  1. Jun 14, 2019 at 9:49 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Or get an LED flasher from O'reillys
    Teke, Dalandser, sandsloth and 2 others like this.
  2. Jun 14, 2019 at 11:28 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Order this on Amazon. I get it tomorrow. Then I’ll swap it over to the marker lights.
    Running Board Man likes this.
  3. Jun 15, 2019 at 5:22 AM
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    Does anyone happen to know if the felt headliner is interchangeable whith vinyl headliner from the earlier years? I don't know if there's some sort of mounting structure they changed later on.
    I have the vinyl now but an thinking about swapping to felt if its possible.
    GQ7227 likes this.
  4. Jun 15, 2019 at 5:35 AM
    Trim taco
    I keep dancing around the idea of adding a sunroof, but the bows in the vinyl headliner are a complication I can't seem to find a work-around to. The felt headliner, with it's rigid backing would be much simpler to work with. Otherwise, I like my headliner just fine. Thx for the suggestion, tho.
    Running Board Man and GQ7227 like this.
  5. Jun 15, 2019 at 6:44 AM
    Trim taco
    So you have the felt headliner, correct? How exactly does it stay in place? The vinyl is tucked into the front and back glass weatherstrip.
    GQ7227 and 01x4[QUOTED] like this.
  6. Jun 15, 2019 at 7:04 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Those contacts are common and standard supply at any auto electrical shop. I got them at local auto electric shop with a plunger for like 10 bucks
  7. Jun 15, 2019 at 7:28 AM
    cruiserguy
    Elijah
    SEKS
    Hell's canyon??? We talking, like the best sturgeon fishing, Hell's canyon?? Tremendous sturgeon fishing river if so
    turbodb[QUOTED] likes this.
  8. Jun 15, 2019 at 7:37 AM
    Trim taco
    hmmm . . . this makes me think i could retrofit it pretty easily. Thx for the info!
    01x4[QUOTED] likes this.
  9. Jun 15, 2019 at 8:26 AM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    i know it looks weird. the extended look is due to a swing out for the hitch basket and hitch drop. after installing the high clearance bumper i couldnt open my bed drawers so i had to install the drop. the basket extends out too.
  10. Jun 15, 2019 at 10:07 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    One and the same.
    cruiserguy[QUOTED] likes this.
  11. Jun 15, 2019 at 10:45 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Tried out my Map gas torch and Air impact on 03 Tacoma rear bumper and receiver hitch. Now onto the wheels. a tacoma bumper removed.jpg a tacoma new bumper.jpg A tacoma wheel before.jpg a tacoma wheel after.jpg
    SwampYota and CS_AR like this.
  12. Jun 15, 2019 at 11:10 AM
    Black DOG Lila
    Virginia
    Please tell me where to find rectangular frame plugs. The hole is 1.25 by .75a tacoma rectangular frame plug.jpg
    FLBAdrian likes this.
  13. Jun 15, 2019 at 11:37 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    1) Finished up the DEI Cool Tape installation project.
    2) Bolted/torqued up the exhaust crossover and Y-Pipe.
    3) Installed a new Denso O2 sensor in the Y-Pipe.
    4) Installed new exhaust gaskets for crossover, Y-Pipe, and connection with the cat. I plan to replace the exhaust system from the cat back when the weather cools in the fall.
    5) Installed the motor mounts for the new engine and torqued everything down.
    6) Cleaned up the transmission pan/filter and reinstalled it with the Red Toyota FIPG.
    7) Started installing engine heat shields.
    8) The new starter is under the truck and ready to go into position.
    9) I'm going out to find some electrical stuff for making a 16" pigtail for the downstream O2 sensor.
    10) Need to pick up some 1" flame retardant flex conduit for the wiring harness refurbish project. I think I will go to NAPS to see what they have in this area.
    Pictures.
    Y-pipe with the refurbished heat shield.
    More Cool Tape work near where the original heat shield ends near the O2 sensor.
    Engine bolted down to motor mounts. I got to put the Engine Stabilizer Bar back in its corner of the workshop until the next major project.
  14. Jun 15, 2019 at 11:40 AM
    cruiserguy
    Elijah
    SEKS
    Idaho mountains and hills, like the Tetons etc, are definitely an underappreciated outdoor scene. Nice to see you giving it some love
  15. Jun 15, 2019 at 12:13 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I hope they stay that way. Geotagging is ruining our public lands.
    cruiserguy[QUOTED] and jubei like this.
  16. Jun 15, 2019 at 12:31 PM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    Might do this, just put it in place of the factory relay?
  17. Jun 15, 2019 at 1:46 PM
    eon_blue
    Azusa, CA
    As luck would have it I snapped a brand new LBJ bolt as I was torqueing it down to 59ftlbs...right after I installed the new LBJ
    How do I go about getting the half bolt out that's still inside the balljoint? It's the inside bolt that doesn't go all the way through
    These were brand new OEM bolts too, wtf
  18. Jun 15, 2019 at 1:51 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Drill+easy out. (They're never "easy" but they do work...sometimes)
    eon_blue[QUOTED] likes this.
  19. Jun 15, 2019 at 1:54 PM
    eon_blue
    Azusa, CA
    Good thing the wife's car is here...making a home depot run now
  20. Jun 15, 2019 at 1:56 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I have one LBJ bolt that would never click at full torque. Figured it was starting to strip. Gonna let it be the dealers problem whenever the lbj's need changed.
