  1. May 27, 2019 at 5:37 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    How are the tie rods?
    CS_AR and m3bassman like this.
  2. May 27, 2019 at 5:39 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    The guy that did the alignment the other day said everything checked out
  3. May 27, 2019 at 5:39 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    I’ve got parts you need collecting dust.
    CS_AR likes this.
  4. May 27, 2019 at 5:40 PM
    Phessor
    Phessor Well-Known Member
    What cleaning products did you use? I have some pretty bad stains I need to get rid of.
    CS_AR likes this.
  5. May 27, 2019 at 5:43 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm not him but I've had really good luck with good old fashioned dawn or gain dish soap, and ive even used simple green on greasy or oily stains. You don't need a lot and a stiff brush and a wet dry vac will help you finish it off nicely
    CS_AR likes this.
  6. May 27, 2019 at 5:43 PM
    cruiserguy
    Elijah
    SEKS
    So this guy has reset your alignment how many times in what time period? And he says there isn't anything wrong? Why does he say it loses alignment then? Just curious
    TacoYankee likes this.
  7. May 27, 2019 at 5:44 PM
    JKO1998
    Utah
    Oh?
    Once ever
  8. May 27, 2019 at 5:45 PM
    cruiserguy
    Elijah
    SEKS
    Yup, nice advantage to synthetic fibers in the carpet... Bring on the simple green or even harsher stain remover without fear! But yeah a lil dawn is all I've used anyway
    CS_AR likes this.
  9. May 27, 2019 at 5:46 PM
    cruiserguy
    Elijah
    SEKS
    So why are you worried about having your alignment set?
  10. May 27, 2019 at 5:47 PM
    JKO1998
    Utah
    My tires aren’t wearing right
  11. May 27, 2019 at 5:47 PM
    Speedytech7
    I'm happy to hear you got there safely and enjoyed the truck! Question that has been on my mind, what did you think of the I4 vs what you feel usually with your V6?
    Thank you very much, I appreciate it! You'll probably see me as drive my 300zx through Cali to park it in WA before I move.
    CS_AR and El Taco Diablo[QUOTED] like this.
  12. May 27, 2019 at 5:48 PM
    cruiserguy
    Elijah
    SEKS
    Yes bad wheel bearings CAN cause your tire wear to be abnormal
  13. May 27, 2019 at 5:50 PM
    JKO1998
    Utah
    Guess we’ll see what Mr. Mechanic says
  14. May 27, 2019 at 5:52 PM
    cruiserguy
    Elijah
    SEKS
    Grab the tire while still on ground at 12 o'clock and push in hard and pull back and so forth.... You'll feel wheel bearing play. Some people lift tire off ground to do it but I've never needed to.
    Edit -nevermind, looks like you're not with taco rn
    JKO1998[QUOTED] likes this.
  15. May 27, 2019 at 6:04 PM
    vonellis
    Some and some more
    Carpet cleaning machine. Now that it’s dry I could probably hit it again in the spots that were heavier stained . Next time I would probably get some good stain remover and soak for a few.image.jpg
    CS_AR and Phessor[QUOTED] like this.
  16. May 27, 2019 at 6:09 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I had my carpet out when I was sound proofing, so I hit it with the pressure washer with Dawn dish soap. Cleaned up to like new!!
    Phessor likes this.
  17. May 27, 2019 at 6:24 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Speedytech7[QUOTED] likes this.
  18. May 27, 2019 at 7:17 PM
    970btu
    970btu Well-Known Member
    Ty
    Las Vegas
    99 Tacoma 3.4 5spd ext limited TRD 55K and counting
    OME, SPC UCA, ARB w/warn 10K winch, TG Rock Defense Rear, Marlin Clutch, Custom hi clearance under bed spare mount. 285/75/16. A ton of repairs done and a list up to come modifications.
    I had to cut the fender flair. Was easier than cutting the fender!
  19. May 27, 2019 at 7:47 PM
    eon_blue
    Azusa, CA
    That looks really good, nicely done
    cruiserguy and 970btu[QUOTED] like this.
  20. May 27, 2019 at 8:51 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Absolutely a bad wheel bearing will throw off the alignment. It's how I found mine to be bad. I kept adjusting toe and I kept chasing my adjustments back and forth.
    Pretty easy to lift a tire off the ground and check yourself. The tech should know how to check for a bad wheel bearing.
    cruiserguy likes this.
