  1. Aug 8, 2019 at 10:35 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    It mess up a day before I go camping. We were going to hit up bald mountain this weekend.
    GQ7227 and Speedytech7 like this.
  2. Aug 8, 2019 at 10:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah, I guess this is why we check these things. I was getting it ready to tow and doing all the fluids. Now that I know about it I can keep up on it and watch for additional symptoms. I've got the Z once Im back in WA. I'll tear the cruiser apart and set it right then.
  3. Aug 8, 2019 at 10:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think Jason did this too and may know. @jubei
    Adude[QUOTED], jubei and Speedytech7 like this.
  4. Aug 8, 2019 at 10:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Seems like kinda low miles for you to be having this happen but :notsure:
  5. Aug 8, 2019 at 10:42 PM
    Speedytech7
    It's a known issue for the 1FZ, Toyota used a crap material for the HG after asbestos was officially set aside and they since fixed it. You eat one HG for seemingly no reason and replace it and it never happens again. People on ih8mud actually do it as preventative maintenance, that's how common it is. It might just be mines time. But we'll know tonight, I replaced some minor parts that also could be the issue and I'm waiting to see if they fixed it
    CS_AR and Digiratus[QUOTED] like this.
  6. Aug 8, 2019 at 10:43 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    :fingerscrossed:
    Speedytech7[QUOTED] likes this.
  7. Aug 8, 2019 at 10:45 PM
    eon_blue
    Azusa, CA
    Did my inner and outer tie rods tonight, pretty straight forward job. Only I didn't order new bellows for the inner tie rods and I should have because I found a small hole in both of them when taking them off. So I'll have to take the outers off again to do that.
    I did notice quite a bit of dirt inside the outer tie rod on the pass side which I guess got in there over time from the tiny hole in the bellows. Hopefully that doesn't spell death for my steering rack. Cleaned off as much of it as I could.
    Installed OEM outers and 555 inners from LROR
  8. Aug 8, 2019 at 10:45 PM
    Speedytech7
    Did your wrench fit?
    eon_blue[QUOTED] likes this.
  9. Aug 8, 2019 at 10:47 PM
    eon_blue
    Azusa, CA
    Yessir, though getting a pipe wrench to fit snugly enough to loosen the inner tie rod wasnt exactly fun but it worked
  10. Aug 8, 2019 at 10:58 PM
    Speedytech7
    Just checked, didn't pull fluid back into the rad. It's not critically low or anything but the rad should always be 100% full. Guess that pretty much condemns it though.
  11. Aug 8, 2019 at 11:32 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Bummer.
    So can you tell me what you mean by it's not pulling fluid back to the rad?
    a) how'd you find this out?
    b) what are the symptoms?
    c) is coolant just not circulating, or is it going missing?
    Sorry, dumb questions. Learning.
    GQ7227 likes this.
  12. Aug 8, 2019 at 11:39 PM
    Speedytech7
    Burp tank was low, filled it, popped rad cap to check level since burp tank was low. It wasn't full but had some coolant above the fins still so filled it and went on my merry way. Checked again after it had cooled and it was low in the rad and too much in the burp tank. Figure combustion gasses are getting in there and pushing the coolant into the tank, not sure why it never draws coolant back in but either way its a classic symptom of a bad rad cap or a bad head/headgasket. Coolant is circulating, my cruiser is running at an appropriate temperature, it isn't smoking, it just is presenting early symptoms of an annoying issue. I just don't wanna cook the thing before I make it to WA. If it makes it to WA in one piece I'll get it sorted.
    turbodb[QUOTED] likes this.
  13. Aug 9, 2019 at 12:01 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Get a combustion gas tester. They’re cheap. I honestly don’t think you have a head gasket issue though.
  14. Aug 9, 2019 at 12:05 AM
    Speedytech7
    I'll do it tomorrow cause if it fails that I'll send it straight to Camelback and get bent over, seems wiser to have an aching backside than an engine welded solid from towing while injured.
    If it passes the block test what do you think it is then? I'm having trouble coming up with any other points of failure that I wouldn't visually see.
    CS_AR likes this.
  15. Aug 9, 2019 at 12:17 AM
    Empty_Lord
    Dan
    It’s hard to say without me being there. Pressure test and combustion gas test is what I’d do.
    m3bassman likes this.
  16. Aug 9, 2019 at 4:29 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Where did you purchase the new shaft?
  17. Aug 9, 2019 at 4:34 AM
    CS_AR
    Sorry to hear that.
  18. Aug 9, 2019 at 4:38 AM
    CS_AR
    Sounds like Subaru. Bought a Forester with a bad HG once to see what Subaru ownership was like.
  19. Aug 9, 2019 at 4:41 AM
    CS_AR
    Can you easily pull the plugs to get a read?
  20. Aug 9, 2019 at 5:08 AM
    CS_AR
    Is anyone using Redline Water Wetter? I use it on my older aluminum engines that call for Xerex Gold. Coolant temp averages around 183 F.
    1997tacomav6 likes this.
