  1. Aug 7, 2019 at 8:16 AM
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    I replaced my carrier bearing a few months back due to some vibration. Shortly after i started to get a clink clank at slow speeds, so i took it apart again and noticed one of the u joint in the middle was really stiff and to my surprise the toyota dealer said it was not replaceable. I tried all types of u joints, spicer, moog. Not one would let the outside clip set in, even though the u joint was the same size. So i ended up going with a full driveshaft.
    GQ7227[QUOTED] likes this.
  2. Aug 7, 2019 at 8:18 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    it should not be too difficult with some xtra help at a mod day,
    just the down time with waiting on the stuff to be powdercoated
  3. Aug 7, 2019 at 8:19 AM
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    After two shot carrier bearings, I remember that both made high pitched squealing noises. Had a Driveline shop do the work both times.
  4. Aug 7, 2019 at 8:20 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    that is very discouraging to hear those U joint parts are not replaceable any more!
  5. Aug 7, 2019 at 8:23 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    The double c(wtf it is) has never been easily serviceable as far as I know, the rest of the ujoints are easy.
  6. Aug 7, 2019 at 8:23 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i had been referred to a local truck place that rebuilds those but have not yet checked how much they want for that
    they would also paint the shafts I was told, but not sure of the cost for that rebuild or just a whole new part for $700 or whatever it is
    04yota likes this.
  7. Aug 7, 2019 at 8:41 AM
    MedicMutt
    Josh
    Baton Rouge, LA
    IIRC mine was somewhere in the $200-300 range. Carrier bearing and both end ujoints replaced, balanced and painted.
    I was told that the center ujoints (Double cardan joint) hardly ever go out, but if they do that they are not serviceable (a couple folks argue otherwise). Best option for DC is to cut it out and weld in a new one, or whole new drive shaft.
    Edit: original price I quoted was too high
  8. Aug 7, 2019 at 9:07 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    How much did that run you? Or is this one of those "if you have to ask..."
    GQ7227 likes this.
  9. Aug 7, 2019 at 9:28 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Jeg's has them in stock...
    https://www.jegs.com/i/Champion-Cooling-Systems/166/CC1778/10002/-1
    Or used to.
    +1
  10. Aug 7, 2019 at 9:35 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    How does the custom one mount - recessed threaded holes?
  11. Aug 7, 2019 at 9:44 AM
    eon_blue
    Azusa, CA
    chrslefty[QUOTED] likes this.
  12. Aug 7, 2019 at 10:21 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Where did you buy it from?
    GQ7227 likes this.
  13. Aug 7, 2019 at 10:49 AM
    04yota
    Angelo
    Central New Jersey
    From this place. https://www.wholesaleimportparts.com/
    best packaging i have seen so far. The u Joints are all spicer and it looks like overall good quality
  14. Aug 7, 2019 at 11:02 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Why in the hell.... Just buy new ones for probably the same cost. I feel like you just like spending money on pointless stuff that with one wrench on them will scratch and start to flake.
  15. Aug 7, 2019 at 12:57 PM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    How old is your fan clutch, what shape is you fan blade in, and have you replaced the fan brkt support w/bearing the fan bolts to?
    I'm running the champion w/factory 5spd man. fan shroud and I can say the difference is well worth the cost. Knock on wood 25k miles and no leaks.
    Replacing the fan clutch was very noticeable, and I think I even ran a few trails with you that both myself and Pat were starting to get overheat prior to swapping these parts. As ref, 37s @5200lbs that is taxing the cooling system alot with constant weight and higher revs. Replacing the fan clutch after the champion radiator made a noticeable difference on top of the already better cooling. No a/c here, no condenser so that might add a bit extra help. Always replacing a thermostat never hurts. Relief valve pointed down 6oclock position of course :D
    Even in hot traffic, I'm typically at 165*-175* (second trans cooler inline) trans temp od off, and engine is between 188-193*
    1997tacomav6 likes this.
  16. Aug 7, 2019 at 1:03 PM
    eon_blue
    Azusa, CA
    Sounds like maybe a bad fan to me...when I had crappy e-fans I couldn't wheel with the AC on either. Truck would start to overheat esp on hills. Got a new mechanical fan installed and I can wheel in 4lo in the SoCal heat with AC no problem. Stock OEM radiator still for me
    My AC also kind of sucks but that's another issue
  17. Aug 7, 2019 at 1:14 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    No electric fan here, only manual. Honestly sometimes it seems like the fan clutch is engaged too long tbh, that’s how I have been feeling lately. But since I have been hearing it roar more I have been thinking it’s on its way out and not properly engaging or disengaging exactly when it should. Crawling in heat has never been an issue though, I’m assuming because of the gearing. Timing belt and water pump was replaced at 200k, only at 245k now. I would think it sticking engaged would only make a cooler motor though, no?
  18. Aug 7, 2019 at 1:16 PM
    1997tacomav6
    Denver
    No, mine came as you see and you have to cut in the sections for it to fit and drill holes.
    This way there is much more meat on the frame of the radiator and my new radiator will definitely not
    be having any stress area.
    It definitely took some time to measure everything and line everything up, was not hard, just took time.
    GQ7227 and Dalandser[QUOTED] like this.
  19. Aug 7, 2019 at 1:21 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    So how much for us all to get another made from the same company? :popcorn:
  20. Aug 7, 2019 at 1:23 PM
    1997tacomav6
    Denver
    A custom aluminum radiator will cost you 600-1000.
    But there is NO comparison to anything on the market with quality of a custom.
    The champion in a crap radiator now that I see the difference and weight in person.
    But a custom Is definitely not for everyone.
    Silver02Taco likes this.
