  1. May 28, 2019 at 10:12 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I only had about 25k on my fully rebuilt engine before the rear of the valve covers started to weep oil. I took it back and they replaced the gaskets, those half-moon pieces and such, re-torqued the studs and seems to be ok so far ~5k later... Whatever you do, just keep an eye on things as time goes on. Even the best work (or "best") may result in not optimal results.
    04Pre_Runner[QUOTED] likes this.
  2. May 28, 2019 at 10:33 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    You running it along with the stock cooler or by itself?
  3. May 29, 2019 at 1:37 AM
    Jonnyricogalabiz
    Jonnyricogalabiz Well-Known Member
    Jonny
    Redlands ca
    02 Prerunner
    N/A
    Hey guys so i have a question that i'm not quite understanding... so i see a king 2.5 coilover 16 travel is about $800 would it make sense to buy these Only for a long travel setup? Because i have mid travel rn... & plan on moving to long travel but not understanding the 6-8-10-12-14-16 coilovers? & why & what there used for? Also bypass shocks do these go infront aswell? Or in back? With a rear cage set up
  4. May 29, 2019 at 5:36 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Im sure someone will chime in but they have a long travel section too. Tons of knowledgeable peeps .
  5. May 29, 2019 at 6:39 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Went camping over the weekend.
    And tested out summer mode on my camp lights.
    cbassd, malburg114, CS_AR and 7 others like this.
  6. May 29, 2019 at 7:01 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Looks good. This is definitely on "the list" for me.
    austinmtb[QUOTED] likes this.
  7. May 29, 2019 at 8:33 AM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    Ran it through the stock cooler first, and then the Hayden.
    cali04intx and Area51Runner like this.
  8. May 29, 2019 at 9:47 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the only use for a 16'' travel coilover would be for rear linking the truck. Which is a huge custom thing involving a lot of cutting and welding and almost makes the truck not a truck. Its a race truck move. Not that you can't do links and keep a bed but its not super easy.
    Bypasses can go in the front or the rear.
    I'd suggest doing a lot of reading on suspensions and long travel if that's what you're going for. There is a ton of good info out there.
    Running Board Man likes this.
  9. May 29, 2019 at 9:58 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Bed space, your wallet and time, other more technical things I don’t know about.
  10. May 29, 2019 at 9:59 AM
    Jonnyricogalabiz
    Jonny
    Redlands ca
    02 Prerunner
    N/A
    Ya i understand the links in the back just the size i was confused of... so 16 are only for the back in case of links which connect to a bed cage i seen etc but thats the size that we as a 1st gen infront coilover size should use? 8in? I'm guessing? I plan to go do coilovers & a bypass infront since the LT i'm looking at has two attachments for them
  11. May 29, 2019 at 10:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nothing or everything. All perspective and what you want out of the truck.
    Thats a custom 4 link setup. Means you can haul major ass through rough terrain though. But higher maintenance. Very much race truck. And not really a DD sort of thing. JD might DD this thing though ha
    There are other ways of doing it. 3 link. 3 link wishbone. Lots of ways to do links and keep the bed too with some trick engineering.
  12. May 29, 2019 at 10:21 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    front standard kits use a short body 8'' travel shock. Race kits sometimes use a 10'' with custom front hoops.
    A lot of kits spec specific shocks so depending on the kit you'll want to ask them what shocks they used.
  13. May 29, 2019 at 11:01 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I suggest spending a lot of time reading the Long Travel thread. I'm not sure you are prepared for what rabbit hole you are about to go down. Unless you have unlimited funds and can just pay the right person to find, guide you what to buy and install it for you.
    JasonLee and Squeaky Penguin like this.
  14. May 29, 2019 at 12:48 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    I wouldn't worry about high mileage covers as long as they are clean and not all gunked up or something. I bought a used set with unknown mileage after I cracked mine and they have been junk fine.
  15. May 29, 2019 at 12:59 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Wait what?
  16. May 29, 2019 at 1:42 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  17. May 29, 2019 at 1:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  18. May 29, 2019 at 3:04 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    My Chevy's are nice and soft. No complaints. I'd never want stock suspension ever again.
    cruiserguy and Area51Runner like this.
  19. May 29, 2019 at 3:19 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol
    Typo for me!
  20. May 29, 2019 at 3:40 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I know. Quotes were supposed to show sarcasm.
