  1. May 25, 2019 at 8:44 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Tbh it could, it’s only first gear and not my daily so I’m sure I can struggle bus it until I have the time. Trucks gonna be in parts by the time I can get it back to 100 haha
    GQ7227[QUOTED] likes this.
  2. May 25, 2019 at 8:59 AM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    The dust shields for the rotors... do that actually serve any purpose or can I get rid of them with no ill effects?
  3. May 25, 2019 at 9:01 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i have heard rocks (little ones) can fly up into there with them off and cause major headaches :confused:
  4. May 25, 2019 at 9:14 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I'm doing the same today with my new 32" pizza cutters. Hopefully I just need to heat gun the liners.
  5. May 25, 2019 at 9:15 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Which tires are you running?
  6. May 25, 2019 at 9:36 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    you"re going to be jelly but i made a deal with a friend of mine to trade his built land cruiser 80 series float axles for my spare set of one ton axles.
    cruiserguy likes this.
  7. May 25, 2019 at 9:44 AM
    JasonLee
    15 TRD OffRoad
    KO2s 255/75R17's on 2012 FJ Cruiser Trail wheels.
  8. May 25, 2019 at 10:06 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Purpose: to trap mud and rocks to alert you that your truck hates mud, don't do it again!
    When I need to do wheel bearings again I'll likely leave them off.
  9. May 25, 2019 at 10:57 AM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Replaced right side axle seal. Someone used gasket sealer instead of the outside “o” ring. That crap was all over the inside of the bearing housing and the ABS sensor. F’n pain in the a$$ to clean up.
    Local place wanted $500, including brakes. I’m under $100 all in.
  10. May 25, 2019 at 11:39 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That o-ring is like $5 :rofl: What a dick. Glad you got it taken care of. Make sure you pay attention to the other side, when one went out the other was out within 6-8 months....
    TacoYankee[QUOTED] likes this.
  11. May 25, 2019 at 12:11 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    Less than $5. I paid $3.82 from McGeorge Toyota, honestly the one cheapest OEM part dealers on line. Other side was good to go...for now.
    BYJOSHCOOK[QUOTED], GQ7227 and CS_AR like this.
  12. May 25, 2019 at 2:12 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Area51Runner and SilverGhost like this.
  13. May 25, 2019 at 3:55 PM
    Reh5108
    Idaho
  14. May 25, 2019 at 3:58 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    20190525_153835.jpg picked this up off craigslist for 100 bucks. Needs some finish work. But cheaper than I could've made it. Has 3 coats of urethane sealer on it. Fits a full size sleeping pad.now I can move crap from my cab back here.
    SwampYota and Area51Runner like this.
  15. May 25, 2019 at 4:23 PM
    Brake Weight
    No. I had to go into town to the parts house for a 12v relay. I spliced into my horn but was losing to much voltage from the 16g wire ran from basically my air box to in the bed behind the passenger. Installed it at a car wash on the outskirts and then 10 miles back into the woods. I ended up using it 3 times at texters. LOL. Love this thing. Now I’ll be looking for some bigger horns to get a deeper tone. This quad is loud but it’s a higher pitch than the 18 wheelers have.
  16. May 25, 2019 at 4:54 PM
    Brake Weight
    New sticker.
    SwampYota likes this.
  17. May 25, 2019 at 5:46 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @BartMaster1234 , I've hit Gunny up several times for part numbers. Just give him you vin number, and he will get back to you really quick. I just dropped $400 bucks at CamelBack Toyota in Arizona. Some things are worth buying original Toyota parts, and from what I've seen here on TW, Ball joints are one of them.
    GQ7227 and BartMaster1234 like this.
  18. May 25, 2019 at 8:48 PM
    beikokupilot
    beikokupilot Well-Known Member
    Utah
    1997 Red Tacoma 4WD
    Power steering pump, Steering rack, Tie rods, Radiator cap, Thermostat, New radiator, magnets to hold the fuel door closed, new starter drum/cylinder, dash lights changed to red, replaced all carpet in the cab. Not real “mods”, but all work
    Sure someone has helped you already, but you can order a new ignition column and swap it out (super easy if you can shimmy the key and get it to turn to ACC) for like $25
  19. May 25, 2019 at 9:11 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    do they offer free shipping if order total is over certain amount?
    not including large or very heavy items
  20. May 25, 2019 at 9:34 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    McGeorge price with shipping works out to be less overall than the free shipping deals. Once you pay for shipping on the first item, the shipping cost for subsequent items is lower. I once saw an online parts supplier that had the best price per item, but the shipping costs for each item were like separate sales and shipments.
    Compare the price at McGeorge for an alternator to any other online dealer to see the benefit. Since I will be spending over $1,000 with them this year, their pricing discounts add up and make a big difference.
    https://toyotaparts.mcgeorgetoyota.com/
