  1. Jun 10, 2019 at 10:07 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I have those transmissions heat up pretty quick in overdrive going up steep grades you only did something to help it I doubt there’s an issue with the radiator
  2. Jun 10, 2019 at 10:08 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I don't think you were "Hiding a problem." I always take it out of OD when climbing grades.
    Running the aux cooler after the rad is exactly where it should be installed. I think you've done everything right.
  3. Jun 10, 2019 at 10:09 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You didn't ask for my take specifically but I don't think you hid the problem. It looks like you directly addressed your problem. Sounds like you did it right by adding that cooler
  4. Jun 10, 2019 at 10:32 AM
    Empty_Lord
    Dan
    Honestly the trans temp likely went up drastically just because the engine coolant temp was likely around 210 at that point. Being next to the trans cooler likely transfered the heat to the trans fluid
    Running Board Man and cali04intx like this.
  5. Jun 10, 2019 at 11:07 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    How are you seeing your AT temp? I have an ultra gauge but it only shows engine temp as far as I can tell.
  6. Jun 10, 2019 at 11:11 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    UltraGauge doesn't show trans temp on 1st gens.
    ScanGauges do, unofficially, by using a custom programmed "X-Gauge Commands".
  7. Jun 10, 2019 at 11:12 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That sounds decent to me, what size and style of cooler? Plate and fin or one of the winding pipe styles. 90MPH is no joke cause usually if the load is high enough it'll unlock the TC and turn itself into a heater. 2000' rise in 17mi isn't crazy and 200° is still a bit high to me. But these trans aren't very efficient so it's certainly better. I climbed Grapevine pulling my trailer with the land cruiser, I typically shoot for above 50mph when pulling a load up a pass cause more than that is undue stress but it was raining and I wanted off the pass so I went for 65MPH and ended up heating my exhaust so much the hanger broke but with an absolutely massive trans cooler I only hit 168° on trans temp.
  8. Jun 10, 2019 at 11:16 AM
    ffirg
    mike
    Anchorage, Alaska
    Oh really. Well I will have to look into this. My usual way to get AT temp is to touch the carpet on the floor. If it’s more warm then normal I know I should probably change something haha
  9. Jun 10, 2019 at 11:16 AM
    Speedytech7
    @zero4 got an Ultragauge to show trans temps, he found the code for them
    cali04intx, zero4 and Captain Magma like this.
  10. Jun 10, 2019 at 11:26 AM
    ffirg
    mike
    Anchorage, Alaska
    Interesting. I’d be curious to see how that works
  11. Jun 10, 2019 at 11:38 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Finishing touch.
    chrslefty, GQ7227, SwampYota and 7 others like this.
  12. Jun 10, 2019 at 11:45 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Have you driven it yet?
  13. Jun 10, 2019 at 11:51 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Coolant temp is measuring temps exiting the engine. It flows through the radiator and is cooled prior to interfacing with the transmission cooler at the bottom.
    Regardless of how many transmission coolers you have, when you are accelerating in 4th gear, your lockup clutch will release to help build torque using the torque converter. The issue is, when you are in OD, the torque converter is very inefficient and your temps will immediately spike well over 200. When the lockup clutch engages, you will see an immediate drop of about 10* followed by a continued drop until it levels out to normal operating temp. I have an oversize trans cooler designed for full sized trucks and my temps easily spike to 205* when aggressively accelerating in 4th. When the lockup clutch engages, I generally operate in the 180-190* range.
    When you turn off OD, this helps a little initially as your torque converter is more efficient in 3rd gear but the reason you saw a large and immediate drop in temps is more likely because your lockup clutch engaged and your torque converter was no longer pumping fluid so hard. In 3rd gear your transmission isnt under as much load and more readily engages the lockup clutch.
    In OD, the lockup clutch will engage aggressively around 50mph with ECT off and with ECT on, it will delay to about 60mph. With OD off, the lockup clutch engages around 55mph.
    This is why its always advisable to run with OD off when towing or hauling, especially in the mountains. Also remember, your trans temp is measuring temperature of fluid leaving your torque converter, not overall fluid temp so it will always be volatile/fluctuating based of your torque converter load, regardless of your trans cooler.
    Hope that explains everything and puts you at ease.
  14. Jun 10, 2019 at 12:18 PM
    JasonLee
    15 TRD OffRoad
    better question: does it even fire up yet / rags removed, @BartMaster1234 ?
  15. Jun 10, 2019 at 12:18 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    think you have to have a newer one. but should work. Think there is even instructions on their site for it.
  16. Jun 10, 2019 at 12:25 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yep, been done about a week. I left for Vegas and just got back the other day, so I’m finishing up the gauges and methanol injection.
    https://youtu.be/sUJM9dBkOfE
  17. Jun 10, 2019 at 12:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yes. I removed the remaining debris with a jewelery remover intended for plumbing through the spark plug holes, and I left combustion burn up the rest of it. It fired up on the first turn.
  18. Jun 10, 2019 at 12:33 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    1999 and up. I tried on both my 1998’s and it doesn’t report transmission temperature. 1999 is the earliest year I’ve seen it work.
  19. Jun 10, 2019 at 12:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah thats not new though. Always been like that.
  20. Jun 10, 2019 at 12:41 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Yeah. @Timmah! Runs an A pillar trans temp gauge on his 98 4Runner because of this. Seems to be a clean solution. I almost want to do that over getting a scangauge.
