  1. Jul 24, 2019 at 5:38 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Redline MT90 is witchcraft. I didn't think a toyota trans could shift so well.
    Silver02Taco, se7enine, Wulf and 2 others like this.
  2. Jul 24, 2019 at 5:46 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Well hit me up on the way through :thumbsup:
    Speedytech7[QUOTED] likes this.
  3. Jul 24, 2019 at 6:38 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Haha cool. Seems a little excessive and potentially thing to break(fans that is). I've been doing great with the passive cooler.
    The thing I need to add really bad is a power steering cooler. This last weekend I had it boiling over and it was only like 95-100° out.
  4. Jul 24, 2019 at 6:59 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  5. Jul 24, 2019 at 7:13 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @Speedytech7
    A thermostat switch and wiring harness (relay and fuse)
    The thermostat switch is set to turn fan on at 180° and shut back off at 165°
    Passive wasn't really what I wanted...
    A) Because it doesn't really cool much when going less than 10 mph.
    B) Because I want to keep the front of my radiator as clear as possible.
    BlackSportD likes this.
  6. Jul 24, 2019 at 7:33 PM
    eon_blue
    Azusa, CA
    Finally got around to setting up my short/long term fuel trim readings on my Torque app and tested it out on my way home from work today. From what I understand on what little reading I've done so far on STFT/LTFTs, you want them both to be as close to 0 as possible without exceeding 10 in either direction (positive or negative). Does that sound right?
    Just on my short ~7 mile trip home from work, I was seeing my LTFT average out to around 3 or 4. STFT jump all over but stay pretty much between -1 and 4. Is this acceptable?
    Area51Runner likes this.
  7. Jul 24, 2019 at 8:45 PM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Stripped out the PO’s nightmare alarm system, resoldered the factory harness, found a disconnected vacuum line and disconnected vacuum switch plug, reset my ECU and the truck feels better than ever. No more 17 LTFT at idle
  8. Jul 24, 2019 at 8:54 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    tire rotation at DT, had them turn the tires around (white letters out) for a different look
    and custom plates (just so I don't get asked again 'what year is that?')
    ... wanting to get that tow hook under in front colored, not sure which color would be better, perhaps the dark charcoal gray or red?
    SwampYota, cruiserguy and sandsloth like this.
  9. Jul 24, 2019 at 9:14 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    chrome mirrors too?
  10. Jul 24, 2019 at 9:25 PM
    mateo_roberto
    Mateo
    San Diego, CA
    Stock
    I’ve always had the system disconnected, but today was the day it all got removed. It’s a daunting task at first but if you go slow you realize most of it can really just be cut out. Only had to solder 1 wire.
  11. Jul 24, 2019 at 11:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    where you planning on mounting it than if not in the front?
    Running Board Man likes this.
  12. Jul 24, 2019 at 11:52 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    have no idea what you just said dude :anonymous:
  13. Jul 24, 2019 at 11:59 PM
    eon_blue
    Azusa, CA
    Haha no worries, it's a reading you can pull up on an obdII scanner to check fuel delivery based on short term readings and long term (average) readings from the ECU.
    If the numbers are off it can help narrow down problems like vacuum leaks, bad fuel pump, injectors, 02 sensors, etc.
    Fairly sure my numbers are good just seeing if someone knows better than me.
  14. Jul 25, 2019 at 12:26 AM
    Wulf
    rock raisin
    No joke
    Sebz13[QUOTED] likes this.
  15. Jul 25, 2019 at 6:27 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Yup. If MT90 isn't working then it's the clutch or the trans synchros have been killed already by lesser fluids.
  16. Jul 25, 2019 at 6:35 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Ideally you want the 2 numbers to add to around zero. Any number around higher than 10 isn’t ideal.
    eon_blue[QUOTED] likes this.
  17. Jul 25, 2019 at 8:01 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Probably under the bed.
  18. Jul 25, 2019 at 9:04 AM
    eon_blue
    Azusa, CA
    or the shifter bushing is bad
  19. Jul 25, 2019 at 9:18 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Yes, that too. I always forget how important that little bugger is.
  20. Jul 25, 2019 at 10:10 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Looks like a fun road! the heat must have been brutal though
