  1. Jun 20, 2019 at 2:30 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I have a garage for now. When I move out next year I doubt Ill have that perk. But I can still use my parents garage I guess, provided I dont move far away.
    01x4[QUOTED] likes this.
  2. Jun 20, 2019 at 2:37 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Non elocker diff are different than elocked diffs. I think the axles are the same though and I believe if you delete the abs ring it'll work on any axle housing. @Squeaky Penguin might know.
  3. Jun 20, 2019 at 2:43 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yeah you’re right, I was implying the non-locked and e-locked diffs are respectively the same. Might’ve worded that badly.
  4. Jun 20, 2019 at 6:33 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Why are you shackles completely vertical, or is that just a illusion.
  5. Jun 20, 2019 at 6:35 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I feel like they’d get some angle with weight
    jubei likes this.
  6. Jun 20, 2019 at 6:42 PM
    Adude
    Pnw
    04 Double cab
    Rule of thumb is 15* to them. If they are vertical and you are driving down a trail and lift a tire the energy will droop the tire more then a flex test. This causes the shackles to invert bend a spring or eye and cause major headaches. Having to high lift your truck and attempt to right a shackle with a bad leaf is a pita.
    I would move the mount /shackle hangers forward wd 1.5 inches.
    EDIT: Just my experience though, good job on the rest. Wish i had the time to box everything out.
    cali04intx and JKO1998[QUOTED] like this.
  7. Jun 20, 2019 at 7:06 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Mounted the new AC compressor. Finished up the transmission cooling line routing and mounted the power steering pump.
    Tomorrow I need to replace the AC condenser and dryer. I'll be glad when the AC part of this project is over. I can do it ok.
    Just not one of my favorite things. I'd rather be working on the suspension.
  8. Jun 20, 2019 at 7:30 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I ran lift shackles from the beginning, a poor mans lift when I had stock springs. I do have stock length greasable shackles that will be going on as part as all this work.
    I was thinking about moving them forward after @Rockbaron1 mentioned it. Maybe I’ll hang onto them in case I ever change my mind to net more travel. But at the same time I only got 10” shocks since that’s what most people can only get out of these trucks so I’ll run that setup for a bit and see how it goes.
    But everyone knows I beat the piss out of my rig and thankfully never had it invert on me luckily, so thankful for that.
  9. Jun 20, 2019 at 9:14 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Stock length shackles, also with the bed removed.
    Yes, they have more angle than @cynicalrider has but in both cases, once the weight of the bed and all the other shit is put back on the truck, they will have more than enough angle not to worry about.
  10. Jun 20, 2019 at 10:13 PM
    Adude
    Pnw
    04 Double cab
    I was referring to when a single tire drops down or say you get s good bounce and unload all the suspension. Not really driving on the street, although that will be a rougher ride as well. Just my personally learned lessons, not saying its not drivable or trying to put anyone down.
    Extreme yours are at the normal angle not straight vertical.
  11. Jun 21, 2019 at 3:13 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    No one thinks you are, it’s a good lesson in shackle angle, something that doesn’t get discussed much. :thumbsup:
  12. Jun 21, 2019 at 4:10 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    OneWheelPeel likes this.
  13. Jun 21, 2019 at 4:16 AM
    Black DOG Lila
    Virginia
    Mothers back to black trim and plastic restorer is AMAZING!
  14. Jun 21, 2019 at 4:19 AM
    Black DOG Lila
    Virginia
  15. Jun 21, 2019 at 7:25 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    That is a good angle, they should be 90 degrees of your leaf spring
  16. Jun 21, 2019 at 8:10 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    I might ask you to take a look at my "custom" ones as they aren't the best and I think they are causing issues with setting up my suspension properly.
  17. Jun 21, 2019 at 9:15 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  18. Jun 21, 2019 at 12:09 PM
    Vabunch
    Vabunch Well-Known Member
    Jeremy
    Capron va
    17 tacoma trd or dcsb & 96 tacoma scsb
    New ome coils with billies
  19. Jun 21, 2019 at 12:25 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
  20. Jun 21, 2019 at 12:35 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Rear shock mounts burned in.
    Area51Runner, turbodb, CS_AR and 7 others like this.
