  1. Jul 5, 2019 at 1:03 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yeah I was considering near the cab of the truck under the bed. Although I want to mount an air tank there.
  2. Jul 5, 2019 at 1:26 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Under the bed. It's hollow.
  3. Jul 5, 2019 at 4:43 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Doubt it'll fit there. Be tight if so. Might not be the best choice there.
    Wouldn't do under the truck anywhere. You'll want access to it if possible.
    Don't you have a tool box in the bed?
  4. Jul 5, 2019 at 4:57 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yes, I have a toolbox. No space in my current one, but I have an old Knaack box I can use. Curious if there's any other mounting spots anyone else has used.
  5. Jul 5, 2019 at 5:40 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    One of mine is mounted in the corner of the bed, right behind the cab. The other is sitting on top of the driver side fender in the engine bay. I needed to move some EVAP lines and such but the mv50 fits like a glove there.
  6. Jul 5, 2019 at 6:33 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If you don't need the space under the back seats you could close one side off from the top and open it up from the bottom and mount there.
  7. Jul 5, 2019 at 8:39 AM
    5280
    5280 old school
    Colorado front range
    99 Tacoma TRD
    Trail Gear Front bumper, Warn, Apex Octane rear bumper, SPC, OME 881, Dakars, Raven topper, PIAA fog lights, dog mod and a couple other things...
    Celebrated the 20th anniversary of the day I bought Ruby.:proposetoast: Starting to think about selling, but not an easy decision. Such a great vehicle.
    BYJOSHCOOK, cruiserguy and xtremewlr like this.
  8. Jul 5, 2019 at 9:22 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I posted a thread on this very subject as I too wanted ideas for an alternative mounting location - https://www.tacomaworld.com/threads/on-board-air-alternative-mounting-locations.613460/
    In the end, I went with a CO2 tank.
  9. Jul 5, 2019 at 9:31 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Powertank in the bed.
  10. Jul 5, 2019 at 10:07 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Not a bad idea to prime the oil pump and/or filter before engine sees combustion again, since it's been drained.
  11. Jul 5, 2019 at 10:10 AM
    cruiserguy
    Elijah
    SEKS
    They actually have little systems you can add to your engine oil, basically it's a small electric oil pump you add in line to existing. This allows oil system to be at full pressure before it fires up while its cranking and 'avoids dry starts' supposedly. Toyota didn't see it important enough to add from the factory so I'd guess the benefit is prolly very little.
  12. Jul 5, 2019 at 10:20 AM
    eon_blue
    Azusa, CA
    There was some talk on here awhile back about how many people see the red oil lantern light flicker for the first couple seconds after the first startup following an oil change. My truck does it. After an oil change, I fire up the engine and the oil lantern light stays on for a second afterward (not long) then goes away. Never does it again until after the next oil change.
    I figured it was because the new oil filter is empty and it takes an extra second to fill up which maybe triggers that light for a split sec
  13. Jul 5, 2019 at 10:33 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Was thinking of mounting it under the bed, don’t want any clutter in the bed itself.
    Still have the crazy idea to run an old AC compressor as an air compressor.
    Running Board Man likes this.
  14. Jul 5, 2019 at 10:34 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I would always add oil to the filter before putting the new one in
    TacoYankee, cruiserguy and GQ7227 like this.
  15. Jul 5, 2019 at 10:35 AM
    eon_blue
    Azusa, CA
    I was thinking about trying that next time, I know some people mentioned that on here once. Just seems like more of a mess with how our oil filters go on but seems worth a try
  16. Jul 5, 2019 at 10:37 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    What are your plans for wheeling this rig? Not a lot of guys find it necessary to have oba. A little viair compressor or the like seems to work for most people. Just seems like youre being a little extra for a truck thats primarily a pavement princess right now. Id spend the money elsewhere personally, or save it.
  17. Jul 5, 2019 at 10:37 AM
    cruiserguy
    Elijah
    SEKS
    Yeah that's exactly what's going on. The pressure sensor switch doesn't feel that oil pressure against it until the filter fills up. So if you're doing your changes like within 30 minutes of turning the engine off, there will still be a bit of oil lubricating through the passages and galleys etc.
    If you're doing your oil change after it sat over night I'd be inclined to Pre fill the filter a bit and/or pull the efi fuse under the hood until oil light goes out. Then fire it up. Even then prolly not necessary but it can't hurt anything to do it. And you can't argue against the fact that it does make sure the engine oil is fully primed when it sees combustion by doing it that way. But likely not NECESSARY. BITOG forums might have some data on that. I'm kinda curious now
  18. Jul 5, 2019 at 10:38 AM
    eon_blue
    Azusa, CA
    I'm always envious of other guys' OBA setups when I see them but I'm happy with my Viar 300p. They make a 400p too which would be even faster, probably some models that are even better. But everyone I know that runs OBA setups like the ARB does it because it's primary use is for an air locker
  19. Jul 5, 2019 at 10:39 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I want a tank for running air tools. Not necessarily only airing up tires. I do some remote repairs and I usually have to carry a tank with me.
  20. Jul 5, 2019 at 10:41 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    should i be embarrassed to say i have never change oil in my truck, dealer has always done it since the very 1st change at 1k miles in IL
    i did change lots of oil in my teens as a lubeTech with benefit of an open pit
