  1. May 31, 2019 at 10:15 AM
    eon_blue
    Azusa, CA
    I have ratcheting wrenches with swivel heads but I couldn't get one on there, it's an extremely tight fit high up inside the fender.
    Although I was cleaning the inside of my door jambs the other day and noticed I could see the bolt pretty clearly with the door open from inside, with an extension I might be able to get to it that way.
    If you have small hands/arms you could probably get to it by reaching up from under the fender using your fingers to thread it on
  2. May 31, 2019 at 10:19 AM
    eon_blue
    Azusa, CA
    Couldn't bring yourself to drill/rivet the a-pillar huh? haha I don't blame you on that either, I riveted mine but it's definitely a commitment once you punch holes in the a-pillar.
    I know a few guys used heavy duty tape on theirs in the ebay thread, I would just worry about the outdoor elements eventually weakening it and causing it to come loose/wobble around on the highway or something.
    Area51Runner and 01x4[QUOTED] like this.
  3. May 31, 2019 at 10:20 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Removing the bottom fender bolt helps as well. Will give you a bit more room as the fender will be able to pull away toward you (slightly!).
    SwampYota, GQ7227, 01x4 and 1 other person like this.
  4. May 31, 2019 at 10:25 AM
    eon_blue
    Azusa, CA
    I'll have to look up this Gorilla tape, I used some of the 10lb 3M tape to hold up a small motion sensor (not even 1lb) outside our front door (wife wouldn't let me put a tiny wood screw in the porch...) and the damn thing let go not even 2 days later lol.
  5. May 31, 2019 at 10:31 AM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I bet you could put a riv nut in that so you wouldn’t have to get up behind the fender to put a bolt in.
  6. May 31, 2019 at 11:12 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Craftsman makes an open end ratchet wrench. I personally haven't used them yet but it saved my roommate some time on his sas 4r calipers bolts.
  7. May 31, 2019 at 11:14 AM
    Reh5108
    Idaho
    Is it gimmicky if it works? :notsure:
  8. May 31, 2019 at 12:23 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Was a hauler not a crawler this morning :laughing:
    Weighed in at 6220 hahah, then weighed after and was 4700, my bitch is a bit heavy
    jubei, 01x4, SwampYota and 3 others like this.
  9. May 31, 2019 at 12:23 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Found some Caddy horns at the junkyard today. Gonna save them for a good rainy day project methinks. IMG_20190531_133346526.jpg
  10. May 31, 2019 at 12:35 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Put on another 1200 lbs, then you’ll be in @Digiratus league :D
    m3bassman and Prayn4surf[QUOTED] like this.
  11. May 31, 2019 at 12:37 PM
    Prayn4surf
    Socal
    Lol Ive got more dirt and concrete to move but i suffer from lazzyencolitus
    @Digiratus did you really load your truck to 7400 lbs lol
    Speedytech7 and drr[QUOTED] like this.
  12. May 31, 2019 at 1:08 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Wut
  13. May 31, 2019 at 1:11 PM
    Area51Runner
    ever think they were tried before? I ordered an extra long flex head ratcheting wrench specifically to try and get that top nut onto the bolt. Problem with it is as you try to persuade the wrench to fit (after painfully using your fingers only to try and position the nut), the wrench will flex and its impossible as the nut will drop. Trust me on this... Why I ended up removing that bottom fender bolt. Once removed and the fender slightly pulled away from the truck, I was able to thread the nut by hand and slip a wrench over it to torque it down.
  14. May 31, 2019 at 1:24 PM
    JKO1998
    Utah
    The whole fender isn’t difficult to remove :notsure:
  15. May 31, 2019 at 1:26 PM
    Area51Runner
    No, its not
    Running Board Man likes this.
  16. May 31, 2019 at 1:34 PM
    Prayn4surf
    Socal
    You mining for gold lol what is that thing a trommel?
  17. May 31, 2019 at 1:36 PM
    JKO1998
    Utah
    Old silage makerer (technical name) go to the scrap yard
    Prayn4surf[QUOTED] likes this.
  18. May 31, 2019 at 1:37 PM
    Prayn4surf
    Socal
    Wtf did that thing weigh in at?
  19. May 31, 2019 at 2:01 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I do have the upgraded harness with the heavy duty relays and I originally the Hella E-code lamps, just wanted to upgrade to black chrome for the look. I found Lasfit Auto Lighting and going to try their LED h4 bulbs out with my original black chrome housings and if it doesn't do anything for me I will put he Hella housings back in. Wish me luck!
  20. May 31, 2019 at 2:10 PM
    JKO1998
    Utah
    I can’t remember, I think right around 1200
