  1. Jul 9, 2019 at 6:16 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Which is probably why ES bushings love to clunk and pop. The entire bushing is rotating when it shouldnt be.
    CS_AR and 95 taco like this.
  2. Jul 9, 2019 at 6:17 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That color scheme is looking good! Don't know why it caught my eye as much as it did?! Maybe the color matched fender flares caught my attention, I dunno. It almost looks burgundy/maroon and looks really damn good with the black armor and stuff
    Hawk_tx[QUOTED] likes this.
  3. Jul 9, 2019 at 6:19 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  4. Jul 9, 2019 at 6:20 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    ^^^ BINGO ^^^
  5. Jul 9, 2019 at 6:23 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Any time I see someone replacing every bushing on their ride with those familiar red poly clunk machines...
    TacoYankee likes this.
  6. Jul 9, 2019 at 6:26 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I did replace my rack bushings with ES. But none of that actually moves. They work well for that application.
    But that's as far as it goes for ES on my truck.
  7. Jul 9, 2019 at 6:30 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yeah the rack bushings seem to get a good rep. Anything else Id just use oem rubber or something like those whitelines.
    Running Board Man likes this.
  8. Jul 9, 2019 at 6:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    mm sort of. They help a lot with range of motion though which allows the suspension to do its job more. If you have a rough ride still, i'd look at your shock setup.
    OME for instance is not a smooth riding shock. They are on the stiff side.
    Plus then there is the coils you're running and the weight to go with it...ect ect.
  9. Jul 9, 2019 at 6:52 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    This man knows what he is talking about
  10. Jul 9, 2019 at 7:00 PM
    Hawk_tx
    Hawk_tx Well-Known Member
    Texas
    2001 Burgundy Tacoma Trd
    Yeah it is burgundy thanks you I’ve been trying to get it together little by little. Almost done with armor then suspension. Just need a rear bumper.
    cruiserguy[QUOTED] likes this.
  11. Jul 9, 2019 at 7:43 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You're feeling every pebble because you're running your tires at 45psi bud.
    Poly bushings is not the problem. LCA bushings aren't going to have anywhere near the effect that shocks, springs, and tire pressures will. In fact, I'd bet they have no effect at all on feeling bumps. All of the absorbtion goes up through the shocks/springs... the LCA bushings are just a hinge.
  12. Jul 9, 2019 at 8:04 PM
    1997tacomav6
    Denver
    Got mine done today, last time was 4 years ago, (150,000) miles ago. The rear flares Had LOTS of rock chips.
    But I took mine off. 6 bolts hold each one on, sanded them down, then primed them, sanded again and then put 3 coats of paint.
    I did replaced the rubber trim seal on the edges of each flares because the rubber
    was hardened and was cutting into the paint under the flare.
    If you have a lot of pitting the Rust-Oleum HIGH BUILD FORMAL
    primer is the ticket to smooth out the finish. It’s a really thick primer.
    The Rust-Oleum flat black paint x2 lays down a heavy spray with no running or spray issues with quick drying time.
  13. Jul 9, 2019 at 8:12 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Nice job scoring your brake points, hope it holds up well!
  14. Jul 9, 2019 at 8:15 PM
    Countryfriedtoyoter
    Countryfriedtoyoter Just truckin around
    2019dcTrdOR
    That's sweet I really like the leather overlay you don't see that often
  15. Jul 9, 2019 at 8:47 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    I blew out my ES poly rack d-ring bushing after two trips. I went back to rubber for the rack and it holds up much better to wheeling. I do have Whilelines in my LCA's and so far they have held up pretty damn well.
    95 taco and Running Board Man like this.
  16. Jul 9, 2019 at 8:56 PM
    theesotericone
    Bishop CA
    Just stress from wheeling. It split down the middle. Went to Beck Arnley's rubber kit and I only have to replace them every 6 months.
  17. Jul 9, 2019 at 9:10 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  18. Jul 9, 2019 at 9:22 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    cali04intx likes this.
  19. Jul 9, 2019 at 10:44 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  20. Jul 9, 2019 at 10:45 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    I been drinking lol sorry
