  1. Jun 23, 2019 at 10:48 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's what I used to get, the 95-97 trucks seem to have a tinny rattle and the later ones get more of a sloppy clunk
    1997tacomav6 likes this.
  2. Jun 23, 2019 at 10:58 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yes.
    Though it also just makes that steering feel super direct. Like it took me a bit to get used to on the highway because if I looked out a side window I'd relax my hand and just the weight of it would shift the truck over haha
    Still nice though
  3. Jun 23, 2019 at 1:15 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Isn’t pretty but I saved $120.00.
    ireymon, BYJOSHCOOK, jubei and 7 others like this.
  4. Jun 23, 2019 at 1:23 PM
    jp59inh
    jp59inh Well-Known Member
    02 Tacoma Extra cab 4x4
    None yet
    Anyone elses hands too big for working on their Taco ? Grrrrr
    Taking the dash apart for stereo and amp install.
    chrslefty and Kwikvette like this.
  5. Jun 23, 2019 at 1:27 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Switched the mint condition passenger bottom cushion onto the drivers seat. Since I can keep my stock passenger seat, all I needed was a good condition drivers seat. IMG_20190623_154800192.jpg
    That dark spot in the back is just the light hitting it weird. I shampooed this thing twice and vacuumed it several times. Even used an iron to get some of the tougher stains out.
    Gyrkin, SwampYota and JakesTacoTRD like this.
  6. Jun 23, 2019 at 1:49 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I got it back and picked some wheels up.
    SwampYota likes this.
  7. Jun 23, 2019 at 2:33 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Got around to changing the contacts in the starter. Originally hoped to do it without dropping the skids, but I finally realized that they would have to come off.
    Starter out...
    Contacts weren't awful, but definitely needed some attention...
    Plunger is definitely pitted pretty good...
    One of the boots was the consistency of silly putty. It fell apart and stuck to my hands, the starter etc while removing. Gonna get one ordered before I get too much further...
    cruiserguy and SwampYota like this.
  8. Jun 23, 2019 at 2:58 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Damn why rip so much apart? I ran a amp for the speakers and a sub and didnt rip that much apart.
  9. Jun 23, 2019 at 3:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I've done the same in other cars; something about running the wires a certain way, zip tying them, and making sure everything is nice and tidy.
    You always want to run the signal wire on the opposite end of any power cables to prevent interference/white noise.
    1st4x4[QUOTED] likes this.
  10. Jun 23, 2019 at 3:14 PM
    1st4x4
    sam
    Torrance
    Zip tying I did not do along the whole path just in points to not alow sag. I ran my power on the drivers side and my signal lines down the passenger side both amps are in the back seat as you csnt get back there anyways because of my cage
    Kwikvette[QUOTED] likes this.
  11. Jun 23, 2019 at 3:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    looks good to me.
    Now rerun you cable so it disapears between the gauge cluster and dash so theres no cables :cool:
    1st4x4 likes this.
  12. Jun 23, 2019 at 3:54 PM
    Shortman5
    Supercharged TRD
    Yeah. I left it like that for easy access to one of the cables. Cold weather messes with my PLX gauge for some reason. My “fix” is to unplug then plug it back in and it usually works after that. It has a connection tucked into the hole for the swivel lever. So it’ll make it easier than before.
    I really need to make it all right though. I think it’s because I use the add a circuits in the fuse box for power and ground them to a screw behind the kick plate. I just need to do some homework because I’ve never wired anything into the ignition/starter before. I have zero knowledge of electronics.
    One other issue that’s plagued me is the boost controller flashes a random number intermittently. It’ll do it in vacuum and boost as well as when the key is on but engine not running. It’s weird and PLX customer support didn’t know what was going on. I’m hoping it’s something to do with the way it’s wired in.
    PLX is weird. They offer cool stuff for decent prices but it’s all kind of cheap and half assed. I had to wire the daisy chain backwards for it to work. It’s what PLX told me to do. And someone else on here had the same issue. Didn’t work the way the directions instructed. Reverse it and it works fine. They had some really neat products they scrapped as well. I’m assuming they just sucked so they just kept the stuff that worked and got rid of the stuff that didn’t.
  13. Jun 23, 2019 at 4:39 PM
    Tacomoon
    Tacomoon Member
    Art
    Oregon
    2004 Prerunner and 2004 TRD both Lunar
    Huge rack
    So I got in on the latest Waterport offer at Costco https://www.tacomaworld.com/threads/costco-waterport-sale.606051/
    I read through 24 pages of the original Waterport?Costco deal trying to find ideas how to mount it. Since it came with 3 different types of mounts and only 1 plate , I figured on fabricating an additional plate to have an extra option. I wanted to carry it in the bed area to travel and then attach to my roof rack or hitch when at camp.
    So 22 of the original pages were 2nd gen guys trying to figure out how to mount to bed rails. I went with a blank canvas and thought what would a 1st gen guy do?
    I had this stool already for general handy tasks, cut a pool noodle in half and ziptied on to legs. The rest is self explanatory.
    chrslefty and SwampYota like this.
  14. Jun 23, 2019 at 4:45 PM
    Tacomoon
    Tacomoon Member
    Art
    Oregon
    Huge rack
    It takes the weight well, no problem and less than 15 seconds I can mount the Waterport up on the rack or on hitch and have the stool for a small table or to reach up to the rack.
    Best part is the cost was $1 for the noodle and .04 of zipties, since I had the stool already. It came from Harbor Frieght and was under $20 with the coupon for %20 off.
    WyldeRayne06 likes this.
  15. Jun 23, 2019 at 4:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It started as a 'rattle' that I would feel/hear most on dirt but has progressed to where I could move my steering wheel about 1-1.5" before it would start the turn the wheels.
    I would describe mine as a sloppy rattle.
    I only drove it a little bit this afternoon but I can feel the steering is much more precise thru the potholes. :p
    Also worked on these.
  16. Jun 23, 2019 at 4:49 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Holy shit, how thick are those brackets :eek:. Thought mine were overkill but you took it to the next level lol. You'll be surprised to find that unless you run it up to the d ring mount, it doesn't do much. Bedside still flexes.
  17. Jun 23, 2019 at 5:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Jesus what is that 3/8 plate? Haha
  18. Jun 23, 2019 at 5:11 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    How much dirt does it take to make a MAF sensor misbehave? Not much.
    My Dad brought his truck over today. Very sluggish when cold, would barely accelerate, and hard starting when hot. Cleaned it and pulled the battery cable to reset the eng ecu parameters. Started immediately and ran perfect.
  19. Jun 23, 2019 at 5:11 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    :anonymous: Yeah I went a little over the top.
    And no, the bedside does not flex - at all. Haha it is ridiculously stiff now.
  20. Jun 23, 2019 at 6:48 PM
    TACOLGY
    TACOLGY Well-Known Member
    Mark
    2003 Tacoma TRD SR5 DC
    Put some Fuels & Nittos on her
