  1. Jun 6, 2019 at 1:18 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Auto or manual?
    Kpatt9[QUOTED] likes this.
  2. Jun 6, 2019 at 1:19 PM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
  3. Jun 6, 2019 at 1:20 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    :rofl:
    That’s awesome!
    xtremewlr likes this.
  4. Jun 6, 2019 at 1:25 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Manual trannys are just as easy as engine oil. Just make sure you take off the fill plug before the drain plug and your good to go.
    The horror stories I'm assuming are of autos since I've never heard of any
  5. Jun 6, 2019 at 1:25 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Change the fluid. The horror stories are for automatics. Manual will love you for changing it. Also check the shifter bushings, they are probably shot. You can get new OEM or even better, get the Marlin ones.
    I highly recommend Red Line MT90 for the trans. I put it in my truck and it shifts beautifully, especially after changing the shifter bushings.
    jubei and Kpatt9[QUOTED] like this.
  6. Jun 6, 2019 at 1:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Okay the difference is ABS.
    First off. ALL ELOCKER HOUSINGS ARE ABS HOUSINGS. So you need to get bearings for ABS regaurdless of if your truck has ABS or not. The axles themselves are just setup for it.
    If you don't have an Elocker, you need to know if you have ABS or not. If you don't Get the bearings that don't go with ABS.
    xtremewlr[QUOTED] likes this.
  7. Jun 6, 2019 at 1:25 PM
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    Word word thanks. Just drain and fill? How much fluid.. 6/7 qts?
  8. Jun 6, 2019 at 1:27 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Non-ABS, with e-locker. I do have the ABS ports, just blocked off. So I need the ABS kit either way. Thanks Monte!
    jubei and Blackdawg[QUOTED] like this.
  9. Jun 6, 2019 at 1:27 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    This is 100% @xtremewlr I have an elocker and no ABS yet I needed to replace all that BS even tho is serves no purpose except to make things harder for ya
    That I can't remember, cue @Speedytech7 to the rescue
    Kpatt9[QUOTED] and xtremewlr like this.
  10. Jun 6, 2019 at 1:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Correct! You need the ABS ones. Your axle will have tone rings too likely install, but you don't need new ones or even have to put them back on if you want. Up to you.
  11. Jun 6, 2019 at 1:34 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
  12. Jun 6, 2019 at 1:34 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    So I'll just order up a couple of these kits from Low Range - http://www.lowrangeoffroad.com/toyo...imate-rear-wheel-bearing-kit-without-abs.html
    And order an extra set of the wheel bearing collars. That should work, correct? Cheaper this way i think, $180 + $24 for the extra collars from Amazon (OEM Toyota) vs $240 for the full ABS version with the tone ring and extra collars included. Same parts otherwise.
  13. Jun 6, 2019 at 1:37 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    2.3qts for the trans.
  14. Jun 6, 2019 at 1:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No. That kit is for No ABS. The bearings are a bit different.
    Ask @jubei I believe he found out the hard way.
  15. Jun 6, 2019 at 1:39 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Gotcha, that's what I wasn't sure about and why I originally asked about the bearing parts numbers. There was no explanation for the different #s that I could find. But this would explain it perfectly. Thanks again!
  16. Jun 6, 2019 at 1:44 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    I've actually had better luck with the Amsoil varient rather than the Redline MT90 but thats likely personal preference. Just as long as its GL4 you're good.
    GL4 is hard to find in store anymore but it is important you use it VS GL5
  17. Jun 6, 2019 at 1:54 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Part of paying someone else is not having to put up with the mess. Only work I had to do was drop them off and pick them up 2 weeks later.
    Running Board Man likes this.
  18. Jun 6, 2019 at 2:01 PM
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    Thank god that shit is expensive haha.
    Thanks for the help.
  19. Jun 6, 2019 at 2:11 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, about $20 for a qt off Amazon of the MT90. I'm sure the Amsoil stuff is just as pricey. Either will work wonders tho.
  20. Jun 6, 2019 at 2:12 PM
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    Anyone know if there are crush washers?
    Torque specs?
