  1. Jul 25, 2019 at 4:39 PM
    eon_blue
    Azusa, CA
    It's on the list of things to do eventually, mine leaks a little but not enough to be concerning yet. Gets wet around the seal but doesn't drip
  2. Jul 25, 2019 at 4:47 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    You figure out the elite and I’d buy it! Lol.. always loved the looks of the elite bumpers
    Silver02Taco likes this.
  3. Jul 25, 2019 at 5:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    FIPG? Really? Never heard of that before.
    And yeah, this'll be the 3rd time it gets changed. First time was done by Just Differentials when they regeared the diff. Second time Jon did it for me in Powell in 2014...?
  4. Jul 25, 2019 at 5:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Took it off road, camped, and got back home.
    Posted about it in the Nor Cal regional section.
  5. Jul 25, 2019 at 5:20 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That's what mine has been doing for a while but after this last adventure, its more than just a little so time to change it I think.
  6. Jul 25, 2019 at 5:45 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'm sure they'd sell haha
    Yeah. Did it to mine. Doesn't need much just a bit.
    Second one lasted a while at least.
  7. Jul 25, 2019 at 7:57 PM
    Empty_Lord
    Dan
    ive had luck using the toyota orange fipg for the pinion seal, just a bit. not a whole lot, on the outside of the seal
  8. Jul 25, 2019 at 8:04 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    If you have the crush washer still careful not to crush it any more.
  9. Jul 25, 2019 at 8:05 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Do you have a solid pinion spacer in your diff?
    It's important you get the preload on the pinion correct.
  10. Jul 25, 2019 at 8:52 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I have small tube but I have no idea of its color.
    I also found there are two part numbers for the seal that are supposed to work. I have one of each and their O.D.s are identical but there is a difference in the I.D.s. The calipers say its a ~.001" difference. 90311-41009 and 90311-38047. It is interesting there are two of them. And they are different. The one that ends in 41009 has a rubberish surface on the top and OD. The one that ends in 38047 is metal on the outside and cost about half as much. Ever seen anything like that before?
    Yes, a solid spacer was used when I regeared. I think that means I don't have to worry as much about messing up the preload doesn't it? That I can be less careful about getting to 145 ft.lbs. of torque.
    Reh5108[QUOTED] likes this.
  11. Jul 25, 2019 at 9:00 PM
    Empty_Lord
    Dan
    hmm cant say i have. its been a while since ive done a pinion seal so i dont remember what it was. i want to say the non elocker diffs for sure have the rubber on the outside. last elocker i did was 4 years ago, i dont remember if it was like that or metal.
    Digiratus[QUOTED] likes this.
  12. Jul 25, 2019 at 10:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Correct the solid spacer you don't have to worry.
  13. Jul 26, 2019 at 7:15 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    This.
    m3bassman[QUOTED] likes this.
  14. Jul 26, 2019 at 7:24 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    MT90 and new shifter bushings cured 95 perfect of my shift issues
    1997tacomav6 and JPinFL like this.
  15. Jul 26, 2019 at 9:22 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Lose a lot of space like that
  16. Jul 26, 2019 at 9:24 AM
    eon_blue
    Azusa, CA
    Slightly better than just tossing the spare in the bed like I do I guess, lol
    Running Board Man likes this.
  17. Jul 26, 2019 at 9:28 AM
    eon_blue
    Azusa, CA
    Keep it in the stock location under the bed if it's a 33 or smaller. Been meaning to put mine back under there, maybe
  18. Jul 26, 2019 at 3:15 PM
    Taco86er
    Taco86er Well-Known Member
    Bay Area
    04 Dbl Cab TRD
    3” Eibach/Bilstein Lift, TG Low Pro Bumper, Hella 700’s, HID Retrofits, Hella Supertones, Deckplate, Grey Wire, Shell w/Thule Rack and Basket, LED Shell Lighting, Rear Bumper LED Pod Reverse Lights, Tinted Tails
    Does this mean i can fit a 255/85 tire in the stock spare location? It's basically a 33?
  19. Jul 26, 2019 at 3:19 PM
    eon_blue
    Azusa, CA
    255/85r16 is a true 33" tire, you might be able to but you might have to trim the ends of the spare tire holder off (or flatten them out) so it fits.
    If your exhaust is in the stock location then that might be in the way, I'm not sure. Mine is dumped over the axle
    Taco86er[QUOTED] likes this.
  20. Jul 26, 2019 at 3:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You have to bend the tire braces if I recall right.
