  1. Jul 15, 2019 at 1:50 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Awesome advice. Looks like I’ll skip my next hot oil treatment. Although I have to say my skin has never felt smoother or better moisturized than it has after catching half a quart of 5w-30.
    JPinFL[QUOTED] and cruiserguy like this.
  2. Jul 15, 2019 at 1:58 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I'm in same exact boat. Want easy oil changes and better access to components for maintenance and repair? Try the 3" body lift mod:rofl:was on it when I bought it. Pulling starter to change the contacts was a breeze, just like my oil changes haha
  3. Jul 15, 2019 at 2:11 PM
    Kevins60
    Kevin
    Odessa FL
    Doubt I’ll ever do a body lift but things might get a little easier when I replace the front shocks. I noticed that the coilovers are so beat that about 1/3 or more of the turns on the springs are compressed to the point they are touching.
  4. Jul 15, 2019 at 2:25 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Misfire cyl 3, no associated mis on its brother cyl?
    FLBAdrian[QUOTED] likes this.
  5. Jul 15, 2019 at 2:29 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Nope just that code was the only one.
  6. Jul 15, 2019 at 4:24 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I changed the starter in the parking lot at work once. In and out in like 30 min.
    cruiserguy[QUOTED] likes this.
  7. Jul 15, 2019 at 4:40 PM
    Kevins60
    Kevin
    Odessa FL
    This $#!+ is worn out, right? There is only 1” of upward travel until the LCA hits the frame.
    4775302C-8B8D-4DE5-AB8D-52A1F2AF87FA.jpg DED35B2D-FA74-4233-8629-54539CEC9DD2.jpg
  8. Jul 15, 2019 at 6:15 PM
    Jaysjammin
    Jaysjammin Well-Known Member
    Jay
    Upstate SC
    '98 SR5 5-speed 4x4 3.4L, 07 FJ Auto 4x4, 97 Locked 80
    Pretty much certain it's the same for all first gens. These are the part numbers for my 98. I get mine from partznet.com and others get theirs from parts.camelbacktoyota.com
    Lower Ball Joint
    43330-39815
    TACOMA; RIGHT
    Lower Ball Joint
    43340-39585
    TACOMA; LEFT
    4504639295 - OUTER Tie rod
    Tacoma; 4WD; Right
    4504739175 - OUTER Tie rod
    Tacoma; 4WD; Left
    Some OEM dealers also have a VIN check to make sure you have the right part for your truck.
    omaguz[QUOTED] likes this.
  9. Jul 15, 2019 at 6:17 PM
    Jaysjammin
    Jay
    Upstate SC
    Since you're doing a tune up anyway. Grab a can of throttle body cleaner and mass air flow cleaner. Takes about 15 minutes to take everything off and clean it.
    omaguz[QUOTED] and chrslefty like this.
  10. Jul 15, 2019 at 6:38 PM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    I will see what I can do.
    Haven’t posted a picture on here in a long time.
  11. Jul 15, 2019 at 6:40 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    The only place on my trucks frame that didn't have rust is right under the filter.
    Relax.
  12. Jul 15, 2019 at 6:55 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    You’re alive?! Do you still have your truck? Haven’t seen you on Battlefield in a while, but then again I haven’t played in two months.
    Got the bed back on, needed to cut part of the bed crossmember because of the lifted gas tank. Probably compromised some bed integrity so ideally next time the bed is off, I’d like to plate it a little or something. But we’ll see. :notsure:
    LukeCC, BYJOSHCOOK, chrslefty and 3 others like this.
  13. Jul 15, 2019 at 6:58 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Truck has been replaced with a TDI since my commute is at least 100 miles a day. PS4 took place of the ps3
  14. Jul 15, 2019 at 7:21 PM
    bangabull
    bangabull New Member
    Wheels, tires and a little lift!
    jonesbt, Prayn4surf, LukeCC and 6 others like this.
  15. Jul 15, 2019 at 7:29 PM
    bangabull
    Billy 5100 adjustable in the front, OME 881's
    5100's in the back , wheelers 1.5" AAL
    Rides like a dream compared to pre-loading the suspension with the adjustable struts
    sandsloth likes this.
  16. Jul 15, 2019 at 7:33 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Umm, no.
  17. Jul 15, 2019 at 8:44 PM
    eon_blue
    Azusa, CA
    I think he means he went from a 2nd gen to a 3rd gen and then to a 1st gen...at least I hope
  18. Jul 15, 2019 at 8:48 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Double Dose of Indian Hot Springs
    July 1, 2019.
    The day started out just like any other. Well, any other where the previous included a 12-hour drive from home to the starting point of our next adventure.
    So it was that, as we lay in bed, I looked over and said, "I've got an idea."
    Hey! Get. Your. Head. Out. Of. The. Gutter.
    See, we'd planned to spend the day heading to Indian Hot Springs via the east entrance - a dirt track that we'd been meaning to take since we'd first come to Idaho 18 months ago to pick up the CBI Outback Bumper. Having run our of time, we'd headed straight down to The Maze, Canyonlands, and we'd never made it back. Then, at dinner the night before, Ben reminded me that he and Kirsten had tried to reach the springs via the west entrance - stymied by a rock slide on the final descent down into the valley.
    So I proposed to @mrs.turbodb that we try the west route first. And then, if we couldn't make it down, we'd drive around to the east. But if we could - and if we could ford the Bruneau River (since the bridge over the river had reportedly been out for a few years) - then we could do both sides on our way east towards City of Rocks, our next destination.
    Read the full story and see all the photos: Double Dose of Indian Hot Springs
  19. Jul 15, 2019 at 8:51 PM
    Gen1FTMFW
    2nd gen --> 3rd gen --> 1st gen
    sandsloth and eon_blue[QUOTED] like this.
  20. Jul 15, 2019 at 9:34 PM
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    License plate
