  1. Jun 9, 2019 at 2:11 PM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Can anyone help me with a carfax report? I heard some can run unlimited reports... please let me know, thank you in advance :hattip:
    GQ7227 likes this.
  2. Jun 9, 2019 at 2:29 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Currently trying to replace the pinion seal on the rear diff. I have the drive shaft separated but can’t get the companion flange off the diff. How hard can I go with a mallet on that without damaging it?
  3. Jun 9, 2019 at 2:30 PM
    eon_blue
    Azusa, CA
  4. Jun 9, 2019 at 2:44 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Depending on if the last guy to assemble it used anti-seize on the splines, you might be fighting some corrosion locking the flange onto the pinion. You can go pretty hard with a mallet on it, but you might try putting an axial load on the flange while you do that, such as a come-along from a crossmember to the flange.
    Do you have a solid pinion spacer? What is your plan for setting the pinion preload during reassembly?
  5. Jun 9, 2019 at 3:03 PM
    eon_blue
    Azusa, CA
    My pinion seal has a slow leak...constantly wet around the bolts. Not bad enough that I'm gonna tackle it yet though. Was yours leaking really bad?
  6. Jun 9, 2019 at 3:06 PM
    tony2018
    tony2018 Well-Known Member
    I don't think this seller wants to get rid of the xtended cab...theres no way I'm going late in the day to look at this truck.
  7. Jun 9, 2019 at 3:14 PM
    ffirg
    mike
    Anchorage, Alaska
    Went on a 1,000 road trip and it sling gear oil all over the rear of the truck. Figured I would just change it when I was ready to do a fluid change. Front diff only had half a quart of fluid in it :0
    Rear had about the right amount but was definitely a bit dark.
    I got the flange off with the mallet. Just took a while. Trying to press the seal in now and will just tighten the pinion nut to where it was before plus I think another 1/16 or so of a turn
  8. Jun 9, 2019 at 3:20 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    So, I didn't do a thorough look through Belmetric on amazon, but I picked something on the first page of search results - (2pcs) BelMetric M10X1.25X50 A2-70 Stainless Steel - $15.99.
    Holy smokes that's expensive. You can get those same two bolts from boltdepot.com for $.89 each. Less than $2.00 for the same thing. Now, you have to pay shipping, but even then, it's way cheaper. And the more bolts you purchase, the more you'll save (b/c their shipping is reasonably cheap as you increase qty.).
    xtremewlr[QUOTED] likes this.
  9. Jun 9, 2019 at 3:22 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I got rid of the factory cross member for the tire carrier and welded the winch to the new cross member. I was then able to raise the Jerry can holder even higher. Not that I had any issue with it hitting anything with the factory crossmember though.
  10. Jun 9, 2019 at 4:33 PM
    Reh5108
    Idaho
    For future reference a 3 Jaw puller works perfectly. 2 Jaw will likely suffice as well.
    Just did my SPC upper bj and an alignment in under an hour!
    m3bassman likes this.
  11. Jun 9, 2019 at 4:43 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    Did you have any issues getting a good alignment with the SPCs? I just put some on and even after the alignment shop "corrected" it, it still has 1.9 and 1.5 degrees of positive camber? Is that normal?
  12. Jun 9, 2019 at 5:01 PM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    Position D? It is the one that comes recommended on the instruction sheet. It just looks funky, if its suppose to be like that its cool, I just want to make sure I'm not wearing anything out quicker that it needs to be.
  13. Jun 9, 2019 at 5:02 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How using tubing as cross braces flex more then the stock one..
    Reh5108 likes this.
  14. Jun 9, 2019 at 5:02 PM
    Reh5108
    Idaho
    No. Sounds like an incompetent tech. I will say that with my old spindles I couldn't get 0° and keep my cams maxed but if I would have adjusted the cams I'm confident I could have dialed it in. Those were negative though. I don't think I could go positive if I wanted to.
  15. Jun 9, 2019 at 5:04 PM
    Reh5108
    Idaho
    He said camber not castor. Is castor what you meant @Tacofire98?
  16. Jun 9, 2019 at 5:09 PM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    Nay. I feel like I am unable to reach 0* and am stuck in the positive camber, even with maxed out cams. You mentioned different spindles, are they longer ones?
  17. Jun 9, 2019 at 5:11 PM
    2002Tacoma4x4
    C K
    GQ7227 and eon_blue[QUOTED] like this.
  18. Jun 9, 2019 at 5:19 PM
    Reh5108
    Idaho
    I just got another set to gusset since I assumed my originals were bent. Having the cams maxed isn't the best if you can't get your camber better. If you adjust the front one so it pushes the arm out it should help. How much lift do you have?
  19. Jun 9, 2019 at 5:49 PM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    Im sitting at 2 in lift with all the weight have on it. right now i think all my cams are maxed out and the ball joint being maxed inward.
  20. Jun 9, 2019 at 6:02 PM
    Reh5108
    Idaho
    Sounds like something isn't quite right. I'd suggest something is bent but they're both similar so that isn't likely it. Your front cam bolts are as inboard as possible and your rears are as outboard as possible, correct?
