  1. Jul 29, 2019 at 2:10 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Can’t you adjust the tie rods?
  2. Jul 29, 2019 at 2:12 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Pretty easy to do yourself. Just move the tie rods an equal amount until your wheel is center. I kind of like a lean just because it's more comfortable with resting my left arm and where my hand sits on the wheel.
  3. Jul 29, 2019 at 3:01 PM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Best advice or write ups on the GM alternator. What exactly do I need to do or buy? I've seen @Blackdawg do one with a different belt, one says you dont need a belt, one has a relay one doesn't etc. Can anybody help me out there? Also the other prong on that alternator fuse wont come out. Sny advice there? TIA
  4. Jul 29, 2019 at 3:12 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You need the GM ago Toyota jumper harness, they sell them on eBay.
  5. Jul 29, 2019 at 3:23 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Can't route that through the stock box you'll melt shit.
    Just wire to the battery and then battery to fuse box
    j0shu4[QUOTED] likes this.
  6. Jul 29, 2019 at 4:04 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    7B1967FE-0D41-4DBA-BED4-5FC64F47E579.jpg Need some wiring advice. I need to wire this methanol controller to a 12V ignition source. I’m thinking of tapping it into the 7th injector, which is tapped into the ECU power.
    I also had to wire the pump directly to the battery and I also need to connect the controller directly to the battery as well. I’m just going to tap that into the power wire from the pump.
    This sound okay to do?
    At some point i think I’m going to add in the URD AFR controller. And I’ll have to tap that into ignition as well. How much shit can I tap into the ECU power before I burn something up??
    j0shu4 likes this.
  7. Jul 29, 2019 at 4:40 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I usually have to take mine back after alignment to get the wheel centered. They seem to forget to do it.
  8. Jul 29, 2019 at 4:41 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Hmm. Good thing its a short list of things to fix... Sounds like you are Rubicon ready...
  9. Jul 29, 2019 at 5:23 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I have no problems with end links or sway bar. Because the sway bar is in the garbage.
  10. Jul 29, 2019 at 6:05 PM
    Shortman5
    Supercharged TRD
    I had mine off for a while. Three weeks ago a coworkers son was in a car accident and is paralyzed now. I decided to put it back on after that.
    Area51Runner likes this.
  11. Jul 29, 2019 at 6:12 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    A lot of people here act like the only way to drive these trucks is sans sway bar. Im not running 600lb springs to serve the same purpose, therefore mine stays on. Take one curve too fast and all the money youve spent building your truck is for nothing. Or you're dead. Guess its up to who evers driving it to decide. :notsure:
    Area51Runner and CS_AR like this.
  12. Jul 29, 2019 at 6:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not much. Only a 7.5 amp fuse stock I think
    Id skip the URD shit anyways and get rid of the 7th injector especially if you're doing meth. Get an AEM FIC6 and run a slightly larger injector like an NA 7mgte injector. You'll get a better tune and be easier to tune.
    j0shu4 likes this.
  13. Jul 29, 2019 at 6:21 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    But it rides so much better without it, comparing my 99 to the 02 anyway.
  14. Jul 29, 2019 at 6:23 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    There could be a lot of other stuff at play there too. Bushings/joints in better condition etc. I like how my truck rides. Everything feels tight.
  15. Jul 29, 2019 at 6:26 PM
    JKO1998
    Utah
    I’m gonna say the 02’s in better condition, just going off of what I know about the 99.
    The 02 to does feel tighter with turns and such but I can feel every little bump in the road, which is fine, I’m not picky at all.
    Area51Runner and Blue92[QUOTED] like this.
  16. Jul 29, 2019 at 6:38 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Did someone say rubicon?
    Yeeeaaap!!! Same here
  17. Jul 29, 2019 at 6:43 PM
    Shortman5
    Supercharged TRD
    I know. Should have done that from the beginning. But I’ve gotta stop for a while and save some cash. The only reason I did the meth now is it hot as hell and Devils Own ran a 20% off.
    BTW Devils Own runs a 50% off during SEMA. check their Facebook. I wish I knew that before I got mine. That’s dirt cheap. Even if their controller, wiring, and fittings are garbage (they are) that’s a great deal.
    Anyway, I’m holding out for the OVtune 03-04 ECU flash. I don’t think anyone who has contacted Mathew has gotten anything yet but the ability to tune the ECU would be better than all that shit. and a portable programmer would be great too.
    Dude at work has a single cab Ram N/A with bolt ons and a tuner. Says he’s pushing 500HP. As much as I love these trucks I’d really like something like that. Much bigger performance market and easier to deal with.
  18. Jul 29, 2019 at 7:16 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Rubicon is on my ultimate goal list.
  19. Jul 29, 2019 at 7:32 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    You can join me in August!
  20. Jul 29, 2019 at 8:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh. Idk how well that'll work really. Hopefully we'll but not worth the wait. He knows the market is super small for that. I doubt he is in a rush.
    I'm looking to turbo one of mine this winter. I think it'll be great. These motors will push 350hp easily and 400ftlbs with the right tweaks. The blower just will never get there.
