replaced mine with 5100s (at 2.5in) a few months ago!
    I’ll check the control arms soon!
  11. May 22, 2019 at 3:24 PM
    eon_blue
    Azusa, CA
    Ah okay yeah you have bushings then instead of bearings. Definitely check the cam bolts, especially if you've had an alignment done recently and noticed the clunk afterward. Sometimes shops don't torque them to the required spec (don't have my torque sheet handy so I can't tell you what it is).
    Also if the bushings in the LCA are in bad shape it can cause them to shift and clunk.
    If the noise started happening after the 5100 install I'd go over the top and bottom bolts and make sure they're torqued as well.
  12. May 22, 2019 at 3:24 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    visited bodyshop to have small nick near fuel tank door touchup paint, he said it doesn't look corrosive, not enough to warrant repaint of box
    humidity not high enough for squeaky door syndrome diagnostics, was opening/closing like a champ
    ran A/C on freeway, turned off when got onto residential streets, no noticeable rattle upon acceleration as has been occurring this season so far
    the gremlins continue marching on for now...
  13. May 22, 2019 at 3:30 PM
    JakesTacoTRD
    Jacob
    Gainesville, FL
    Hmm... yeah, I noticed the clunk around the suspension install/alignment, but my lower bushings were blown on the old coil overs so likely couldn’t hear the clunk over that squeak. I asked the alignment guy to make sure I torqued all the bolts correctly and gave him the correct torques because I don’t trust my shitty torque wrench... didn’t tell him the torque for the cam bolts though just the top at lower bolts on the 5100.
  14. May 22, 2019 at 3:36 PM
    eon_blue
    Azusa, CA
    yeah I'd give those cam bolts a double check then, if it happened after the new suspension went in then my money is on something with the new setup.
  15. May 22, 2019 at 3:43 PM
    Phessor
    Phessor Well-Known Member
    Installed some MB Quart component speakers in my front doors. Replaced my worn belt molding on both doors. Also put some sound deadening in doors and back wall of cab. Sounds better already.
  16. May 22, 2019 at 3:46 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    Might have to pick one of these up. Not a bad idea
    01x4[QUOTED] likes this.
  17. May 22, 2019 at 3:53 PM
    JakesTacoTRD
    Jacob
    Gainesville, FL
    Did the mount come with it? Just bolt or velcro?
  18. May 22, 2019 at 4:04 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They honestly don't even need the bolts, I don't put them back in
    El Taco Diablo likes this.
  19. May 22, 2019 at 4:05 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I changed my oil, finally got the whole belly skid mounted.
    Did some truck stuff. Took a load to habitat for humanity.
    And I stopped by discount.
  20. May 22, 2019 at 4:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    usually a fresh lift and clunking is the sway bar if you still have it.
    LukeCC likes this.
